Old 11-12-2007, 11:32 PM   #1
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
History and product up-date on KTM/Caponord 19/17 tubeless wheels
a brief history,,,,
the notion of having genuine tubeless wheels/rims has intriqued many over the years as evidenced by the variety of ways that riders and manufacturers have adapted to achieve that end,,,,we could break their efforts down into four main genres,,
Group A...those that try to seal traditional wire/spoked wheels,, it is the older of the groups ,,,,the methodologies/techniques utilized by these questors has ranged from a variety of sealants and application techniques with and without vacuum assistance ...everything from numerous layers of electrical tape,,,silicone sealants ,,,low and hi-end exotic epoxies,,,special single and double sided adhesive rubber bands and carpet tape,,,sealants protected with nylon strapping tape and/or kevlar/carbon fiber impregnated strips,,,rim bands glued on with rubber cement,,gorilla glue,,,,large O-rings on the outer bead corners ,,,,often unwittingly performed on rims never intended for tubeless tires....some techniques work better than others, some hardly at all,,,alot has to do with the care in applying and cleanliness of the sealing area not to mention only sealing rims designed for tubeless application,,,,and YES i know major manufacturers that routinely seal ANYthing.....most of these technigues are price conscious,,,,and others will run you several hundred dollars for the sealing kits,,,,
the biggest drawback is that at excessive speeds above our national mandates circa 75-84MPH,,,one moves into the territory where centrifugal force has a tendency to want to sling off the sealants,,hey it's basic physics....and what happens if a spoke breaks,,,,these are the main advantages that the next goup has over this one..
Group B,,,those that provide the motorcycle public with wheels /rims specifically made to use tubeless tires on them,,,that quest has burdgeoned in the last 30 years,,,,,some examples are Honda's Comstar wheels in the '70-80s,,numerous cast and forged wheels of every description,,,,,
and in the last 15 years,BMW,Aprillia/caponord,Moto Guzzi and a few trials bike Mfgs have offered wire wheels assembled with specially designed tubeless rims whose spokes attach from the outside edges of the rim in a x-lace pattern to the hub,,,commonly referred to as tubeless x-laced wheels...BWOE the techniques differ only in where the nipple is located,,,BMW with the oldest patent runs the spoke thru the rim's edge to the opposite side of the hub where the nipple is anchored and adjusted,,,the others reverse this process,,,their nipples are in the rims edge,,,,the trials folks have rims with a special rib running down the center of the rim,,the spokes thread thru and are adjusted in the hub ala BMW,,,,,
these wheel assemblies range in price from $250-1300...most are in the $350-450 range,,,,he BMWx-laced wheels are all circa $950-1300each the caponards/moto-guzzi not much less....hit something and bend them and you will need a specialist to repair them,,,Yes,,they can be straightened more often than not,,,,
Group C,,, is what i call the new hybrid technology,,,where a variety of mechanical techniques are utilized to seal the nipple in the rim...the Alpina company,,spoke and nipple suppliers to the bicycle/mc kingdom for 80 some years,,have bought practically every patent on the planet that deals with any notions surrounding sealing a traditional wire wheel in this manner....
some years ago i designed a special sealing and locking nipple waiting for the ''right time '',,,although different than anything alpina has,,,the ''idea'' of mine bangs into the ''idea'' of what they own from what i have gathered in speaking with them,,,,,we'll see if we can collaborate,,,you will see this technology spread in the next few years....several mainstream manufacturers have already bit into their apple,,,
Group D,,,is largely composed of folks that cross-pollinate existing tubeless rims from certain brands /models and make them work on other brands/models,,,BWOE the numerous transformations available for the BMW GS/HP-2 crowd,,,,converting these models from touring to mega-moto to off-road to....even better offroad/competition...Baja-1000/Paris-Dakar specials.....or..
from brand to brand ala taking the 19/17 36hole tubeless Aprilia Caponord rims and x-lacing them to oem KTM or aftermarket RAD hubs on the LC-4/8 Adventure models,,,voila,,,now a KTM adv rider has all the benefits of genuine tubeless tire specific rims,,,,their merits have been posted too numerously already,,,
that's it for today,,,,will post phase two of what it took to create these and the lessons learned along the way,,,
Pics of the 19/17 tubeless Caponord rim conversion to KTM LC4/8 hubs
here's a pic of the 2.50x19'' front on sidestands's bike
and here's the 4x17'' rear...trick Superlace pattern on powdercoated 60%glossy oem hub to satin black anodized rim
kudos to ''zune'' for the great pics
here's a link to see a black anodized RAD/hub to polished black Caponord rim
https://mail.google.com/mail/?ui=2&i....1&disp=emb&zw
the Gobbler in action on MT. Palomar with his new Caponords
one pic is worth a thousand words.....+++++
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 12-07-2010 at 03:06 AM
Old 06-08-2008, 09:02 AM   #2
Wreckluse
Will work for beer
Wreckluse's Avatar
Oddometer: 444
Hi Woody,
These wheels look like exactly what I want!! I want a second set of wheels for my 06 KTM 625SMC.
