Old 01-14-2007, 07:42 AM   #1
KTRMN8R OP
Sand Camel
KTRMN8R's Avatar
Oddometer: 1,217
Clean the oil jet for clutch lubrication.
How's everybody? I see in the 2006 950 Adventure Owner's Manual,... under Periodic Maintenance Scheadule, beside engine checks "Clean the oil jet for clutch lubrication." Does anyone have a Factory Maintenance Manual pictures of this process? I have seen the recall thread on oil jets, but as I understand reading that recall,... those jets are specific to the engine itself (ie: rotating assembly lubrication). Any help here would be much appreciated.
God Bless & Godspeed!
KTRMN8R is offline   Reply With Quote
Old 01-14-2007, 12:39 PM   #2
K2m
....58....
K2m's Avatar
Oddometer: 2,239
That will be the oil jet above the clutch slave- chain guard. A tiny little jet. mine was blocked. After unscrewing use a vacuum to remove it.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 01-14-2007, 12:42 PM   #3
scottr
scottr's Avatar
Location: Pedernales R., Tx Hill Country (Ihadthisavatar1st)
Oddometer: 1,768
scottr is offline   Reply With Quote
Old 01-14-2007, 01:49 PM   #4
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
Thats the first I have heard about this!! How often should one do this?
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 01-14-2007, 03:43 PM   #5
KTRMN8R OP
Sand Camel
KTRMN8R's Avatar
Oddometer: 1,217
According to the '06 Owners manual, under PMS on page 20, 1st service after 1,000km and every 15,000km or every two years.
Old 01-14-2007, 04:26 PM   #6
figurehead
Bring It On
figurehead's Avatar
Oddometer: 34
The oil jet IS internal and you have to take off the slave cylinder to get to it (as well as removing the chain/case guard).
The part number given above is correct and it is shown on the “engine case” page in the engine parts manual as #29.
'09 KX450F
XR "100" dirt tracker
figurehead is offline   Reply With Quote
Old 01-14-2007, 05:37 PM   #7
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
Dam I am calling my dealer in the morning they did not do that at the first service or the second when I had it in for the valve check. I sat and watched both times.........sonsabitches~~~ I do see that it is in the owners manual on pg 29 for the 07 950SE. I overlooked that damit!!!! After looking at the maintenance schedule they only performed 4 out of 16 things that it says to check at the first maintenance. I'll do my homework next time and take a list with me!!!
Thanks for bringing this to my attention KTRMN8R
Old 01-14-2007, 02:05 PM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
The oil return jet.
You should be refering to part No 600.38.029.000. In order to pull it out though you could use a screwstarter for flat screws, or the vac cleaner as mentioned above!! I wonder if increasing the hole to a 0,5mm would be a good idea? More oil and less prone to blocking.
Old 01-14-2007, 04:17 PM   #9
KTRMN8R OP
Sand Camel
KTRMN8R's Avatar
Oddometer: 1,217
Hey Gefr, how goes it? any pics of said part?
Old 01-15-2007, 05:27 AM   #10
K2m
....58....
K2m's Avatar
Oddometer: 2,239
No. Never do this...... You will not be able to get it in to neutral with the engine running !!!!!!!
Old 01-15-2007, 11:14 AM   #11
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
I am actually running it with the 0.5mm hole.
Neutral is O.K. The problem on mine has never been too much oil. I guess there was too litle oil until the TSB was carried out and so the damage was already done. Anyway after my clutch steel (?) disks and lining disks have been replaced, under warranty, together with the clutch booster, everything works as never before.
Old 01-14-2007, 04:22 PM   #12
KTRMN8R OP
Sand Camel
KTRMN8R's Avatar
Oddometer: 1,217
Old 01-14-2007, 03:40 PM   #13
KTRMN8R OP
Sand Camel
KTRMN8R's Avatar
Oddometer: 1,217
So, if I am understanding this correctly; you are saying,... an Oil Jet in KTM language is refering to the bleeder screw on top of the clutch slave cylinder??? If so,... mine has a small grey protective "rubber booty" on it and it is clean inside. For some reason I was thinking that this"oil jet was internal, as it follows the clutch lining inspection and clutch pressure booster system checks on the '06 model PMS?
Old 01-25-2007, 05:58 PM   #14
tkorpi
Oddometer: 130
How tight is this jet supposed to be?
I just slapped a 16t on my 950 SM and figured I'd clean out that oil jet by the clutch. How tight is it supposed to be? I gave it a bit of force and it didn't budge and I didn't want to go overboard. Is there a secret to this thing?
2006 KTM 950SM
tkorpi is offline   Reply With Quote
Old 01-26-2007, 08:48 AM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,000
It is a slotted screw, made of bronze...
with a deep cut. Good luck.
gefr screwed with this post 02-08-2009 at 08:46 AM
Times are GMT -7.   It's 01:17 AM.
