Old 09-17-2006, 04:35 PM   #1
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
640 Adv / CS Sprocket / Loctite ?
I'm replacing the cs sprocket on my 640 Adventure tonight and I have one very simple question I need answered...
The manual calls for Loctite 243 to be used, however, I was unable to find 243. I found 242 and I also have some 245, but no 243.
Will the 242 be good enough?
Forgive my Loctite ignorance...I am not totally sure what the difference between the 242 and 243 is. Seems the 243 is more 'oil resistant' ??
I did the requisite searching and found a few people with similar questions, however, they were for shocks and such, nothing near the CS. :(
Any help would be greatly appreciated.
-- Jason
nyc_gs is offline   Reply With Quote
Old 09-17-2006, 05:21 PM   #2
2whlrcr
gooligan
Oddometer: 6,386
I've used blue Loctite with no problems. Can't remember the number?
2whlrcr is offline   Reply With Quote
Old 09-17-2006, 06:03 PM   #3
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
Blue
The 242 and 245 I have are both blue. I believe the 243 is blue as well.
I'm assuming that red is not what would be wanted for this particular application...but I am certainly no expert with loctite...hence my asking. :)
-- Jason
Old 09-17-2006, 06:23 PM   #4
BlackTalon
KTM
BlackTalon's Avatar
Oddometer: 47
Hi Jason, concrats on your new bike. I just replaced my front sprocket seal and I used 242 with no problems. 242 is a lock and seal . I have it left over from making a fuel cell and I have been useing it as regular locktite with no problems.
Later, Joe
BlackTalon is offline   Reply With Quote
Old 09-17-2006, 07:10 PM   #5
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
Later, Joe
Joe...thanks much man. I was hoping someone could tell me that. :)
The ride you guys had in Idaho looks awesome. I'm really jealous!
Thanks again!
-- Jason
Old 09-17-2006, 08:14 PM   #6
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,235
I would strongly recommend that you replace the CS sprocket bolt and it's spring washer when replacing the CS sprocket - consider it a consumable part. Although you might get away with reusing them, for the price it is not worth the risk. They are sold together:
CS sprocket bolt and spring washer P/N 590.33.034.044 $4.25
Discussion linked HERE.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 09-18-2006, 07:30 AM   #7
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
The index
Meat...
Thanks...I have read that other posting about 100 times already to make sure I knew what I was getting into. :)
I actually ended up not replacing the sprocket as I decided to wait for the parts you mentioned.
I did take the cover off last night with plans to replace it, however, it seems there is a tabbed washer of some sort behind the nut. One side folded over to help prevent the nut from backing off. Looks like I need a replacement for that washer before I can even think of taking that thing apart.
It looks like the tab is only possible on one side of the nut...does that make sense?
I was expecting to be able to re-use the nut/etc as the bike is only 3 weeks old with 600 miles on it...
It is going to the dealer tomorrow for it's 600 mile service, so I may just have them do it while it's there...hate to pay to have someone else do this type of thing though. I even went out and bought a torque wrench just for this!
Thanks for the pointer though...the lc4 index is awesome, one of my favorite places on this site since buying my new 640. :)
-- Jason
Old 09-18-2006, 08:14 AM   #8
Yukoner
Motorcycle Addict
Yukoner's Avatar
Oddometer: 82
For your peace of mind I recommend cutting a hole through the cover and marking a paint line on the nut and shaft.
You may be reluctant to take a hole-saw to your new bike but you can clean up the hole nicely with sandpaper.
Yukoner is offline   Reply With Quote
Old 09-18-2006, 08:22 AM   #9
meat popsicle
Ignostic
Oddometer: 14,235
Meat...
-- Jason
Ah, so you were on top of this. I am not sure what version of the CS bolt/washer your model year has; sounds like the older one that folks talk about so I am surprised to hear it is on your almost new bike.
