Old 10-24-2005, 05:06 PM   #1
clintnz OP
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,504
Air in 640 Front Brake, Again!!
Went to pull the 640 ('03 Enduro) out of the shed this morning, (she's been there for 3 weeks all lonely while I've been holidaying in Europe with a newer model ) & discovered a very mushy front brake, When I had this a while back & I checked all the brake fittings & bled the system which fixed it, now it's happened again. Does anybody have any clues on where the air might be getting in? Do I need new seals somewhere?
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 10-24-2005, 05:34 PM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Cheers
Clint
You might want to completely flush the system with fresh dot 4 or 5.1 Clint... prolly has water in it.
So... how's tricks?
creeper is offline   Reply With Quote
Old 10-24-2005, 06:02 PM   #3
clintnz OP
clintnz's Avatar
Oddometer: 3,504
Did a full flush last time, the fluid was clean, but there was definitely air in there.
Cheers
Clint
Old 10-24-2005, 06:49 PM   #4
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Cheers
Clint
Strange... fluid is hydroscopic... but very little rubber in the system exposed to atmosphere, no rubber in the hose at all. Front side of the caliper piston O-rings... backside of the master cylinder O-ring… that's about it.
Oh well... it only takes a little bit.
So... how's tricks?
Old 10-24-2005, 07:14 PM   #5
yater
yater's Avatar
Oddometer: 8,517
back bleed your system. I haven't seen anything on backbleeding on this site but it's BY FAR the easiest way to ensure there is no air in the line. Simply fill from the bottom nipple...takes 5 minutes and works everytime. If you don't find any info on parts needed when you search, pm me and I'll start a "how to" thread
yater is offline   Reply With Quote
Old 10-24-2005, 07:56 PM   #6
clintnz OP
clintnz's Avatar
Oddometer: 3,504
Cheers for that, but it's not the bleeding that is the problem, when I bled it last time the lever came up nice & hard, & it was good for the couple of months & several thousand km's until now. I'm really looking for any ideas on how the bike is getting air in the brake system while sitting in the shed??
Cheers
Clint
Times are GMT -7.   It's 05:51 AM.
