Old 05-15-2003, 11:09 AM   #1
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
Penny Tech Panniers
Tired of high prices for panniers? These do the trick at around $100 a pair. These are Merimite Food Containers courtesy of good old Uncle Sam.
The finishers medal is satisfyingly heavy...
Neduro on Dakar
The other 10% are sociopaths , serial killers and KLR riders. You wont get much sympathy from them.
-Furious D
pilot screwed with this post 02-05-2010 at 07:16 AM
pilot is offline   Reply With Quote
Old 05-15-2003, 11:11 AM   #2
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
more
This is what you get. They come with these annoying inner cans. If anyone knows what to do with these, let me know.
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:17 AM
Old 05-15-2003, 11:16 AM   #3
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
cans
Give these away if you can.
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:18 AM
Old 05-15-2003, 11:19 AM   #4
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
cut here
Remove the gasket and cut here all the way around the liner with a sabre saw.
Neduro on Dakar
-Furious D
Old 04-08-2005, 10:25 PM   #5
RealpolitiKLR
RealpolitiKLR's Avatar
Oddometer: 2
Gasket question
Will the gasket still seat itself well without that inner lip to snug up against?
-RealpolitiKLR
RealpolitiKLR is offline   Reply With Quote
Old 04-09-2005, 10:35 AM   #6
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,113
Send a message via MSN to Surly
-RealpolitiKLR
I think they will as its downward and not inward pressure
I chose to leave a portion of the alum liner on my bags however
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 07-10-2005, 07:13 PM   #7
RLK
4,949
RLK's Avatar
Oddometer: 6,005
More on Mermite
I grabbed one mermite can to convert to a top case. The can I got looks like it has already had a hard life. I have found 4 holes in the outer case but I didn't find them untill I ripped the inner can out. The insulation had already fallen off the inside and was all laying in the bottom.
I'd not reccomend buying a surplus Mermite online or mail-order. Before you buy, inspect it carefully.
SmugMug is taking its sweet time with my pictures but i'll post them and explain what I found in my can ASAP.
It takes less time to do things the hard way than to be too nervous to even start at all.
-Juanito on the Yahoo!
RLK is offline   Reply With Quote
Old 07-10-2005, 08:13 PM   #8
RLK
4,949
RLK's Avatar
Oddometer: 6,005
I started by taking an angle grinder to the inner liner, about an inch below the lip, thinking that leaving the top inch of metal would help hold the gasket in place. After prying out the inner part, I found all of the insulationlaying loose in the bottom.
I don't think its supposed to look like this:
Removal of the insulation was a snap. It all just dumped out. What was left came out with a dish scrub/sponge and plain water. After It was clean I found holes in the bottom.
In the bottom, the insulation has 3 "bars" (for lack of a better term) of more dense insulation. They are located where the metal appears more greyish in this picture.
In the center, that's a blade of grass sticking up from below. Two more smaller holes are visible, kinda left-center. Not visible is a small hole in the seam between the end wall and the floor and another pinhole on one end wall, below the handle.
While I was working on it, the top inch of the inner liner that I wanted to leave just kind of fell out.
As a temp. fix I just duct taped over the holes and all around the floor seam. Hopefully that will keep it somewhat water resistant for a while.
I didn't encounter any rain over the first weekend out with this thing but I hold little hope for its long term road-worthyness. Hopefully I can get my $12.50 out of it.
Here's how I set it up. Go ahead and laugh, I know its rediculous.
Its double ratchet-strapped to the subframe, not just bungeed. The bungees are for redundancy
All I can say is, INSPECT YOUR CANS CAREFULLY BEFORE BUYING.
RLK screwed with this post 07-10-2005 at 08:19 PM
Old 05-15-2003, 11:22 AM   #9
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
remove liners
Next cut the liner in half lengthwise. I used an angle grinder. This is the worst part of the whole process. Then pry, cuss, pry, and pull these out of the boxes.
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:19 AM
Old 05-15-2003, 11:28 AM   #10
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
remove insulation
You then have to remove the insulation from the inside of the can. I used a putty knife to scrape all the foam out starting about an inch down from the fiber gasket surface. I left the top inch in to support the gasket surface. I then painted the interior with truck bed liner in a can. Use plenty on the foam at the top.
Next is the latch and mount. I used eyebolts from Airparts for the lock hasp. Drill and cut out the tab to allow the eyebolt to pass through. The Happy Trails mount bolts on the back. Two more holes at the top for the hold on bolts and your through.
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:20 AM
Old 05-15-2003, 11:31 AM   #11
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
completed latch
Here is the completed latch.
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:21 AM
Old 05-15-2003, 11:32 AM   #12
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
mount
This is the Happy Trails mount.
Neduro on Dakar
-Furious D
Old 05-15-2003, 11:36 AM   #13
pilot OP
Slacker
pilot's Avatar
Oddometer: 29,536
rear view
Here is the rear view of the bags on the bike. This is the setup I used through Mexico and Guatemala this winter. Lots of room, water tite, secure, and quite ugly to match the KLR.
You don't have to worry about trashing a $1000 set of boxes if you fall over. I didn't crash test them yet, so I don't know how well they hold up to abuse, but for the money, who cares?
Neduro on Dakar
-Furious D
pilot screwed with this post 02-05-2010 at 07:23 AM
Old 05-15-2003, 11:38 AM   #14
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Re: cans
Said pilot:
You can make a pine cone stove out of those. Or a parts container. Or stuff your tool roll in there to keep the greasy bits off your shaving kit. thousands of uses
dead
Chopperman is offline   Reply With Quote
Old 05-15-2003, 11:42 AM   #15
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,606
Send a message via Yahoo to Ricardo Kuhn
Exelent Work,,actually those bags are Perfect size
Love the care you took to explain the whole thing.
I thank you in the name of everybody,that belive in autonomy, I love the felling of creation....
Great JOB
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Times are GMT -7.   It's 10:58 PM.
