Old 07-01-2006, 09:36 AM   #1
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
Carb Vent lines???
Need help figuring out how to vent FCR carb lines, dealer removed smog and routed all lines behind swingarm. So other than the drain bowl line (noob- obvious) I am at a loss as to which lines need to be raised and filtered. Please help cause every darn time I go creek running I get bogged down ...thanks,
Dan
TE-610 FCR MX
buffallodan is offline   Reply With Quote
Old 07-03-2006, 08:04 AM   #2
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Talking
You should run all vent lines to a "T" and run one side up under the tank and the other down behind the swing-arm. So if you have 2 vent lines you will have two "T's" and two sets of vents up high and two down low.
This will stop the vent lock when crossing creeks as the vents up high can still draw air while the lower vents are in the water. I found some hose the right size at my Walmart and "T's" at my auto parts store.
This setup will work wonders and is very cheap as well!
Go forth and modify my friend.
jeff_in_rc is offline   Reply With Quote
Old 07-03-2006, 03:37 PM   #3
twotyred
Practising Recedivist
twotyred's Avatar
Oddometer: 2,106
Thanks for the info. This was something that I've been searching for as well.
I've had a couple of problems myself crossing some creeks. I hate it when you bike stalls just one metre short of the other bank. Didn't drop it - just wet feet!!
If you succeed at first...don't look surprised!!
More enthusiasm than ability!!
twotyred is offline   Reply With Quote
Old 07-03-2006, 04:18 PM   #4
desmo900
desmo900's Avatar
Oddometer: 63
Could all of the carb. vent hoses be sent to a manifold. and then one hose to the swing arm and one hose up under the tank ??
desmo900 is offline   Reply With Quote
Old 07-05-2006, 08:23 AM   #5
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Talking
I don't see why not as long as you have good airflow through the lines which is what you need for proper venting.
Old 07-05-2006, 11:03 AM   #6
Beez
Given to fly
Beez's Avatar
Oddometer: 5,810
I just "t-vented" my RXC last week but did not put one on the line that comes out of the bottom of the bowl. Does this one need a t-vent too?
Beez is offline   Reply With Quote
Old 07-05-2006, 12:55 PM   #7
jeff_in_rc
A DRZ kind of guy
jeff_in_rc's Avatar
Oddometer: 616
Talking
No, as this is a drain only and not a true vent.
Old 07-05-2006, 02:12 PM   #8
Beez
Given to fly
Beez's Avatar
Oddometer: 5,810
Thanks Jeff! That's what I thought but it wouldn't be the 1st time I was wrong.
I'm a California native, used to ride in your neck if the woods a lot, and you know what? There's a shitload of water to deal with in New England! Kinda freaky for a SoCal boy dealing with water, but the more I deal with it the more confidance I gain. But the sputtering engine sucks.
Fun stuff
Old 10-20-2006, 07:26 PM   #9
Countdown
Oddometer: 5,618
As I wrote in another thread, I think that one vent hose on each side should go down to drain any liquid gas that comes out the vent when bike is on its side. Second hose on each side should go up under tank to break vacuum when lower hose goes under deep watter. Bikes with all hoses down tend to stall in deep water.
The vent is a pressure vent and does not need any air flow except to equalize pressure.
Jerry Counts
Countdown is offline   Reply With Quote
Old 10-20-2006, 10:18 PM   #10
rmhrc628
rmhrc628's Avatar
Oddometer: 2,570
OK this is what you should do:
One hose from eother side goes north and gets routed up near the tank. The other 2 stay low.
I did the left hand side as the way FCRs route their hoses, they have one from each side passing through on opposite sides
rmhrc628 is offline   Reply With Quote
Times are GMT -7.   It's 04:23 AM.
