Old 01-27-2008, 05:17 PM   #1
bananaman OP
transcontimental
Oddometer: 7,992
Drowned in a river near San Blas, Panama
I crossed 4 rivers on my way to Cocuye. The 2nd river on the way back got deeper than it was, and the whole air intake got flooded. I spent two hours drying it. I removed and dried the plugs. I threw away the air filter (wrecked). The plugs are ok. I drained the water by removing the plugs and tilting the bike. Probably a quart drained out. I managed to re-start it, and with a twist of the throttle at least another quart came out- through the tail pipe!
The bike is still in the jungle. Tomorow I'll take oil, an oil filter, an air filter, a mechanic, and a big truck. We will use the truck to get back over the rivers. It is raining now in the mountains which means the rivers will rise. I would really appreciate any advice. Now I'm going to shower and get some food.
It is at least 4 hours from here to where the bike is stashed. Tomorow is going to be a long, long day.
I am Charlie.
bananaman is offline   Reply With Quote
Old 01-27-2008, 05:28 PM   #2
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,352
Good luck, man. It will make a great story. I think after the oil change you'll want to keep the bike at operating temp for as long as possible to make sure as much residual water evaporates and purges as possible. Then change the oil again asap. That said, these things are amazing machines and can take a lot of abuse in stride..
John
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 01-27-2008, 05:57 PM   #3
bananaman OP
transcontimental
Oddometer: 7,992
Change the oil twice? Ok. Anything else?
I am Charlie.
Old 01-27-2008, 06:01 PM   #4
Lone Rider
Registered User
Oddometer: 25,130
This is g r e a t sht.
Make sure to take care of your bike, keep 'er running so that you can post more cool stuff.
You may want to run thru two cycles of oil cleaning, dump one and then stuff in fresh oil. Bearings are your friends.
Get an air filter, dirty sock, pantyhose, whatever....
Keep the horse running, man. We want fcking pics....
Go 'Nannerman, go....
Lone Rider is offline   Reply With Quote
Old 01-27-2008, 07:51 PM   #5
NBeener
Oddometer: 1,521
It's gonna' be awfully funny if ... in a few months ... he 'fesses up that he never left the Barcalounger and the comfort of his own home
Good luck on getting out of this one, 'nannerman. Amazing adventure. I'm just flat jealous
NBeener is offline   Reply With Quote
Old 01-27-2008, 07:59 PM   #6
bananaman OP
transcontimental
Oddometer: 7,992
I wish right nw that I was in Wisconsin feedin the fireplace
What else should I look out for?
I've got a truck lined up for tomorow. Looks like I'll be sleepin in the jungle, if my bike isn't on a boat to Colombia right now.
I am Charlie.
Old 01-27-2008, 08:05 PM   #7
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,503
perhaps other fluid changes in the trans and final drive might be a good idea?
xdbx is offline   Reply With Quote
Old 02-21-2008, 07:45 AM   #8
bananaman OP
transcontimental
Oddometer: 7,992
Pantyhose? What year is this? Who do you know who still wears pantyhose?! Silk stockings... or, more likely, REI brand poly-fleece- that's what I want my woman to wear!
Now that I think of it, I did have access to a pair of silk long-johns, but I didn't have a key to the side-cases they lived in. Good luck to the man who was going to wrestle them from Barb!
I've got 3 and a half weeks until the return to Panama and the resumption of travel. Oil filter, fuel filter, O-ring kit, platinum spark plugs, flywheel, and clutch are on the way to Wisconsin. The left side-case is so bent that I'm considering just throwing it into the flea market. The pucks that held the cases on... well, the screws pulled right out of them and no amount of "goo" will hold. It's either big-old bolts, or total replacement. The right side case isn't much better. Next on my wish-list is a set of Jesse's. I fall asleep dreaming of all the things I'll be able to fit inside. 108 liters. Compared to the total 76 liters I have now, 108 is HUGE!
I am Charlie.
Old 02-21-2008, 09:41 AM   #9
stickfigure
Fiendish Fluoridator
stickfigure's Avatar
Oddometer: 523
With the amount of abuse they're getting, maybe Pelicans? The 1440s are pretty big and top-loading. You still won't have the same capacity but they'll survive... and even if they don't, they're cheap to replace.
Jeff
stickfigure is offline   Reply With Quote
Old 02-21-2008, 10:28 AM   #10
bananaman OP
transcontimental
Oddometer: 7,992
Pelicans, Zegas, Happy Trails, etc. etc. etc... I've debated and read and examined every system out there. I'm going with Jesse's for a few reasons. When I called, Al Jesse took my call. He promised he'd call me back in a couple of days, AND HE DID. We were able to have an actual conversation about international adventure riding. He gave me a few tips. He's done the routes that I'm planning. He knows what I need. (Kimo over at Touratech USA has also provided awesome service and advice.)
I'm really looking forward to testing the angled surface at the bottom of the bags. I drop my bike- that's just a fact. I don't know when I'm going to drop it, but so far on this ride I've dropped it at least ten times. Each time it falls, it makes very-hard initial contact with the lower corners. For example, when I fell in Costa Rica, going down a steep steep gravel hill, I put a nice gash in the lower front corner of the right case. (Repaired with cold-weld and duct tape). Hopefully the angled corners will perform as planned. When I drop the bike on the left side, the extended mounting frame adds leverage to the weight of the bike, and the result is a totally crushed side case. The last time I crashed, I managed to rip the left case completely off the bike. Ow.
