Old 07-13-2006, 05:15 PM   #1
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
1200 Adv winglets on 12GS
I installed a set of Adv winglets on my 12GS today and the difference is amazing! I would say the wind noise is less than half of what it was.
They also eliminated the buffeting/vibration that I used to get from my helmet (HJC Symax).
Mounting was easy....just marked the holes and drilled. I used about 1 inch fender washers (just a large washer with a small hole) underneath to help distribute the forces on the fairing piece. Seems to be working fine, I can't notice any major flexing of the bodywork.
Has to be some of the best $45 I've ever spent. I can actually hear my motor now. OK, it wasn't that loud before but it is ALOT quieter now.
Barry
mrmaico is offline   Reply With Quote
Old 07-13-2006, 05:32 PM   #2
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,411
Good show Barry!
Dang, for $45 its worth a try.
Do you have a part number?
Karl | 2014 BMW R1200GSW Adventure | 2009 BMW G450x
Originally Posted by SchizzMan View Post
We pay Motorrad to design weight off the bike then pay TouraTech to bolt it right back on.
rideLD is offline   Reply With Quote
Old 07-13-2006, 05:47 PM   #3
GELSTRA
GELSTRA's Avatar
Oddometer: 106
+1 on part number. That is the Givi screen, right? Same as me. Do you end up with too little airflow ala RT or just less noise and buffeting?
R1200GS
"It's not a bike; it's a 2 wheeled Jeep!"
GELSTRA is offline   Reply With Quote
Old 07-13-2006, 06:00 PM   #4
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
Yup...Givi. I didn't get a chance to ride very long today but it feels like there will be enough of a breeze coming past the inner sides of the winglets to keep from being too hot behind them.
Barry
Old 07-14-2006, 12:38 AM   #5
Chacifer
sui generis
Chacifer's Avatar
Oddometer: 6,663
Neato. What I wonder is, will my Aux plug outlet that I have on the left side work with the wings? Hmmm.
Chace
Originally Posted by Jabba
I live in "Sport Mode"
Chacifer is offline   Reply With Quote
Old 07-14-2006, 03:44 AM   #6
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
Sure will, they have cutouts for plugs on both sides. The Adv. has the plugs in the same spot as the GS lite.
Barry
Old 07-02-2007, 10:55 PM   #7
FOREVER HANDSOME
FOREVER HANDSOME's Avatar
Oddometer: 263
Yes it will. I had an accesory plug put in there and I have winglets, lots of room.
cheers
Handsome
FOREVER HANDSOME is offline   Reply With Quote
Old 07-14-2006, 04:33 AM   #8
GSButter
Oddometer: 18
Barry
I have the same Givi on my gs and was about to try a new windscreen due to frustration with wind noise. This is a much more cost effective option. Many thanks for the tip.
Steve.....
'06 R1200GS
Katy, Texas
GSButter is offline   Reply With Quote
Old 07-14-2006, 05:10 AM   #9
GB
Mod Squad
GB's Avatar
Oddometer: 57,128
Excellent Barry! Thanks for posting.. It makes me want to reinstall my Givi screen just to get the winglets!
Old 07-14-2006, 05:31 AM   #10
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
Steve.....
I rode to work today so I got a chance to try it again minus the 30 mph wind we had yesterday and I was even more impressed today. AMAZING! It's hard to believe that these could make such a big difference in helmet noise but they sure do. I used to get a roar/crackling sound around the sides of my helmet and that is almost completely gone now. I always wear either earplugs or Etymotic earphones with my XM radio, haven't tried the earphones yet but they normally work better than earplugs so that should really be nice.
Barry
Old 07-13-2006, 05:55 PM   #11
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
Thanks Karl.
06327657966 screw .80 x 4
46612308594 washer .80 x 4
46637664846 bushing $1.60 x 4
46637694399 left wing $17.20
46637694400 right wing $17.20
Those are Chicago BMW prices. Took a few weeks for them to get them in.
You definitely want to get the hardware so they are spaced to sit off your bodywork a bit.
I figured if I didn't like them for whatever reason and took them off I will just find some small black rubber plugs to fill the holes but I don't see that happening now.
Barry
Old 08-24-2006, 12:28 PM   #12
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Thanks Karl.
Barry
Just got mine today and thanks for your part numbers; I have a minor concern. I was going to mount them with fender washers and nylok nuts but then started to think a bit. I am not a great fan of wellnuts, but thinking that wellnuts might absorb some impact should you inadvertantly hit one/bang it. Nahhhh, probably over-engineering the thing.
Anyone notice how they are mounted on the GSA?
jpalamar is offline   Reply With Quote
Old 08-24-2006, 12:56 PM   #13
mrmaico OP
mrmaico's Avatar
Oddometer: 1,706
Interesting, can't say I've ever seen a wellnut before. Might not be a bad idea but I don't know if it would really make a difference or not.
http://www.emhart.com/products/pop/wellnut.asp
Here's what the GSA mount looks like. Don't be fooled by the color, it's a repaint.
Barry
Old 08-24-2006, 02:40 PM   #14
jpalamar
jpalamar's Avatar
Oddometer: 3,080
Barry
My only thought for using the wellnut is so that the mount is a bit 'softer'. I'm nut a great fan of them but BMW does use them quite a bit on their cycles. Hopefully, using a wellnut would dramatically lessen the probability (I think) of a hard bang into the winglet and cracking the tupperware. The wellnut, appropriately torqued/tightened could preclude that. But then again, what would have been perhaps a 4-5 mm hole, the wellnut is a lot bigger. Probably take my chances without the wellnut.
Old 07-14-2006, 07:09 AM   #15
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 19,252
Nice job! You even have one of the ultra-fast and offroad capable blue ones like I have, so you are a man of keen intellect and sophisticated tastes.
Anyhow, my question is how did you determine exactly where to locate the holes?
Times are GMT -7.   It's 11:21 AM.
