-   Airheads (http://www.advrider.com/forums/forumdisplay.php?f=85)
-   -   '72 R75/5-How to remove Ignition switch and terminal board inside headlight Bucket? (http://www.advrider.com/forums/showthread.php?t=886374)
Echolake 05-11-2013 03:22 PM
OK, I give up. Does anyone know the secret to removing the terminal board inside the headlight? I have searched this forum and every manual I can find. I am at a complete loss....
Plaka 05-11-2013 04:19 PM
Yeah...don't.
It is held in by folded metal tabs on the inside. unfold the tabs and they break when you try to re-use them, .
JonnyCash 05-11-2013 05:01 PM
I've done it twice on mine over the 20 years I've had it, and I'm sure I could never get away with a third time. If I ever have to take it out again, I'll need to come up with another way to hold it in there, maybe weld some other tabs. My headlight switch is a little funky, but I'm going to live with it until it just won't work any more before I pull it apart.
Echolake 05-11-2013 05:31 PM
Thanks for the replies...I took a chance and unbent 'em. Fingers crossed when I reassemble.
Kanticoy 05-11-2013 05:49 PM
I just did that since the original switch in mine just spun with no purchase. I replaced it with the aftermarket switch from Rocky Point. Much happier with it and couldn't be easier to install.
Bill Harris 05-11-2013 06:13 PM
I'm on my third removal in 40 years-- I think that next time will be _it_. I'm toying around with the idea of making a thin metal sleeve to fit inside the one in the headlight bucket that will have small screws to attach the switch board with. :amazon
--Bill
Chad M 05-11-2013 06:26 PM
Those tabs can be annealed to remove the work hardening done by the twisting motion. I've heard of guys using a 12v battery to localize the heat.
spo123 05-11-2013 08:21 PM
Bingo!
First prize for Chad M!
HOWEVER> DO NOT remove that board assembly unless ABSOLUTELY necessary.
Ensure good, clean connections from underneath and use a clean and non residue forming ELECTRICAL cleaner....Sometimes the ARM needs to be REFORMED (bent) slightly for proper contact....Sometimes the POINTS are burned and need to be BURNISHED.....Yes, POINTS.
You will see.
Troubleshoot everything up to the SWITCH BOARD first.
Good Luck.
In the last 58,000 miles, I have not needed to remove mine...
See 'ya,
spo
Bill Harris 05-11-2013 08:51 PM
And Duane Ausherman has a good section on the care & feeding of the /2/5 switch plate:
http://www.w6rec.com/duane/bmw/ignkeys/index.htm
and beau coup other information...
--Bill
Echolake 05-12-2013 09:11 AM
Great info!
Hey everyone, Thanks for taking the time to answer. I think that this is the first time for these ears so I may just get lucky. This is my first BMW. She sat in a warehouse for 14 Years and I'm having a blast getting her back on the road.
Times are GMT -7.   It's 04:07 AM.
