Old 02-09-2009, 03:05 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,849
320mm Brake upgrade for G/S
OK after hashing out whether to ad another disc, or some other method of upgrading brake I decided to go w/ a 320mm brake upgrade. I think stock is 260mm. As Of now I cannot comment on the improvements as you can see I have no front tire.
This uses the stock caliper and just relocates the calipers outbound a bit, comes with a spacer for the rotor and needed bolt to mount the caliper and disc. I got this from Seinbenrock. It is suggested to get another brake line but the old one will work.
One thing I don't like and has nothing to do w/ function is that the bracket which mounts to the fork needs to have the mounting bolts recessed into the bracket. I may have this done later.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-09-2009 at 03:12 PM
Old 02-09-2009, 06:53 PM   #2
johno
johno's Avatar
Oddometer: 2,912
Thats a strange looking disc
Looks like a floater, but its not.
Should definately work better though.
Down in the land of the confused(mainly me)
johno is offline   Reply With Quote
Old 02-10-2009, 04:10 PM   #3
One Less Harley OP
Oddometer: 4,849
It's a solid disc which have been laser cut at a few locations to take care of heat expansion and probably help keep it from warping.
I had the aluminum countersunk for the mounting bolts. A much neater look.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-10-2009 at 04:19 PM
Old 02-10-2009, 07:14 PM   #4
woodgrain
In-Dented Savant
woodgrain's Avatar
Oddometer: 821
How much for the Siebenrock kit?
Woodgrain
woodgrain is offline   Reply With Quote
Old 02-11-2009, 05:39 AM   #5
One Less Harley OP
Oddometer: 4,849
USD Cost- $311.98 plus $41.40 shipping from Germany.
Probably cheaper to get someone to make another bracket for a four pot caliper, but might have to change brake lines and possibly the MC. The stock brakes aren't that bad w/ standard tank and unloaded...not great but adequate.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-11-2009, 09:24 AM   #6
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Or, for a lot less, you can use a 2000 or so K1200R (re-badged Brembo) 4-pot caliper (34/32mm) on a stock disc with great stopping power:
Use a left caliper with bracket for the G/S location behind the fork leg.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 02-11-2009, 10:09 AM   #7
England-Kev
Oddometer: 3,700
Are there any options for four potting an ST front end?
England-Kev is offline   Reply With Quote
Old 02-12-2009, 03:29 AM   #8
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,190
The ST use the same calipier so the 4 pots conversion would work
Caddy82rats is offline   Reply With Quote
Old 02-13-2009, 06:15 PM   #9
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
Nope, the BMW 4-piston caliper does not work on a G/S nor ST.... I can tell you that for sure.
Boxerworks sells a machined adapter to do this mod, but the caliper ends up almost below the wheel and looks to be in a bad place for off-road riding.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 02-12-2009, 03:37 AM   #10
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,499
Anybody have a link to more info on this mod? e.g. does stock bracket work? Shims...? Does master cyl need to be re-thought? etc...
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 02-12-2009, 04:34 AM   #11
StephenB
StephenB's Avatar
Oddometer: 2,044
On a stock GS you only have to shave a bit (4mm) off the mounting brackets of the caliper, otherwise it is plug 'n play. I made no changes to the m/c. I think mine is stock GS 12mm.
Dunno about doing the mod on a G/S but I assume you need a custom bracket.
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
Old 02-12-2009, 03:26 PM   #12
One Less Harley OP
Oddometer: 4,849
Took the bike out for a test ride w/ the 320mm rotor, don't know what pads are on the stock caliper, but getting the front wheel to chatter and lock up is not a problem now. First ride and I like it so far. Nice upgrade w/ no fuss on installation.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 05:22 AM.
