Old 12-04-2005, 06:26 PM   #1
Loadedagain OP
making chips
Loadedagain's Avatar
Oddometer: 26,745
lc4 odometer. who has the most miles?
ok... i'll edit the first post as you guys add info. how many miles are on your lc4 and what major repairs have you done? maintenance does not count. i'll start. mine has 25,000km with absolutely no engine repairs whatsoever.
lets hear it guys
updated 11.02.10.
gunnerbuck - 127,000km - http://www.advrider.com/forums/showthread.php?t=632893
jan from finland - 97,000km
clintnz - 95,000km - http://www.advrider.com/forums/showthread.php?t=633753
samh - 71,000km - 44,000m - no repairs (new owner)
castleman - 49,600km - 31,000m - water pump seal, ignition coil
motomike - 33,600km - 21,000m - replaced main bearing, carb issue, new clutch
mikeprod92211 - 25,600km - 16,000m - starter clutch
loadedagain - 25,000km - 15,500m - no repairs
herobikes - 24,480km - 15,300m - no repairs
markjenn - 24,000km - 15,000m - no failures, has repaired several problem areas
ausierob - 20,800km - 13,000m - no failures (slipping starter clutch)
ktim - 20,800km - 13,000 - cylinder head leak
empedrado - 20,800km - 13,000m - minor ignition failure
martindktm - 20,000km - 12,000m - cylinder head leak
braaap! - 14,500km - 8700m - no failures
chrisc - 9,080km - 5,675m - no repairs
sherpa - 0 - 0 - brand flippin new
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain screwed with this post 11-03-2010 at 05:19 PM
Loadedagain is offline   Reply With Quote
Old 12-04-2005, 06:38 PM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
I'm just a piker. 2003 - 5,675 miles - no issues (save one leaky fork seal).
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 12-04-2005, 07:17 PM   #3
SamH
90S on the bench
SamH's Avatar
Oddometer: 436
Bwahahaha
71,000k's, 44,000m's and I haven't even got it yet.
I'll know in 2 days if that's worth bragging about
Work done... a lot I hope.
SamH is offline   Reply With Quote
Old 12-04-2005, 07:49 PM   #4
sherpa
...Robert
sherpa's Avatar
Oddometer: 3,183
05 Adventure...0.8 miles...no repairs yet. just got it yesterday, and we're supposed to get 4-8" of snow tonight.
Trebor Home Inspections
05 640 Adventure
08 KTM 250 XCFW
I'd trade all my motorcycles for one Flying Dragon.
sherpa is offline   Reply With Quote
Old 12-04-2005, 08:07 PM   #5
herobikes
HE AINT HEAVY HES MY LC4
herobikes's Avatar
Oddometer: 207
Miles
15,300 miles , no repairs , dead nuts reliable.2000 six days 640e
herobikes is offline   Reply With Quote
Old 12-04-2005, 08:12 PM   #6
empedrado
Oddometer: 372
Mileage
Total on bike 13,000 miles, over 10,000 this year (I bought the bike used a year ago). 2003 640 Adv. Not a single problem other than a loose wire in a connection that caused the bike to misfire for awhile and then die entirely. Was able to diagnose myself and has run smoothly ever since.
empedrado is offline   Reply With Quote
Old 03-19-2006, 01:54 AM   #7
freekb
Oddometer: 1
'99 LC4 in supermoto trim. Ran for 23300 miles (37500km) then self-destructed.
Still figuring out what went wrong, but consensus is crank pin failure.
Work done: fork seal + pitted stanchion replaced, snapped chain and replaced the 'bearing of doom' preventatively (even though it's not an 02 model). Starter motor on the way out (worn brushes). And replaced sidestand spring after I trashed it by kickstarting with the stand down.
freekb is offline   Reply With Quote
Old 03-19-2006, 05:29 AM   #8
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,709
02 Adv, 32k kms.
Water pump
Base gasket
main bearing
couple of oil leaks
Keeping the fastener shop in bidness replacing bolts it loses.
New ugly sound in motor, suspect big end conrod bearing. Gotta tear it apart.
Issues. Always issues. Can't ride it more than a thousand k without having to fix it. Fun to ride when it's running.
If I had the money, it'd be gone. Very disappointed in the cost of ownership with this thing.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 05-07-2006, 01:03 PM   #9
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,942
Stator clutch
Is the stator Clutch a problem with the 640 LC4 engine? I have an 03 and my mate has an O3, on the weekend we pulled up for a chat and went to ride off again, when the mates bike wouldn't start, the starter would just make a wizzing sound. he then kick started the bike, which fired just fine. Then a crack appeared in the stator cover and oil came rushing out. We pulled this cover off and there were five hex head bolts which were sheared off. Can any one shed some light on what happened and why?????
Regards,
JM
MymoJoe is offline   Reply With Quote
Old 05-07-2006, 06:26 PM   #10
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Yeah. It broke
Why? Dunno but I bet any KTM dealer I know will say its not a warranty fix
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 05-08-2006, 02:49 AM   #11
Roarin
Oddometer: 73
Just looked at the engine parts manual & it looks like the bolts that hold the one way starter clutch to the flywheel have broken/sheared. Best guess would be that they have somehow come loose allowing freeplay betwen starter clutch hub & flywheel. Eventually the bolts have sheared off & caused the damaged you described. In hindsight if you had not kickstarted the bike but pulled the cover off you could have removed the broken bolts before they wedged & broke the casing. Who would have guessed huh?
Roarin is offline   Reply With Quote
Old 05-08-2006, 09:09 AM   #12
BonneRocker
BonneRocker's Avatar
Oddometer: 241
'00 Ktm Lc4e...
second owner
17000 miles
stronger than ever
still for sale...
But when we ride very fast motorcycles, we ride with immaculate sanity. - HST
BonneRocker is offline   Reply With Quote
Old 05-08-2006, 10:00 AM   #13
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
2000 640 ADV 9226 miles
Fork seal and choke cable. Runs like a top
Just say'IN
crankshaft is offline   Reply With Quote
Old 05-08-2006, 09:59 AM   #14
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Regards,
JM
Did you check the (bleep)ing index thread?
LC4 clutch noise
http://www.advrider.com/forums/showthread.php?t=118095
Check post #9 from dirtrider...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-08-2006, 01:03 PM   #15
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,942
did you even read my thread Meat?
LC4 clutch noise
This has nothing to do with the standard clutch noise... if you don't have accuarate or relevent input - then don't
Times are GMT -7.   It's 10:47 AM.
