Old 08-18-2007, 04:46 AM   #1
Sadlsor OP
Oddometer: 691
Question New starter torque limiter
I've been dealing with the noise since week 1 of riding the Beast home from Louisville. 2005.5, 1364 miles when it became mine in early July. It's been getting progressively worse, so Donnie at Graham KTM (Senatobia, MS) has sent me the new parts, to arrive today. Said it's a big box, like it includes the case. Good thing, too, because yesterday it clacked, slapped and whacked itself without ever starting the bike, to the point I ran the battery flat. Again (new battery 3 weeks ago.) It's like the starter gears are completely stripped.
Having just replaced the stator (not starter!) a week ago, I know I can get that far. But in the numerous threads I've seen here, I haven't seen details on actually getting into the starter / freewheel and all the guts there. I know I'll drain the oil again, but seems I saw a mention to drain coolant as well? Doesn't seem that should be necessary.
Is the whole procedure performed from the left generator case as before, or will I need to attack the starter from the right side as well? Does the starter need to be removed from the engine?
I'd feel better having a couple of more clues than I do now. I know Pyndon and RidewestKTM could do this in their sleep.
The workshop CD has been on backorder for over a month, so hopefully NC has mailed me his loaner. Feel like I'm flying blind here.
TIA!! I'll be wrenching while y'all are riding.
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 08-18-2007, 06:45 AM   #2
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,717
replace limiter
Yes it's all done under that cover. If you go to my discription of trial-side repar its the same, but allow the oil loss and keep it up right. Undo the vent hose competly. My new case came with an extra screw -no idea what for. The only thing I could see which would use it was a shaft retainer and it already had it. By the way no need to remove that screw on dissassembly - it is the one in the center of a boss in the middle of the old cover. If you went after the alternator stator you have done everything already except remove the limiter which is by fingers no tools.
good luck
ridewestKTM is offline   Reply With Quote
Old 08-18-2007, 06:54 AM   #3
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
The case mounting bolts are different lengths. You'll need a pair of snap ring pliers. Installation is straight forward.
It sounds pretty bad but is only the torque limiter slipping.
not necessary
not necessary
yes
no
no
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Old 08-18-2007, 07:00 AM   #4
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Sadlsor
PM me and I send you the link to the Library where you will find the info you require.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 08-18-2007, 06:01 PM   #5
Sadlsor OP
Oddometer: 691
Thanks, cp - PM sent.
And the new case and parts package did NOT arrive today. Damn!
Looks like Monday afternoon is set aside for this job I had planned to do today. *sigh* Such is life...
Thanks for the feedback!
Old 08-19-2007, 03:10 PM   #6
Roughidle
Super Star Destroyer....
Roughidle's Avatar
Oddometer: 1,494
I had this done at my first service, no noise, but now its leaking a bit of oil from the bottom of the generator cover.
my dealer is gonna fix it, but if I was doing the repair I would keep a careful eye on the gasket when i put the cover back on.
Burninating the peasants.
Roughidle is offline   Reply With Quote
Old 08-19-2007, 06:08 PM   #7
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,273
I give up....... What's a starter torque limiter?---- What kind of noise does it make?
rufus is online now   Reply With Quote
Old 05-20-2013, 06:10 AM   #8
Sadlsor OP
Oddometer: 691
Originally Posted by DrKayak View Post
I did mine last week. So cool that the 950 now starts like any other motorcycle. none of that clanking if you crack the throttle the least bit.
My 05.5 -S model began this nonsense shortly after I bought it used.
Was so loud and obnoxious, I was embarrassed to start it when anyone was around!
Thankfully it's an easy fix. At this late date, I think it's at the dealer's discretion whether the kit is no charge to the customer.
Times are GMT -7.   It's 05:14 PM.
