-   GS Boxers (http://www.advrider.com/forums/forumdisplay.php?f=3)
-   -   getting the garmin 5 to work with everything (http://www.advrider.com/forums/showthread.php?t=963093)
mqo233 03-19-2014 12:13 PM
on my 14 gsw, I got the factory GPS5, I contacted J & M, for the intercom, I got everything I need, everything works but,
my I-phone is suppose to connect to the GPS, through blue tooth, and then the GPS is suppose to connect the J & M through blue tooth,
the J & M will only talk to one device, while the GPS can communicate to two devices
I read all the manuals and am fixing to try it, I was hoping someone has some inside information that would help,
please let me know.
thanks
James Carpenter
mqo233 03-20-2014 02:43 AM
this morning, I looked and many people have looked at this and no one can help me,
that just surprises me,
thanks to all that looked
James
Travman 03-20-2014 08:10 PM
So what is not working. Sounds like you have them all paired correctly. I use a Sena headset but have the same pairing. iPhone is paired to Nav V and the Sena is paired to the Nav V. I can answer and make calls through the Nav V. For music, I loaded my songs onto a micro card and use the Nav V. So far everything pairs up and works flawlessly.
mqo233 03-21-2014 02:36 AM
I can not firgure out how to pair the phone to the nav 5, I know I missing something, but that is the biggest problem right now.
thanks for your help.
we can talk off line if you want
or keep the conversation here so as others could learn
thanks
James
fbj913 03-22-2014 07:44 AM
thanks
James
read the directions. :wink: follow it exactly. Garmin support is also helpful... give them a ring.
Times are GMT -7.   It's 04:37 PM.
