-   GS Boxers (http://www.advrider.com/forums/forumdisplay.php?f=3)
-   -   Switched power sources for powering other items (http://www.advrider.com/forums/showthread.php?t=855289)
WindSailor 01-13-2013 11:50 AM
This has been brought up in other threads, but I wanted to hear your experiences and ideas on which circuit to use for a power source for relays, other items etc. and the issues or concerns using those circuits.
I have used the Green / Blue wire on the diagnostic plug to power my HyperLites controller (easy to get at etc.); but I found out through Robert that sometimes that is not a good idea. Here is a thread that shows it sometimes doesn't work - 06 R1200GS Battery Warning Light is ON... and to take JVB's suggestion seriously - "The blue/green wire on the diagnostic plug is fine for a signal voltage for something like a relay, but I wouldn't power anything off of it."
That is something I would have found out the hard way.
Any more suggestions, experiences?
Thanks to all.
Rick
Twempie 01-13-2013 12:27 PM
never had a problem
I have a Centech AP-1 (harness by Eastern Beaver), and PIAA 1100X lights (with PIAA harness) both individually posi-tapped into the g/b diagnostic wire for switched power. I haven't had a problem - yet - using this method with my camhead or my old R1150R. YMMV.
JimVonBaden 01-13-2013 02:38 PM
I have used the blue/green wire to signal relays on literally dozens of bikes, and seen well over a hundred done this way. Remember, "switched" power only. In the referenced thread the OP used the blue/green wire to actually power something, big difference. You use the B/G wire only for a switched voltage to a relay that actually turns on the power to an accessory.
See these:
http://www.jimvonbaden.com/images/2%20basicrelay.jpg
Note that the trigger/signal wire goes to terminal 86. Power in to 30 and out to 87.
http://www.jimvonbaden.com/images/5%...ng-diagram.jpg
http://www.jimvonbaden.com/images/BM...Cabe-share.jpg
Jim :brow
bemiiten 01-14-2013 02:50 PM
:hmmmmm How about powering the relay for your accessoies from the switched, protected accessory socket?
JimVonBaden 01-14-2013 08:13 PM
That works. However, it can leave your accessories on for up to 2 minutes after shutting off the bike. Furthermore, in a few cases such as some GPS chargers drawing a specific amount of power, it mimics the BMW charger and doesn't let the socket power down, which will kill the battery if you have lights connected to it.
Jim :brow
scooteraug02 01-14-2013 08:26 PM
Jim what can you do to add another brake light that goes on when the canbus light is triggered?
JimVonBaden 01-14-2013 09:53 PM
Use the stock brake light wire as a trigger through a relay. If the extra brake light is LED, odds are even you can wire it directly to the stock one. It depends on draw.
Jim :brow
Times are GMT -7.   It's 08:26 AM.
