Old 10-25-2006, 05:16 AM   #1
boother OP
Oddometer: 227
Factory lowering a DR650
Has anyone performed the factory lowering themselves. Looking at the service manual, it does not look difficult. There are several special tools listed but the only one I think you would have to have is the "T-handle" to loosen the bolt down in the forks. Can anyone tell me what that tool really is? What is on the end of it? Square drive? Torx? PN 09940-34520. The rest of the "special tools" look like I can find an alternative.
boother is offline   Reply With Quote
Old 10-25-2006, 06:46 AM   #2
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,576
Thumb
I did it for my buddy last week and I'll be doing it to my new to me '05 DR650 that I pick up tommorow.
I have a 1/2" x 1/2" x 20" piece of square steel rod that I tapered on one end and it works great. Sure you could buy the Suzuki special tool but mine works on any damper rod type fork and yours could too.
I've also made one by grinding down a 1/2" drive impact extension. Just use a damaged or cheapie 1/2" drive impact extension and grind the part that goes into the socket down to a tapered end. I've heard of people using broomsticks but I've never tried it myself. Easy and cheap enough to try if you dont have any other materials available.
Loosen the top fork cap before you remove it in case you dont have a vise.
Remove the fork leg from bike, then try to loosen the bolt (8mm allen) on the very bottom of the fork. This bolt holds the damper rod in place. It might come loose with the tension of the fork spring holding the damper rod but dont count on it, there isnt very much tension in these forks.
If the lower bolt just spins & spins but doesnt start coming out, then remove the upper fork cap, preload spacer, washer, then fork spring. Lay those to the side on a clean surface then dump out the fork oil. Now it's time to stick whatever tool you fabricated down the fork tube into the damper rod and your tool will hold it in place while you remove the 8mm damper rod screw. Pretty easy.
Now if you're going to lower the front, slide the top out spring off the damper rod. Take the preload spacer you remover earlier from the top and slide it onto the damper rod. Now put the top out spring back onto the damper rod. Insert your fabricated tool into the damper rod and slide it back into the fork. Attach & tighten the damper rod, then fill your forks with fork oil.
I used ATF and filled it 5 & 1/2" from the top of the tube with the fork fully collasped. This was purely experimental and works great according to my buddy who owns the DR I'm talking about. Use whatever oil you prefer, and what fork oil height suits you.
Extend the fork, drop the spring in, then the washer & cap it off. Done. Now you get to do it to the other side.
Note: you can add another preload spacer, or washers for additional preload if you wish. I added 3 flat washers I had laying around. That was maybe a 1/4" of additional preload.
My buddy says the front feels great, and it made the soft rear that much more noticeable.
Lowering the rear is easy enough, choose the bottom bolt hole on the lower shock mount. If it's not low enough, remove the shock, remove all the preload from the shock spring, remove the spring, then remove and flip the shock spring seat and this will provide you with the complete Suzuki lowering option.
Dont forget, you're going to need a shorter kickstand. I cut 2" of it and had it welded back up. Works great.
HTH
Lil' Steve is offline   Reply With Quote
Old 10-25-2006, 07:19 AM   #3
boother OP
Oddometer: 227
So it is a square drive tapered down from about a 1/2". Cool! Thanks from the help.
Old 10-25-2006, 07:44 AM   #4
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 4,445
If you have an air impact wrench you can normally spin the bolt out of the bottom of the fork tube without having to use a tool to hold the dampner rod.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Old 10-25-2006, 11:15 AM   #5
FatChance
Road Captain
FatChance's Avatar
Oddometer: 9,322
Just move the fork tubes up about an inch in the triple clamps. Much more easier.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 10-25-2006, 11:31 AM   #6
street rider
Grow old not up
Oddometer: 283
I slid the fork tubes up an inch and 1/4, changed bolt holes on the rear then added Suzukis lowered gel seat. I'm short and it worked great. It was easy too.
His 05 FLSTNI, 08 FLHTCU,
Hers 08_FLHTCU, 12 Burgman 400
Ours,11,G650GS
Project 78 FLH
Before you can be old and wise you must first be young and foolish, and live thru it.
street rider is offline   Reply With Quote
Times are GMT -7.   It's 07:14 PM.
