-   GS Boxers (http://www.advrider.com/forums/forumdisplay.php?f=3)
-   -   2006 bmw hp2 enduro gas leaks (http://www.advrider.com/forums/showthread.php?t=872258)
STXTRUCK 03-20-2013 10:10 AM
Just sprung a leak from the high presure fitting holding the quik connect hose. Was able to patch it with teflon tape to ride home. This is 1 of 4 2005 2006 hp2 in cabo san lucas mine is the newest and the latest to crack. Teflon will not last as the gas eats it in a day. Anyone else been doused with gas at speed will make a permanent fix before buying new one / any idea what sealant will repel gas
bemiiten 03-20-2013 05:42 PM
http://www.advrider.com/forums/showthread.php?t=711467 Take a few minuets and report the leak to the NHSTA. These failures are widespread and BMW should issue a recall. Here is a good thread that shows how you can fix it http://www.advrider.com/forums/showthread.php?t=852502
hillbillypolack 03-20-2013 06:29 PM
You need the replacement fuel cap which has the reinforced (steel) threaded fittings for the hoses. The original one was made by Continental, the replacement I believe is Siemens. The cracks radiate out and allow fuel to seep at best or squirt at worst. Had that happen on my Megamoto, was a warranty fix, but since it's a fuel system concern you may be in luck and get it with some creative negotiations.
AA5IB 03-20-2013 08:01 PM
Happened on mine last October. Because it was a known issue BMW covered it at no cost to me. :clap
oldfool 03-20-2013 08:47 PM
2006 hp2 fuel leak
48,000 miles on mine and no leak yet. Richard
ViperJustin 03-20-2013 10:44 PM
It happened to my MegaMoto. Had it replaced by the BMW dealer, $860 later.............
K1DUDE 03-22-2013 01:09 PM
It is amazing how much info is available on this site.
http://advrider.com/forums/showpost.php?p=21003567&postcount=1
Times are GMT -7.   It's 03:53 AM.
