Old 04-17-2007, 02:03 PM   #1
losiu OP
wheelie addict
losiu's Avatar
Oddometer: 577
LC4 640 starter clutch fix
First of all, I’d like to thank Beez who inspired me to do the work described below. Based on his description of the problem which he had posted on an e-starter thread, it sounded like the same problem I had been having:
Originally Posted by Beez
I had the starter clutch go on my '97 620. Kicked it for a couple of years before I finally got it fixed. I've heard this problem many times here and on KTMtalk so it seems to be a weak point on LC4s. If this is your problem the starter will turn fine but you will hear a loud, horrible KLaaccKK! KLaaccKK!
He also sent me an interesting PM in which he told me that, supposedly, the starter clutch could be fixed with the right sized spring from an O-ring seal.
Let’s get to work then !!
DISCLAIMER:
I am not a professional mechanic nor do I have the repair manual for LC4s. I did this based on my experience working on the LC4s I’ve had (and some luck).
The tools needed to do the work are very basic. There are two things that I can think of that are an absolute necessity to do the work right: beer and the flywheel puller.
The first one is probably readily available where you are. The puller might be a little harder to get. I was lucky because my buddy had one made for him when he was rebuilding his engine. He kindly lent it to me and I can tell you right now that if you don’t have this particular tool, it is probably impossible to do the work.
No.7 on the diagram below is the part you need to get to.
1.You have to unscrew the flywheel cover (with the stator inside) on the right.
It’s a good idea to find the TDC and then take out a bolt from the front of the engine to lock the crankshaft in place. In order to do that, you need to take off the thick washer that sits on this bolt, and screw the bolt back in. You might need to try a few times moving the crankshaft back and forth a little to hit the right spot. When the piston is in TDC, the bolt goes right in and locks the crankshaft in place.
2.You don’t have take anything else off at this point. I was doing it for the first time and to make sure I was doing the right thing, I took the e-starter out and basically, the whole right side of the engine (this is NOT necessary to do the repair). It’s at this stage that you’ll need the puller.
3.When the flywheel is off, you’ll notice another “wheel” attached to it with 6 screws. Again, I took it apart to take a closer look but it doesn’t need to be done to get to the faulty part.
If you turn the flywheel over, you’ll see this:
4.You need to use pliers to get the starter clutch out. It looks like a kind of bearing at first, but when it’s pulled out, it looks like this:
5. What you see above are irregular shaped metal blocks held in place within a metal ring by a spring. The spring was so loose that one of the metal blocks slid out of its place and looks like it's missing.
Put the whole thing flat on the table to take off the spring without losing the metal blocks. You also need to make sure that the blocks don’t turn in any way when you put the new spring back on.
6.You can see that this spring has seen better days.
7.This was the cause of the starter clutch “slipping”. The metal blocks couldn’t lock the crankshaft together with the free wheel which is spun by the starter engine. The slipping created the grating sound described earlier by Beez.
Here a problem occurred. Based on my information, the possibility of replacing the worn out spring with a spring taken from a large rubber O-ring seal was only a theory which proved to be a little trickier than expected.
8.All the springs pulled out of the rubber O-ring seals that were more or less the right size in diameter, were too thick to fit in the groove around the metal blocks. The spring has to kind of hide inside the groove and if it doesn’t, it won’t fit back in the engine. Basically it needs to be just the right size. I have no idea what diameter the original spring is when it’s new because mine was all stretched out. This element, the metal blocks and the spring, is sold as a whole unit and costs around $80. You can’t buy just the spring.
9.I got 3 rubber seals and measured the springs. The first one was clearly too thick.
Here's a pic of the one that was originally in the starter clutch:
This one turned out to be too thick:
10. I finally managed to get a seal made by a company called "ERIKS” whose measurements are 50 x 72 x 7.
The thickness was right but the diameter seemed a little small (50mm). I decided to put it in anyway because the old spring didn’t work at all and I really had nothing to lose by trying.
It worked fine and the starter works great with no weird grating or KLaaccKKing sounds.
From this point, everything is easy – put it all back together in reversed order and start your bike
Here's what my e-starter sounds like after the repair.
The engine was cold and I used no choke in order to let it work for a while.
Does it sound healthy or what ????
The total cost of the repair is probably around $15 ($2 for the rubber O-ring seal and $13 for the beer)
It's also worth mentioning that the work can probably be done within 2 hours if you have the right spring :)
Good luck :)
Losiu
KTM 690 R - The new wheelie weapon
Husqvarna TE 250 - The little beast
Husqvarna 333R - The ...umm..... how do I put it....
losiu screwed with this post 04-18-2007 at 05:20 AM
losiu is offline   Reply With Quote
Old 04-17-2007, 05:11 PM   #2
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,565
Very good post, great description and many pix. My junk was a bit different. Just put in a new starter ($250). I hope I never have to kick again.
Guns keep society safe.
Colemanfu is offline   Reply With Quote
Old 04-17-2007, 08:45 PM   #3
DC950
Microadventurer
DC950's Avatar
Oddometer: 2,897
I'm bookmarking this one. Thanks Losiu!
God. Family. Motorcycles. Guns. Music. Books. Dogs. Beer. Baseball. Work. That about covers it.
