-   GS Boxers (http://www.advrider.com/forums/forumdisplay.php?f=3)
-   -   Heated Grip Re-wrap...anyone done this? (http://www.advrider.com/forums/showthread.php?t=856853)
blueshoat 01-19-2013 05:20 PM
Looking for a little guidance here. I buggered my heated grips by accidentally severing one the wires. I unwrapped everything (throttle side) and reattached the resistance wires using some crimped metal tubing...but alas...no heat.
The left side still works, but I can't get any heat on the throttle side. I've checked the connections at the main junction (the connector that branches the left and right side from the harness) and even switched the left with the right to see if it was just a bad connection. No go. Clues anyone? (Its a 1995 R1100RS).
I'm wondering if anyone has ever fully unwrapped the wires to re-tape everything with success. I can't figure out why this would not work...but maybe I'm missing something? Not in the mood to drop $103 on a new heated grip!
http://i374.photobucket.com/albums/o...ps808793ab.jpg
mwood7800 01-19-2013 07:27 PM
Been making my own heated grips for me and friends for several years. Wrap the stock grip with bare niochrome wire then heat shrink. Then foam covers. Takes longer to wire the switch than making grips.
blueshoat 01-19-2013 07:33 PM
Sounds llike you're the guy with the experience. Can I just use my existing resistance wires and re wrap everything?
space 01-19-2013 10:53 PM
I never trust DIY crimp connections. Especially when they're subjected to a lot of vibration.
Are you sure you have good continuity there? Either way, I'd suggest finding a good soldering iron and make sure.
jdub 01-20-2013 05:33 AM
If the heated grips ever fail on my R12GSA, I plan on replacing them with this for $35. I'd installed this kit on my KLR and V-Strom, and it worked every bit as well as OEM BMW heated grips. Splicing into the bike's existing grip switch should be pretty easy.
blueshoat 01-20-2013 07:36 AM
I'll try soldering and report back...
blueshoat 01-20-2013 07:38 AM
Thanks for the lead. This looks like a possible plug and play alternative. Definitely my plan B.
STUFF2C 01-20-2013 12:48 PM
me too :deal
kellymac530 01-20-2013 01:47 PM
Not to hijack but a related question, on those $35 grip heater kit, how do you run the wires on the throttle side?
Out the end of the bars? Can you still run a hand system like bark busters?
STUFF2C 01-20-2013 06:35 PM
I ran mine in the end of the bar, then drilled a hole at the mid way point of the bars and fished the wires out there. don't see a way you can use anything that would install in the end of the bars after you install the aftermarket heaters. :ear
davek181 01-20-2013 06:48 PM
I use the cheapie grip heaters and they do fine. On the throttle side I run the wire to the inside and make a little bit of a channel in the grip for the wire to exit perpendicular to the bars, I then form a loop with enough length to allow the throttle to move full range and zip tie the wire in place.
Rocky Mountain had a grip heater blanket sale this fall, they were $9.99 a set. Bought two myself. :D
Mike Ryder 01-20-2013 07:24 PM
I had trouble soldering the nichrome wire. In the end I used acid flux and 50/50.
The nichrome crumbles up with silver solder heat.
STUFF2C 01-21-2013 12:51 PM
I wrap the two wires together and then crimp them. do the same any time i need to crimp wires together, never a problem so far.
I NEVER use butt connectors where you push a wire in each end and crimp them. Always wrap them then use one end of the butt connector, works for me.
Times are GMT -7.   It's 02:30 PM.
