Old 11-03-2005, 10:21 AM   #1
myblubeemer OP
JWAT
myblubeemer's Avatar
Oddometer: 435
Scott Harden School & Lower LC4 E Pegs
Serveral of us on Adv Rider were lucky enough to take the one day Scott Harden off road school. What a great opportuntiy! Scott started off with some classroom instruction and then took us out to real world, working on everything from bike setup, to "barrel" racing, to trail riding.
In the bike set up portion, he pointed out to me what I already kinda new. Even with 30mm risers and higher bars (Pro Taper Pastrana FMX) on my LC4 E, I still have to stretch too much to the bars while standing in the "correct" position (I am the token tall guy in the pic). Since I have gone about as high as I can on the top end with the risers and bars, he suggested lower pegs.
Herein lies the problem. I've searched high and low for a source of lower pegs on the LC4 E without much luck. If anynoe has any solutions or suggestions on how I can get at least an inch lower pegs, I would greatly appreciate it!
Thanks,
Joel
myblubeemer is offline   Reply With Quote
Old 11-03-2005, 10:29 AM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
A set of Fastways will lower you about 1/2" and provide a much larger, more stable platform from which to conduct business.
I had to buy and modify a left footpeg braket from an SXC to install them on my 640 Adventure... but the additional cost was well worth it.
creeper is offline   Reply With Quote
Old 11-03-2005, 10:47 AM   #3
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,763
Send a message via AIM to Stobie
I have the same problem. I've put Emig underbar steering damper mounts on, along with the Pastrana FMX bars, and it's still not enough. Fastways are the next step, but it still may not be enough. If I raise the bars any more, I'll have to replace all the control cables.
For reference, I'm 6'4", but I don't have particularly long arms--the sleeves on a 46R jacket are long enough.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 11-03-2005, 11:50 AM   #4
myblubeemer OP
JWAT
Oddometer: 435
I am 6'5" and wear a 46XL jacket. If I knew the 1/2" gain on the Fastways would do the trick, I would do it right away. When Scott stood me up on the bike and put me in position, it appeared that I needed at LEAST an 1", maybe a little more. I don't want to go to custom cables, mainly for the pain of replacement down the road. I may have to go with the 1/2" gain and be happy with that.
Old 11-03-2005, 11:59 AM   #5
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
1/2" is better than nothing... and it opens up your seated position too. The Fastways alone are worth the price of admission comparied to the iddy biddy stock pegs, even without the "lowboy" feature.
Old 11-03-2005, 04:01 PM   #6
gaspipe
Just a dude....
gaspipe's Avatar
Oddometer: 11,204
Originally Posted by creeper
...snip...The Fastways alone are worth the price of admission comparied to the iddy biddy stock pegs, even without the "lowboy" feature.
I love Fastways as much as the next guy, but the OE KTM rally pegs are nice for the price at ~$45 for the pair
But then again, I use Saran Wrap for rain gear.
Rally Foot Peg (5850304000090)
Rally Foot Peg (5850304100090)
gaspipe [the original]
I contend that for a nation to try to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle.
-- Winston Churchill
gaspipe is offline   Reply With Quote
Old 11-03-2005, 12:02 PM   #7
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,842
Good info from creeper there.
The Index Thread has a direct link to my Yahoo Briefcase, plenty of nick-nacks in there. Help yourself.
Index Thread
"Other external links to downloads"
http://f2.pg.briefcase.yahoo.com/bc/...c=bc%26.view=l
Yahoo Briefcase
"Fastaway guide"
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-03-2005, 03:44 PM   #8
gaspipe
Just a dude....
gaspipe's Avatar
Oddometer: 11,204
Joel,
Since the OE pegs are mild steel, it might be worth it to bring them to a machine shop and have them modified (cut and some additional material welded in) to lower them an inch. It will likely move them outward just a tad to properly brace them, but I don't think it'd be particularly expensive to do.
BTW, it was fun riding with ya (I'm the guy on the far left).
Bruce
Old 11-03-2005, 07:05 PM   #9
myblubeemer OP
JWAT
Oddometer: 435
Index Thread
http://f2.pg.briefcase.yahoo.com/bc/...26.view=lYahoo Briefcase
"Fastaway guide"
VERY HELPFUL!! Thanks Meat!
Old 11-03-2005, 11:03 AM   #10
meat popsicle
Ignostic
Oddometer: 13,842
creeper, did you have to do any grinding to get them to fit? there is a Fastways installation guide someone put together to download in the "other downloads" link in the index thread. that one included lots of grinding and supposedly sucks.
ISTR, somebody else mentioned there are a couple of variants on the Fastaways, perhaps they said adjustable or non-adjustable; and perhaps the non-adjustable ones required more grinding? of course this is from the dark recesses of my potato vodka addled brain... so i could be high.
Old 11-03-2005, 11:22 AM   #11
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The right one was a bolt-on other than some light grinding to shorten the Fastway collar about .010".
The left requires the '04 625SXC footpeg mount and hardware store sourced allen bolts to mount it to the frame.
You have to grind or mill a radius into the mount for clearance for the peg. You also need another right side peg pin, as the stock left side pin becomes too short for the new mount.
Thats about it. A little grind, stare and compare, grind a bit more... about 1/2 hour for all of it.
C
Old 01-27-2010, 05:05 AM   #12
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 1,760
C
Plus One!! This is the exact same way I mounted my Fastway Pegs. One of the best mod's that I have made! It makes a world of difference to get a peg that you can actually stand on!! The bracket from the 625 cost me 54 dollars.
Take Care Brothers, Eric.
BIG-E is online now   Reply With Quote
Old 01-27-2010, 10:21 AM   #13
sam1905
...it wasn't me!
sam1905's Avatar
Oddometer: 216
Which fastaways
Are there Fastaways for the 04SXC? IF not what model / bike fit did you use?
Sam
2008 Ducati 1098s (For Sale)
2009 KTM 690E-R
Two 1978 R100RS slowly coming back to life as Cafe bikes...
2010 R1200 GSA
sam1905 is offline   Reply With Quote
Times are GMT -7.   It's 12:04 PM.