DC950 is offline   Reply With Quote
Old 04-17-2007, 10:50 PM   #4
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,177
Great post, but a word of caution: On LC-4 engines with the Kokusan 4K-2 ignition it is recomended to use a flywheel holding device rather than the crank locking screw to tighten the flywheel nut. The 120 LBS torque required could damage the crank web. It's ok to use on the LC4s that only require 44lbs torque on the flywheels.
gunnerbuck is offline   Reply With Quote
Old 04-18-2007, 05:25 AM   #5
losiu OP
wheelie addict
losiu's Avatar
Oddometer: 577
Thumb
Thanks for making this clear. When I bought this bike it needed much more work done than this. Right now it runs almost perfectly but because it required work in general, I was not afraid to do this repair.
I did worry about locking the crankshaft in place using the bolt because it's on the other side of the engine. I looked for many ways of locking the crankshaft but I failed to unscrew the nut. After locking the crankshaft with the bolt it turned out that the flywheel nut wasn't that tight.
I tried to be careful putting it all back together and the bike runs great but I agree that it's always good to have the right tools.
Thanks for bringing it up here :)
Losiu
Old 04-18-2007, 06:12 AM   #6
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,473
Good write-up.
I'd like to nominate this for the index. I have already "subscribed" to it, just in case.
NICO is offline   Reply With Quote
Old 06-26-2008, 01:49 AM   #7
drtwiggy
Oddometer: 3
I just ordered a 19993 seal from Rocket Seals and I am searching for a place to buy the fly wheel puller. Any suggestions?
How do I tell if I have the Kokusan or SEM ignotion? Seams like I could do some damage if I have the Kokusan. Mine is a 1997 lc4 egs-e.
Finally is it a good idea to get a replacemt gasket/o-ring (which is it?) for the fly wheel cover?
ciao.
drtwiggy is offline   Reply With Quote
Old 07-05-2008, 04:24 AM   #8
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,561
Alright, I attempted this job and got stumped: couldn't undo the flywheel nut.
My bike is an '05 EU/AU model. The book says 150Nm for the flywheel nut = 110 lb.ft. The crankshaft locking screw is listed with a torque value, but it only has a normal thickness washer. I tried using another 5mm longer M8 bolt, but it didn't engage with anything even when fully screwed in. The crank would still turn freely.
How do I know which variant of Kokusan ignition is fitted? The specs in my books don't say.
So, how the heck do I stop the crank from rotating? I tried putting the bike in gear and standing on the rear brake pedal, but it would slip with a fair pressure applied... I suspect that's the clutch slipping? Do I need a clutch holding tool? What's this flywheel holding you speak of, gb?
Toys <------------------> Cot
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 07-07-2008, 07:19 PM   #9
jonz
Miles are my mantra
jonz's Avatar
Oddometer: 2,355
I used an impact gun and it came right off.
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is offline   Reply With Quote
Old 07-24-2007, 06:42 PM   #10
goatherder
Wondering WTF?
goatherder's Avatar
Location: Olympia, WA, or the Aleutian Islands & Bering Sea
Oddometer: 46
Just fixed mine and heres the repair part#
SKF Seal # 19993. Cost me $8 and the spring fit perfect. Starter works like new now. Drove the bike to European Motorsports in Spanaway and gave them $10 to remove the flywheel for me. Nice guys at that place.
So the starter works like new, and I did the fix for $18 + the fuel to drive to their shop. I didn't use a gasket...just loctite sealer to glue the stator cover back on. Time will tell if it works.
But fer now I'm happy as a pig in shit.
"Do what thou wilt" - Aleister Crowley
2001 KTM 640 LC4e
goatherder is offline   Reply With Quote
Old 07-25-2007, 05:50 AM   #11
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Heya loisu,
you are turning out to be a handy fella - more than just wheelies! looks good to me; the only question I have is if the spring wears out, and KTM doesn't sell just it, how long until the irregularly shapped metal blocks wear out? could you see wear and tear on them?
thanks for the nominations folks. now that I finally have some time again I will be attempting an update, although reorganization may be in order due to the post size limit...
MP
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 07-26-2007, 12:07 AM   #12
losiu OP
wheelie addict
losiu's Avatar
Oddometer: 577
Hey Meat,
I don't really see the problem with the blocks. YOu can see that they've done some work but as long as they keep the right shape they're OK.
The whole unit (part no.7 in the diagram at the beginning of the 1st post) costs less than $100. The reason you might want to do the repair using a spring from a seal is to save $90 for beer or to avoid having to wait for the new starter clutch.
I have to tell you that there was another KTM in Poland that has been fixed using this info and it works great. Maybe I'll get the guy to post here. Mine has been working great ever since the repair. I think it's a good way to go.
Cheers,
Losiu
Old 08-22-2007, 03:09 PM   #13
pawel
KTM SuperMud
pawel's Avatar
Oddometer: 5
it woked ok for me
hey,
as losiu was mentioning, I was having exactly the same problems with my clutch starter, and thanks to this post I was able to fix it by own spending few $ for the spring
below I am attaching few photos:
- after taking out flywheel, clutch was totally destroyed,spring was broken and those small stones was everywhere
- I realized as well that flywheel is little bit demaged, and 'stones' are not having initial/oryginal shape
but finally I have decided not make anything with flywheel, and stones, I have replaced clutch spring only, mounted everything back and till now(more than month, I am ridding almost everyday) it works fine!!!
losiu, thanks for this post and help
pawel
pawel is offline   Reply With Quote
Old 08-31-2007, 05:45 PM   #14
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 755
um......
When doing this are you guys draining all of your motor oil ? or just losing whats whats behind the cover and toping off?
CRW is offline   Reply With Quote
Old 01-05-2008, 08:15 PM   #15
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,903
Thanks Losiu & Goatherder! I think this will be the cure to my problem.
Cheers!
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Times are GMT -7.   It's 09:46 PM.
