Old 02-12-2009, 08:49 PM   #1
brianjonesphoto OP
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,458
How to tell if a triple tree is tweaked
I'm starting to rebuild a v-strom that was in a head on collision into a vehicle at 15-20mph.
The obvious damage was to the fork tubes and radiator. After removing the forks tonight I'm now wondering it the triple tree could be tweaked as well. the fork tubes didn't want to come out very easily. At first i chalked it up to the fact that they were bent and may be binding at the lower clamp.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 02-12-2009, 08:56 PM   #2
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,868
They're probably just twisted and offset from each other. Basically you need the old forks out, loosen up the head nut and adjuster nut, line the triples up and see if the new forks go in and line up. Check for peeling paint around the steering neck to see if it got bent into the frame.
Old 02-12-2009, 09:13 PM   #3
brianjonesphoto OP
Single Track Noob
Oddometer: 1,458
I should have added this to the first post.
Brian
Old 02-12-2009, 09:21 PM   #4
sideshow
debaser
Oddometer: 2,775
Ouch!
Get your replacement straight forks and do what larryboy suggested. They should slide right in from bottom to top. If not, time to find a new triple clamp.
sideshow is offline   Reply With Quote
Old 02-12-2009, 09:25 PM   #5
brianjonesphoto OP
Single Track Noob
Oddometer: 1,458
Thanks guys!
Brian
Old 02-13-2009, 09:30 AM   #6
mcma111
mcma111's Avatar
Oddometer: 7,989
Tweeked
With the fork tubes removed, rotate the triple clamps side to side. Smooth? OK. Binding? Stem bent. Go buy a piece of glass. Long and wide enough to cover the fork tube holes in the triple clamp. Remove the upper triple clamp and lay it on the glass. See any gaps under it? Hold the glass up to the bottom of the lower clamp and check it.
When installing the new tubes you may need to loosen the top center nut to align the two clamps. Slide the tubes so that equal length is exposed from both sides and rotate the tubes. Set/tighten the center nut.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Times are GMT -7.   It's 06:57 PM.
