Old 09-18-2007, 12:16 PM   #1
dieseldave24v OP
Wish I was riding
dieseldave24v's Avatar
Oddometer: 424
Thumb DR650 valve adj. first service
DR 650 first service
So after leaving the dealertip with a price quote of 300.00 dollars for the first service I made my way to the parts counter for a filter and some oil. I put this together so everyone who does not know how to do this gets a clear picture of how easy it really is......
First thing I did was drain the old oil.
While the old oil was draining..."remember to hold the bike straight unitl it is done." I removed the filter housing cover with a ratchet and 10mm socket.
Once the cover was off I removed the old filter and instaled the new one. The open end goes towards the engine and the spring goes between the cover and the filter.
Instal the drain plug, but not to tight so it does not strip the soft aluminum threads. Add the oil. 2.4 qts
After starting and checking the oil level it was time to tacke the valve adjustment. With the tank, side panels and seat removed I was able to gain acsess to the valve covers.
The valve adjust ment is VERY simple. Remove the valve covers and the inspection plug on the side of the magneto cover.
The serivce manual says to turn the engine by removing the center plug an the mag cover and turning it with a socket. I choose to put the bike in 3rd gear and turn the engine that way. either one should work just fine. Remember to remove the spark plugs to make the engine easy to turn over. Ensure that the engine is on a compression stroke........you are looking for a line with a "T". align this symbol with the center of the hole.
Now you are ready to adjust the valves....Get a set of feeler guages and check the clearance between the bottom of the rocker arm and the top of the valve stem. Intake and exhaust can be done at the same time.
If adjustment is nescesarry rember to hold the adjuster while you tighten the jam nut or it could move with it.
Put the valve covers back on and install everything you removed. You are done! See how easy that was.
Next thing I did was lube the clutch cable and throttle cables. Tighted all the bolt on accordence with the service manual. The first service really is this easy. Took me about two hours and I was taking my time. hope this helps someone
Dave
You cant fix stupid
The Inventory
2007 DR 650
2006 KTM 640 Adv
1992 DR 350
1998 XLR 200 Yes you read it correct.
dieseldave24v is offline   Reply With Quote
Old 09-18-2007, 12:22 PM   #2
bacon
KZ5TLP
bacon's Avatar
Oddometer: 616
Thanks for taking the time to do this and post it.
Being simple and to the point showing newbies it is not rocket science.
"Be still, and know that I am God"
For all that motorcycling is, one of it's greatest gifts is the ability to take us to places where that quote is the first things that came to my mind.
bacon is offline   Reply With Quote
Old 09-18-2007, 12:25 PM   #3
dieseldave24v OP
Wish I was riding
Oddometer: 424
Thats what I was going for. I figured I couldnt sit around and let people pay 300.00 for somthing so easy. There are so many guys out there that are some what mechanically inclined. If you can change oil on your car then you can do this. And everyone is very welcome.....now send me the 300.00 dollars...LOL
Dave
You cant fix stupid
The Inventory
2007 DR 650
2006 KTM 640 Adv
1992 DR 350
Old 09-18-2007, 12:39 PM   #4
racer 07
Lock & Load
Oddometer: 689
You need to make sure you're on the compression stroke and not the exhaust. This is obvious to most because on the exhaust both valves are open on valve overlap and there is no lash, but I've seen people loosen them on the wrong stroke and have a pretty noisy result. Just my $0.02
racer 07 is offline   Reply With Quote
Old 09-18-2007, 12:50 PM   #5
dieseldave24v OP
Wish I was riding
Oddometer: 424
Thats why I put it in there. I hope no one skip that step. If they do they should be able to tell as soon as they try to fire it up.
Dave
You cant fix stupid
The Inventory
2007 DR 650
2006 KTM 640 Adv
1992 DR 350
Old 09-18-2007, 01:01 PM   #6
CaptTurbo
CaptTurbo's Avatar
Oddometer: 1,099
Send a message via Yahoo to CaptTurbo
Thanks for making the effort to take us through this Dave. I noticed that you cautioned to not over torque the oil plug but I think you should also caution to not over torque the oil filter cover bolts. Those little buggers have very tender theads. Great thread and again thanks!
"No Man's life, liberty or property is safe while the legislature is in session." --American lawyer, editor, politician, Judge Gideon Tucker (1826-1899)
CaptTurbo screwed with this post 09-18-2007 at 04:09 PM
CaptTurbo is offline   Reply With Quote
Old 11-01-2007, 06:11 PM   #7
dieseldave24v OP
Wish I was riding
Oddometer: 424
for you wish you could ride
Dave
You cant fix stupid
The Inventory
2007 DR 650
2006 KTM 640 Adv
1992 DR 350
Old 11-01-2007, 06:32 PM   #8
u wish u could ride
SHELTON CONNECTICUT.
Oddometer: 126
thanks.
u wish u could ride is offline   Reply With Quote
Old 12-03-2007, 01:46 PM   #9
doc riverz
anatra di seduta
doc riverz's Avatar
Oddometer: 4,349
Dear dieseldave24v, thanks for making good ju-ju with this thread. Spreading the knowledge is oh-so-good.
doc riverz is offline   Reply With Quote
Old 04-06-2008, 11:52 AM   #10
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 590
Valve Adjustment
Just doing my first service... The dealership also quoted me $300 - which means their shop rate must be about $150 an hour. WOW! My shop rate is only $80.00 an hour and I work on Airplanes!
Anywho, thanks for the info as it is not found in the owners manual and they did not have a shop manual for sale at the dealership... guess I better order one..
"Save a horse, ride a cowboy!"
I just wanna ride!
TheCowboy is offline   Reply With Quote
Old 04-09-2008, 06:51 PM   #11
greer
Oddometer: 3,503
Here's the online manual:
http://www.deakin.edu.au/individuals..._adm/DR650.pdf
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 08-27-2011, 04:06 AM   #12
Escaped
Escaped's Avatar
Oddometer: 265
Originally Posted by Aerocycle View Post
To me, it looks like I don't need it, the "special tool" just makes it simpler?
Correct special "tool" is not necessary it just makes the adjustment easier. The hard of the job is just getting around to doing it. :)
Sent from my MB520 using Tapatalk
DR650 - Living the Dream!
Escaped is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
