Old 03-24-2004, 07:45 PM   #1
O.C.F.RIDER OP
Loose nut behind h/bars
O.C.F.RIDER's Avatar
Oddometer: 4,508
"hot" exhaust set-up
I have definitely come up with the "hot" (pardon the pun) set-up as opposed to the Akras or KTM solution. I made my own pipes using a MagnaFlow car muffler....Stainless Steel 4" od, 2" core, made my own flanges and tig welded them on - used Hindle muffler clamps - and for the finishing touch polished everything (since that's what I do).
Check out the front fender also.....KTM SuperMoto!
See pictures below....
O.C.F.RIDER is offline   Reply With Quote
Old 03-24-2004, 08:08 PM   #2
Will
Carpe Moto.
Will's Avatar
Oddometer: 434
Very nice! I think I'll run out to my garage and TIG weld up a set. Or not. But how do they sound? How did you adjust the carbs to match? What would a set cost if some other KTM rider was interested?
Will is offline   Reply With Quote
Old 03-24-2004, 08:26 PM   #3
K2ride
Single track mind!
K2ride's Avatar
Oddometer: 1,615
Nice setup!
So......
C`mon, give us answers!
Ride hard, ...life's short!
K2ride is offline   Reply With Quote
Old 03-24-2004, 08:32 PM   #4
O.C.F.RIDER OP
Oddometer: 4,508
I could probebly make another set for about $400,and they sound great,at low RPM(3400 or below) they are maybe a little "HARLEYISH",but at higher RPM or when you are blipping the throttle it sounds like a very angry 996 DUC!
Yes,the carbs have been sorted out:
#4 groove
160/165 MAINS
2- 3/4's turns out on fuel screw
stock pilots
Old 03-24-2004, 09:19 PM   #5
Wayne Weber
why are we stopping?
Oddometer: 3,854
Nice flanges! you went to the trouble to match the KTM flange shape, it looks great...
These are straight thru glass packed mufflers, right?
Wayne
04 KTM 950 S
93 KTM 550
93 XT225 Adventure Serow!
00 Weber Rally Twin (www.rallytwin.com)
Gas Gas 270
2 Waterbuffalo's (Sold!)
Wayne Weber is offline   Reply With Quote
Old 04-07-2004, 05:04 AM   #6
O.C.F.RIDER OP
Oddometer: 4,508
pipes
Yup,they sure are straight thru! Thanks for the thumb's-up on the flanges.
Old 04-07-2004, 08:47 PM   #7
kailwathne
Registered
Oddometer: 138
Those look great and I'm sure they have plenty of sound. How is the weight compared to the stock pipes?
kailwathne is offline   Reply With Quote
Times are GMT -7.   It's 09:52 AM.
