Old 04-20-2007, 09:38 PM   #1
Stretch67 OP
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,540
SW-Motech Mounts on a Tiger Tank Bag
I recently picked up a Triumph Tiger tank bag off eBay. I love the bag (nice medium-size, but expandable to Huge. Lots of pockets, clear map pouch, a pocket that zips-off into a fanny pack, rain cover, etc.), but didn't like the attachment system.
The bag quickly attaches and disconnects from the base pad with nylon quick-release buckles, and several square inches of velcro keep the bag from shifting around on the base pad.
The foam and nylon base pad is secured with 1-inch nylon straps and buckles. It's not permanently-mounted, but it may as well be. You have to remove the seat to thread the straps into the frame, and it's also a pain in the keister to secure the front of the pad.
If it's that much of a pain to remove and re-install, I can see that I probably wouldn't remove it often to clean under it, and the paint on my tank would suffer for my laziness.
There has to be a better way.
Enter SW-Motech's gascap ring mounting system.
I like this system, but not their bags (very few have a see-through map pocket), so I decided to use the SW-Motech mounting system on my Tiger bag.
I made this base plate from .125 aluminum. The box on top is so that I can recess the mount, allowing the base plate to sit as low as possible.
The underside...
Painted, with bag attachment hardware and velcro...
The finished product installed...
The SW-Motech parts are:
RAM base, part # TRT.00.475.225 $38.00
Triumph Gas Cap Ring, part #TRT.00.475.160 $25.00
http://www.twistedthrottle.com/
Twisted Throttle Ltd
1080 Kingstown Road, Building 2
Peacedale, RI 02879
Phone: 401-284-4200
Fax: 707-922-7276
Office Hours
9:30 AM - 6:30 PM (Eastern Time), Monday - Friday
6:30 AM - 3:30 PM (Pacific Time), Monday - Friday
Cupholder, made from a scrap of one-inch aluminum and a plastic Jif peanut-butter jar.
Cupholder installed...
I use a 20-ounce Coca-Cola bottle because they're more slim than others. I drilled a hole in a cap and made a non-disposable straw from a sixteen-inch length of plastic tubing. I bent the end into a 90-degree mouthpiece so I can slip it under the chin guard of my full-face helmet.
The insulator is a neoprene beer bottle sleeve. I have it attached to a retractable key ring. I once lost one of these on the road when a truck passed me and the wind gust blew the bottle out of the cupholder. So now I have a retractable lanyard.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 01-15-2008 at 02:45 PM
Stretch67 is offline   Reply With Quote
Old 04-20-2007, 09:47 PM   #2
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
You're my new freakin idol Stretch
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 04-21-2007, 03:36 AM   #3
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,540
Well, thank you.
IBA # 33113
Alaska
XR400 Index
Old 04-21-2007, 06:45 AM   #4
EagleFeather
Flyin' High
EagleFeather's Avatar
Oddometer: 2,227
Dude, you are like the "Mad Scientist" of motorcycle accessories
Can I schedule my tigger for some upgrades too?
"You know I've had too much RedBull when my pee smells like gasoline" - Geek
Surf the World
www.couchsurfing.com
Motorcycle Travel Network
www.motorcycle-travel.net
save $5 on your SmugMug subscription - use coupon code RzTdQ4pMyqEuU - www.smugmug.com
EagleFeather is offline   Reply With Quote
Old 04-21-2007, 07:20 AM   #5
Stretch67 OP
Stretch67's Avatar
Oddometer: 6,540
Heh heh.
Funny you should say that. I've been calling my 'BMW to Tiger' Jesse bag mods "FrankenJesses".
The name will be quite apparent once I post pics of the 'During' stages.
IBA # 33113
Alaska
XR400 Index
Old 04-21-2007, 12:57 PM   #6
speedjunkie
Oddometer: 128
Genious!! Shear genious!! Very well done indeed! I may have to do something like that myself!
Mike
speedjunkie is offline   Reply With Quote
Times are GMT -7.   It's 12:19 AM.
