Old 07-04-2006, 08:07 PM   #1
Komet OP
The Voice of Reason
Komet's Avatar
Oddometer: 38,096
Blue Sea 5025...
I've noticed a couple of folks using these things and am considering the same for my new 1200GS...quick question...are you folks just strapping them into the tool compartment or more of a permanent type mount?
Always mindful of obstruction, do your duty, never fail;
Keep your hand upon the throttle, and your eye upon the rail.
Komet is offline   Reply With Quote
Old 07-04-2006, 08:08 PM   #2
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
Jim
JimVonBaden is online now   Reply With Quote
Old 07-05-2006, 02:45 PM   #3
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,539
Originally Posted by JimVonBaden
What, no fuse from the battery + to the 5025 ??
That's actually how I have mine wired but I'm worried about it shorting out..
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 07-05-2006, 02:48 PM   #4
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
I know it is supposed to be close to the battery, but I placed it further along and under the fuse box, along with a relay to power it when the key is on.
Jim
Old 07-05-2006, 06:33 PM   #5
Hotspice
Hotspice's Avatar
Oddometer: 5,539
Jim
I've seen your pic a few times and never looked close enough to see that you relay the whole block..
Not a bad way to eliminate turning off a bunch of gadgets when you are done with the bike.
Old 07-05-2006, 07:21 PM   #6
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
Helps me not to forget, and kill the battery!
Jim
Old 07-04-2006, 09:58 PM   #7
onewheelwunder
are we there yet?
onewheelwunder's Avatar
Oddometer: 166
the strap works fine but I put a couple of sheetrock screws of varying length thru the provided holes in the fuse block. Be careful of the relays and other electrical wizadry underneath the tool tray. I also stashed my tire patch kit underneath it. If ever need it I can just unscrew it with multi tool.
onewheelwunder is offline   Reply With Quote
Old 07-04-2006, 10:10 PM   #8
Komet OP
The Voice of Reason
Komet's Avatar
Oddometer: 38,096
Wonder how a little velcro patch would suffice?
Old 07-05-2006, 02:48 AM   #9
kdude
orgasmatron engineer
kdude's Avatar
Oddometer: 2,022
I strap.... works perfect, easy to pull out to clean.
BMWMOA 122163
kdude is offline   Reply With Quote
Old 07-05-2006, 04:57 AM   #10
Belg
Belg's Avatar
Oddometer: 3,940
Strappin and happy...
"Tend to the wolf within your fences. The pack outside may not even exist." - Frank Herbert
"The difference between stupidity and bravery is often measured by the survival of the player." -Me
http://www.terrawolf.com/ for pictures
http://www.wvhorsetrainer.com Our Farm
http://www.natural-horse-training-methods.com for horse training information
Belg is offline   Reply With Quote
Old 07-05-2006, 05:48 AM   #11
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,080
I strap mine in too. Makes it easy to lift if I need to get to stuff that is under it.
Old 07-08-2006, 03:33 PM   #12
HasBean
HasBean's Avatar
Oddometer: 61
Fuse Block
I used the Centech since it's smaller and mounted it to the tool tray with some smal screws.
HasBean is offline   Reply With Quote
Times are GMT -7.   It's 01:10 PM.