I like the Zega easy-on/easy-off mounting system, but I think it gives up some robustness in order to be so easy to mount/dismount. I only took the side-cases off a few times. Easy mounting shouldn't be a big issue.
The Jesse's don't just mount closer to the bike, they also present a narrower profile. I don't really like to lane-split, but the reality of riding Latin America is, LANE SPLITTING. I'm careful about it (not nearly as daring as local lunatics), but with the Zegas.. I felt FAT.
I chose the Zegas for two reasons: nice square design, and, most importantly, a fellow inmate had them for sale, never-used, for a great price. I debated the size-factor: 35 liters on the left side seemed pretty small. On the plus side, the small-size was supposed to limit what I could carry, thus reducing the overall weight. I regretted this later, when I found myself having to lash waterproof duffels to the lids. I never did find a really good system for lashing everything. I never worried too much about bike-security, but there was always a nagging feeling that someone could walk off with the lashed stuff pretty easy. Getting into the cases when stuff is lashed to the lids- not fun.
Barb has Jesse-knockoffs on her KLR. They're way, way bigger than my Zegas. They're durable (Barb dropped her bike too! Not always reported in the Ride Report to protect her... innocence) and did I mention BIGGER.
I am Charlie.
Old 01-27-2008, 10:00 PM   #11
Peka
Peka's Avatar
Oddometer: 2,013
That was not a good idea, but if you got all/most of the water out by tilting the bike you could be lucky. The water coming out the tail pipe was probably just the exhaust full of water. Standard procedure for a drowned engine is get the water out of the intake & airbox, then remove the plugs and turn the engine over with the plugs out. This will pump out all the water (don't look in the spark plug hole while you're doing this, as a mate of mine once did ). Keep turning it over until no more water comes out. Trying to start an engine that has water in the cylinders can result in nasty, expensive noises coming from that area
I can't see a breather on my 1100 trans, the FD definitely has one. Change the trans & FD oil, ride to get it up to operating temp, then drop and check the oil. Any sign of water, do it again with fresh oil.
You will need to clean up your starter motor. At least clean and lube the shaft of the gear that engages the clutch housing. Otherwise you may find that it stops engaging and turning over the engine in the weeks to come.
The cover on the left of this diagram is what you need to remove, then clean and lube it:
With the starter motor off, get a torch and have a look inside at the clutch. I don't know an easy way to clean this out, but hopefully there won't be any/much in there.
Replace oil filter and air filter. Get an oilable foam type air filter (eg. Uni Filter) rather than a paper one - they don't melt when they get wet like the paper ones do.
Peka is offline   Reply With Quote
Old 01-27-2008, 10:07 PM   #12
NBeener
Oddometer: 1,521
GREAT post, Peka.
On the SLIM chance that somebody doesn't know ... "torch" is Brit/Oz for "flashlight."
[Ya' never know....]
Old 01-28-2008, 12:50 AM   #13
Peka
Peka's Avatar
Oddometer: 2,013
Originally Posted by NBeener
GREAT post, Peka
Can you tell I've done this more than once? It only ended badly on one occasion, and it was an expensive exercise for the insurance company (V6 quad cam engine from a 4wd).
Another tip: if the engine stalls while you're in water, think hard about whether you want to try and start it again. If you know there's no water in the engine go ahead, otherwise play it safe and check it first (check airbox, then pull the plugs and turn it over).
Old 01-28-2008, 01:42 AM   #14
Gum
Oddometer: 475
Gday
Was the oil milky, if not there is no water in it and dont rush to change it. It wont get water in the engine unless it sits in it. If it was running, yes the combustion chambers will have it, did it stall ???. Like some one has said, run it and keep it running at operating temperature is all you have to do. The only real vacuum you had was the air intake, everthing else should be fine. If it runs well, then it cant have been to bad as the first thing is that water does is not compress and you would have a bent rod. Gum
Gum is offline   Reply With Quote
Old 01-28-2008, 05:20 AM   #15
bananaman OP
transcontimental
Oddometer: 7,992
Thanks everyone.
I'm off now to the BMW dealer here in Panama. I thought they opened at 9 but instead it's 7 so if I really hustle I could be home again tonight.
Where the bike is now, I really don't want to have to change the tranny and final drive fluid.
The starter made a strange noise. I'll do what I can for it.
The clutch... holy shit the clutch got abused in the mud. I buried the rear wheel right up to the axle. A lot. To try (in vain) to keep from spinnin, I's start out in 2nd. Or at least try to start out in 2nd.
Did I mention that my dad did this road a few days ago (in a Landrover Defender) and reported it dry and in good condition, with rivers only ankle deep.
I don't know if any of you pray or anytin, but if you do, please hope that my bike is where I left it? I'm sure I can fix it... if I can find it again.
Here are the coordinates (aprox). Check it out on google earth. n 9, 30.945, w79,14.888
I am Charlie.
Times are GMT -7.   It's 03:34 AM.