That said, why do you have to REPLACE the sprocket after only 600 miles?!? I could imagine you might want to exchange for a different tooth count - but is the stock CS sprocket already fried? If you are only exchanging the sprocket then I would expect you to be able to reuse the bolt/spring washer combo (w/loctite) for a spell, but I have no idea about the tabbed washer. BTW, did you see the loctite thread in the index?
You can still do the drivetrain work, just have the dealer order the parts for you. Speaking of which, you don't want to do the valve adjustment/oil change/general inspection? It is challenging, but not impossible for those with decent mechanical aptitude and wrench experience.
Old 09-18-2006, 08:39 AM   #10
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
Smaller
Not sure...I have tried to find a photo of what it looks like but have not yet found one. Perhaps I'll go take a photo of it tonight and post it. The bike is an '06 that I purchased new about 4 weeks ago.
I'm just replacing the 16t sprocket with a 15t sprocket. :)
I found a few about loctite...but I'll go and check the index again.
The biggest challenge for me is that I live in NYC. It's a bit hard to pull all that stuff apart in the basement of the garage I'm in. :(
Plus...doesn't KTM void your warranty if you do this stuff yourself during the warranty period? I thought I read something about that in my manual.
-- Jason
Old 09-18-2006, 10:01 AM   #11
meat popsicle
Ignostic
Oddometer: 14,235
-- Jason
J,
I am not familiar with the tabbed CS bolt washer - hopefully someone with experiece will speak up. But for the price, I would just get another one: peace of mind is worth more than $5.
KTM cannot void your warranty due to limitations imposed by the Magnuson-Moss Act. They can't tell you where to maintain your bike. Just search for it here in Thumpers and on Google; it's come up before. Pretty sure you can even maintain the bike yourself and make warranty claims provided you keep adequate records of your work.
Old 09-18-2006, 11:44 AM   #12
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,959
Loctite Guru Checking In...
NYC GS- I'm Adventure Rider's resident Loctite Factory Rep working out of south Louisiana.
243 is an oil tolerant medium strength blue threadlocker. When I say "Oil Tolerant" I'm not talking about the material's ability to stand up to oily environments when inservice. Any cured threadlocker does this, so there's still nothing special about it. When Loctite says 243 is "Oil Tolerant" we are referring to the materials ability to work and cure properly on "As Received" threaded fasteners that are already lightly oiled to prevent rust. 243 isn't as picky when used on slightly oily threaded fasteners as 242, 248, or 2440.
I don't know about everyone else, but I won't paint car with oily handprints on it because surface prep is king. Most any of us would remove all surface contaminates before we paint a car or reinstall a bolt if we're working in our shop.
In short, always clean and degrease fasteners before reassy.-especially if we're using a threadlocker. Use 242, 243, 248 (the Stick), or 2440 (Primerless). They'll all do the job-each with a different twist.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 09-18-2006, 11:52 AM   #13
nyc_gs OP
Lurker
nyc_gs's Avatar
Oddometer: 241
Sweet
Dirty
Sweet. That is excellent information and I really appreciate it.
I can feel a little better about the 242 now!
THANKS!
-- Jason
Old 07-12-2008, 05:20 PM   #14
Totally pinned
Oddometer: 6
Wink Loctite
-- Jason
I'm a licensed mechanic, use a good slather of Blue medium strenght and fold the lock coller tight and your good to go!
Totally pinned is offline   Reply With Quote
Old 07-12-2008, 07:33 PM   #15
KTMax m AL
Fagarwe tribal member AL
KTMax m AL's Avatar
Oddometer: 303
Thumb Stock gearing
nyc gs
You may find in time that you switch back to the stock 16 gearing.
I changed mine to a 15 tooth for about a year and then went back to the 16 tooth. The 16 works much better if there is any open road riding and I have done some tight off road with this 640 torque monster and it's not much of a problem.
JMHO
KTMax m AL is offline   Reply With Quote
Times are GMT -7.   It's 03:05 AM.