Two questions:
1. Do you know if the front brake calipher on the SMC would clear the spokes, as the SMC has a 320 mm front rotor?
2. If so, how much to build a set and ship to Calgary, Alberta?
Thanks,
Doug
Indecision is the key to flexibility.
07 950 SM R
09 450 EXC dual sport
08 DRZ 400 SM Adventure
12 GasGas 250 Pro
Wreckluse is offline   Reply With Quote
Old 06-22-2010, 04:13 PM   #3
Built to Last
Oddometer: 3,431
625SMC KTM with Caponord genuine tubeless rims and 320 mm disc ..DoAble!!
Originally Posted by Wreckluse
Hi Woody,
Two questions:
Thanks,
Doug
1,,the X-laced wheels lend themselves to this conversion because their's more room for your caliper where the spokes x each other
2,, circa $2500 with billet hubs $1700 using your wheels/hubs,,,S&H circa $100-200 depending on speed
woody
Old 05-27-2009, 03:27 AM   #4
kahoon
who's yer daddy??
kahoon's Avatar
Oddometer: 2,392
kahoon is offline   Reply With Quote
Old 09-27-2009, 03:10 AM   #5
Built to Last
Oddometer: 3,431
other threads and links to tubeless Caponord rims on KTMs
so here's some threads and links that'll give you feedback,,a few pics and stuff you may want to know......
1......Who's got the Caponord Tubeless Rim setup for their Adventure? http://www.advrider.com/forums/showthread.php?t=465628
2...... KTM 950/990 Adventure owners show off your bike
http://www.advrider.com/forums/showt...62878&page=446
post#6677
Originally Posted by sidestand
Here is mine after a new set of woodys caponord wheels
woody's wheel works screwed with this post 09-27-2009 at 03:23 AM
Old 11-01-2009, 08:25 PM   #6
Built to Last
Oddometer: 3,431
Nowwhat's 19/17 combo in action
Originally Posted by Nowwhat
Woody's 19/17...Caponard wheels....
they perform flawlessly....
That was the intention ,,,ya know it gives me great pleasure to build stuff like this for people that appreciate the difference,,,Psssst,,from the looks of the the confidence you exhibit,,,i'd also invest in some riding boots for you n your honey!!!!
Old 11-05-2009, 04:55 AM   #7
overlandr
Dystopist
Oddometer: 5,899
Originally Posted by woody's wheel works
here's the 2.50x19'' front...
post 9... http://www.advrider.com/forums/showthread.php?t=348354
post 8...http://www.advrider.com/forums/showthread.php?t=348354
Hey Woody - just a heads up as these links appear to be broken.
overlandr is offline   Reply With Quote
Old 11-05-2009, 07:08 AM   #8
Built to Last
Oddometer: 3,431
help me find zune's great pics of his 950/Caponord wheels again!!!
thanks ,,,i know it aches me too because zune shot 2 of the best ever pics i've seen in a ride report,,,i mentioned oit to the moderator and essentially informed me that someone goes around and deep-sixs pics that take up too much space,,,
i have tried to find zune to see if he has them save dsom where....Gadget Boy in formed me that getting a smug-mug account was the way to go and store my pics,,,hell it's been 3 years since i joined the asylum and i'm just now getting the basics down,,,
later,,w
Old 11-14-2009, 03:45 PM   #9
DakarBlues
One-everythinged man
Oddometer: 1,296
Aprilia CapoNord wheels
later,,w
Hey Woody, I don't know if these are the pics from Zune, but for me they are the nicest pics of the CapoNord wheels on an LC8 ever, anyway here they are straight from my very huge personal LC8 pics archive.
Thank you Woody!
He, whose nuts skim the ground while airborne, won't crash very far!
Pedibus Cum Jambus 1200 S
IBA # 38875
DakarBlues is offline   Reply With Quote
Old 11-15-2009, 08:59 AM   #10
Built to Last
Oddometer: 3,431
kudos to Dakar Blues for some nice caponord-950 ADV pics
woody
Old 11-15-2009, 10:21 AM   #11
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
well done man, they look awesome!!!
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 06-22-2010, 08:42 PM   #12
overlandr
Dystopist
Oddometer: 5,899
woody
Woody, what width is that front and rear rim? Cheers
EDIT: Just found answer here!! See some of us can actually use the search thingy!
http://www.advrider.com/forums/showp...postcount=1700
Old 09-21-2010, 07:18 PM   #13
HWSNBN
HWSNBN's Avatar
Oddometer: 2,895
Thank you Woody!
That's my bike... long ago.
SAME Wheels I rebuilt them and sold them to Nowwhat.
HWSNBN is offline   Reply With Quote
Old 09-23-2010, 08:08 AM   #14
Built to Last
Oddometer: 3,431
nice job HWSNBN
great job!!!! he sure does like em!!!!...now he's laughing too
Times are GMT -7.   It's 03:48 PM.
