Old 08-29-2006, 08:27 PM   #1
jimmy2020 OP
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 986
a better tire change solution. (KTM 950)
It can be a little pricey, but worth every $ to me. SOLUTION - Have WOODY'S build you a new set of wheels. I was always a little nervous of getting a flat in the middle of nowhere. Previously, I tried changing my front tire in my garage. Did it, but seemed very difficult under ideal conditions. I had read on this forum that the rear was worse.
Well, I dedcided to have WOODY's build me a new set of wheels using the stock hubs, super lace spokes, and sun rims. I also had them mill the bead to help make the tire change easier.
The payoff - this past weekend I had 2 REAR flats on the trail. I could not believe how easy it was to change the tube. Breaking the bead was simply done by putting my boot on it and stomping down.
If you want to ride with the confidence that a flat is not a big deal, then I suggest calling WOODY'S. This new setup is also MUCH stronger than the stock rim and spokes.
Cost was around $850. Worth it in the long run to me and the customer servive by Woody and Chris was fantastic.
Jim
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 08-29-2006, 10:01 PM   #2
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,482
Jim
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is online now   Reply With Quote
Old 08-29-2006, 10:11 PM   #3
Pointman0853
Unregistered Gun Owner
Pointman0853's Avatar
Oddometer: 1,495
Thumbs down Getting the boot...?
" Breaking the bead was simply done by putting my boot on it and stomping down."
If you think it comes off easy just using your boot, just wait until it loses air on the pavement at speed...
Hope you have good health insurance...
Pointman,
showing his sensetive side...
AMA Life Member 600475
IBA #5
CarsonMotorSports.com
Pointman0853 is offline   Reply With Quote
Old 09-07-2006, 07:08 PM   #4
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,467
machining bead
The great thing about the way we machine the safety bead is that we only do three inches each side of the valve stem. It allows you to break the bead for tire changes, but does not sacrifice the security that the safety bead provides at lower tire pressures.
In regards to stronger wheels, the rims alone are a much higher quality aluminum and the spokes and nipples larger and made of non-rusting stainless steel. Just thought I'd put my two cents in.
Chris
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 09-08-2006, 02:46 AM   #5
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
My spokes and nipples aint gone rusty and they're standard KTM ones(Euro 04) and yes,i live in rust central(UK).I ride all year round so they have stood up well.
I cant comment on the rims cos i aint bashed 'em!!
BLUE(UK) is offline   Reply With Quote
Old 09-08-2006, 05:00 PM   #6
JediBri
Glory to GOD
JediBri's Avatar
Oddometer: 501
Originally Posted by woody's wheel works
Chris
I'll be contacting you guys about a set of wheels for my Super Enduro
Brian
currently rideless...
JediBri is offline   Reply With Quote
Old 09-08-2006, 06:16 PM   #7
barko1
barko1
barko1's Avatar
Oddometer: 3,416
Why not go Tubeless?
DR650, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), Triumph Thunderbird Sport, Triumph Daytona Super III, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 09-09-2006, 11:31 AM   #8
TipOver
TipOver's Avatar
Oddometer: 405
Durability
Most offroad is done with tube tires. Bend a rim to the point it will not hold a good bead (to retain air) & you get a long walk. In the desert or the mountains that can also be a dangerous long walk if you are by yourself.
TipOver is offline   Reply With Quote
Old 09-09-2006, 02:13 PM   #9
barko1
barko1
barko1's Avatar
Oddometer: 3,416
Good point, I may be more likely to run over a mesquite bush than bend a rim so tubeless might be better for me.
Times are GMT -7.   It's 08:49 AM.
