Old 08-24-2006, 12:55 PM   #1
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Universal, one-size-fits-all penny-tech rear axle alignment tool
So while I was finishing up the brake DIY guide it dawned on me that although I’ve referred to a rear axle alignment gauge, I’ve never gone into much detail on how it works, how to make one or what it looks like… and I’ve never shown a photo of one.
OK... so it's not universal. The rod length will vary from bike to bike and it's of no value on a bike with snail cam adjusters like a DRZ for example... or a shaft drive anything. So I lied... so sue me.
What you need:
All you need to make one is a 35 cent piece of steel 1/8” welding rod... about 36" worth, and a zip-tie. For a total investment of what? 40 cents maybe. You can make this tool tricker and fancier... but I doubt you can make it cheaper.
Get at least 1/8" steel rod for this... smaller diameter or softer materials are too flexy and inaccurate.
Why you need it:
Rear axle alignment, with few exceptions, is usually only as accurate as the axle block and swingarm hash marks… which is to say not very accurate at all.
Rear axle misalignment can cause unstable tracking down a straight road, “odd” handling in corners, accelerated tire wear, brake pad wear and chain and sprocket wear.
How you make it:
Cut the rod to length so it is a few inches longer than the approximate distance from your swingarm pivot shaft center to the rear axle center… in the case of the KTM LC4, about 29-30” is fine.
Grind a point on one end of the rod and bend that end at a 90 degree angle. The length of this bend will vary from brand to brand, model to model, but the idea is to have the major length of rod parallel with the swingarm when measuring.
In the case of the KTM LC4, a handy length is about ¾”.
Now grab a zip tie, put it tight over the long end of the rod and cut the tail off short and to a point. Congrats… you have made a tool.
If you need to, you can make more complicated sets of bends to clear things that are permanently in the way. The drawing is an approximation of a tool for a '79 to present Harley-Davidson with a rubber mount driveline.
How it works:
On a KTM LC4, there are rounded plastic buttons in both ends of the swingarm pivot shaft and one on the fixed end of the rear axle… and then an aluminum axle nut.
It doesn’t matter which side you start on. You place the pointy end in the center of the plastic button on the swingarm pivot shaft...
... and slide the zip-tie so the pointy end of it aligns with the center of the axle… that is the "reference length" for one side.
Now you transfer the tool to the other side and see where the center of the axle is in relationship to the reference length.
Adjust that side of the axle (or both sides, more or less) until both sides measure the same distance by the tool, then using the current alignment as a baseline, readjust your axle for proper chain tension for your particular bike.
That's it... you done.
This is the "whole tool"... complete with blatant promotional background.
Small example of why alignment is a good thing:
It’s hard to believe, but with a 40 cent tool, you can get your axle aligned to an accuracy of less than one millimeter.
Can you screw it up? Sure you can... I did once recently because I wasn't paying attention, and my rear brake pads looked like this with a less than 2mm misalignment:
So there ya go,
C
creeper screwed with this post 08-24-2006 at 01:42 PM
creeper is offline   Reply With Quote
Old 08-24-2006, 01:12 PM   #2
MF1A
Ride with the Wind
MF1A's Avatar
Oddometer: 228
Send a message via MSN to MF1A
Hey Creeper , great info thanks dude
El MatiMoto
MF1A is offline   Reply With Quote
Old 08-24-2006, 01:13 PM   #3
Odysseus
Stoic Philosopher
Odysseus's Avatar
Oddometer: 4,154
Yesterday we get an awesome DIY brake guide, and now today this!! Creeper you are truely a gentlemen mechanic, thank you again.
Keep faith with our American heros:
Wounded Warrior Project www.woundedwarriorproject.org
Special Operations Warrior Foundation
www.specialops.org/
Odysseus is offline   Reply With Quote
Old 08-24-2006, 01:15 PM   #4
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
One kinda fell in line with the other... this took about an hour and half to do, so no biggie.
Hope it comes in handy.
Old 08-24-2006, 01:52 PM   #5
tedder
irregular
tedder's Avatar
Oddometer: 8,792
That is kinda cool.
I use the Motion Pro chain guide- it's something like $20, easy to use on any bike (even the DRZ).
tedder is offline   Reply With Quote
Old 08-24-2006, 02:40 PM   #6
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,843
What TDC-C is to valve adjustments, rear axle alignment is to drivetrain adjustment. (cut me some slack, it's not perfect)
Dotting all yer i's and crossing all yer t's - good man.
I will have to mate this with your brake DIY thread, since I note you snuck most of the adjustment method in a post about your tool. No wait, that came out wrong...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 08-24-2006, 02:48 PM   #7
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by meat popsicle
I note you snuck a post about your tool. No wait, that came out wrong...
Your thinking of Colin...
Old 09-27-2006, 11:06 PM   #8
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,689
Originally Posted by creeper
Elegantly simple, Creep.
Arch
Arch is offline   Reply With Quote
Old 09-28-2006, 04:13 AM   #9
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 11,659
THANK YOU!
All the esoteric straightedge parallel to the front wheel stuff aside, this will work just fine for me.
Now - how do you get the point on the welding rod? Do you have a metal compatible pencil sharpener? Just kidding.
Thanks,again.
Dave
dunno.....
Old 09-28-2006, 05:15 AM   #10
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
If you need to worry if your swing arm pivots are square and in line with the rest of your frame, you have too much time on your hands. If they are not in line and square, then who cares about adjusting the chain correctly 'cause you got other problems!!!!
Thanks Creep, I've made one of these alignment tools for myself and one for a friend. He was amazed at my inginuity. Na, I gave you full credit!
Techieguy
Reality does not always develop in a way we expect it to.
techieguy is offline   Reply With Quote
Old 09-28-2006, 03:34 PM   #11
MrH
Oddometer: 463
I've always checked the wheel alignment on my bikes with two straight 6' planks bungied either side of the back wheel, and then measuring the gap between the planks and the front wheel. This is very sensitive because of the distances involved - 1mm at the axle is probably equivalent to 5 or 6 mm at the front wheel.
In the UK there's a requirement for the wheels of a bike to be in line for the MOT test, I guess for reasons of safety, ie steering as well as tyre, wheel bearing and transmission wear.
MrH is offline   Reply With Quote
Old 10-01-2012, 04:21 AM   #12
turbodieseli4i6
turbodieseli4i6's Avatar
Oddometer: 273
Tagged for future reference!
1999 TW200, 2012 NC700X
turbodieseli4i6 is offline   Reply With Quote
Old 10-01-2012, 06:22 AM   #13
ihatefalling
Let it roll
ihatefalling's Avatar
Oddometer: 2,612
Pretty cool . . . . . . .thanks !
We gunna debitchulate you boy . . . .
ihatefalling is offline   Reply With Quote
Times are GMT -7.   It's 05:41 PM.
