07-10-2008, 04:55 AM
#1 |
Oddometer: 3,809
Stripped clutch-oil-resivor-cover screw head.. help!
So I stripped the head (not the thread) on the of the screw that holds down the clutch oil resivor. What now?!
07-10-2008, 05:01 AM
#2 |
Aquatic adventurer
Oddometer: 1,343
Try and tap the screw round using a fine centre punch, perhaps?
You could try clamping the reservoir lid down in some way (maybe a large elastic band would do?) - this might relieve the pressure on the screw caused by the compression of the rubber diaphragm in the reservoir. If the other lid screw is already out, put it back in for the same reason. Only ideas I'm afraid, but probably worth a try.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks |
07-10-2008, 05:29 AM
#3 | |
Oddometer: 3,809
Well, good excuse to do away with the old and farkle with new! So, I think I'll order the flashy orange OEM KTM clutch reservoir plate - in which case, I'll grind the original plate + screw head down until I can pull it off by hand - a crude crude solution indeed! (unless anyone has futher suggestions?!). .....as a second to last resort, I'll try creating a philips head first (with a Dremel - even if that means cutting into the plate a little).... there might be enough material left there to latch on to. |
07-10-2008, 07:40 AM
#4 |
Orange Caveman
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,100
Sounds like a job made for the Craftsman power extractor. I don't sell 'em, just use 'em. Work good, especially on small screws with stripped heads.
![]() -cp DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt. |
07-10-2008, 07:59 AM
#5 |
KTM
Oddometer: 1,196
this is gonna sound scary but we do it on aircraft all the time and it is completely safe.
Get a drill bit the diameter of the screw. Chuck it in a hand drill and place in the center of the screw head. (This will be be centered if you rounded it out) Now you drill but only bump it a turn revoluition or two at a time two. Once you get threw the screw head with the drill bit still in the drill but not rotating rock the drill bit back and fourth. This will snap the head off then pull of the cover and remove the stud with a pair of vise grips. This is VERY easy the whole trick is to go slow, straight and only threw the head of the screw. You can check you depth buy using the other screw for measurment purposes. Believe me once you do this 500 or 1000 times on a plane it is nothing. But it is a very fast way to remove a screw safley and without damaging anything else.
Every question in life has an answer of YES OR NO Maybe = NO Keep life simple and enjoy it!
07-10-2008, 11:05 AM
#6 |
Rat race Dreamer
Oddometer: 2,831
2007 KTM 990 ADV 2008 URAL Patrol "If you sit around waiting for death to take you, you will miss life. Die living life to the fullest, don't live dying!" -patient |
07-10-2008, 12:16 PM
#7 | |
Oddometer: 343
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I do believe you. it just made me laugh the way you said it's nothing once you've done it 1000 times. A dremel might help remove the head and then get pliers on the stud.???
Errr...... |
