Old 04-24-2009, 08:59 AM   #1
Tundra Tom OP
XLR8
Tundra Tom's Avatar
Oddometer: 65
H-1 Project
Aka: "The Widow Maker"...
I've reserected a 10 year old project, a '74 Kawi Mach 3 two stroke triple.
New connecting rods, bearings and journals, crankshaft seals, case seals and all engine gaskets. New clutch plates, front brake pads and a bunch of other crap I forgot about.
Other than the con rods, I had purchased this stuff long ago.
Hope to have it smoking by this weekend.
"When my time has come I prefer to be in the Saddle, rather than the Recliner"
2008 Suzuki Bandit 1250SA / 1999 BMW F-650
1975 Norton 850 Commando / 1974 Kawasaki 500 H-1
And yes I ride all four
Tundra Tom is offline   Reply With Quote
Old 04-24-2009, 09:57 AM   #2
G2mk3
G2mk3's Avatar
Oddometer: 162
mmmmmm kawasaki triple
actually a friend and I looked at a gt550 in hammond, but it needed a bit more love than we were willing to give it.
81 xv750
82 xl185s
G2mk3 is offline   Reply With Quote
Old 04-24-2009, 10:39 AM   #3
Tundra Tom OP
XLR8
Tundra Tom's Avatar
Oddometer: 65
If they've been sitting for more than a few years they likey need Con Rods as they tend to rust with no oil in the crank case. I found this shoved in a corner in a machine shop and got it cheap, it ran for a while but the crank seals were going and it would lose compression. When I tore it down the inner crank seals were toast too....common. Then it sat for many years till I was either going to use it or lose it.
If it wasn't in decent shape with under 7000 miles I doubt I would have invested the cash. Super easy to work on. Even got a parts bike to scavenge from.
Hope to get it to First Thursdays at Dulanos May 7th.
Old 04-24-2009, 10:46 AM   #4
arcticsp2003
arcticsp2003's Avatar
Oddometer: 31
Nice bike...
I have a 72 Mach IV in need of resurrection. Maybe next year....
damn college gets in the way....
arcticsp2003 is offline   Reply With Quote
Old 04-24-2009, 08:40 PM   #5
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,969
I'm not totally familiar with these, but these were famous, crazy fast, first of their kind kinda thing. Brown tank with yellow stripes, eh? Werent they the fastest thing ever, for about two years? Just about the pre-sportbike wave crest or something like that.
I almost just asked why there was no oil in the case but then it dawned, even through the rum soaked smog :lol
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 04-25-2009, 10:22 AM   #6
Putts
Gettin' there.
Putts's Avatar
Oddometer: 11,392
I remember when they were new and I was in high school.
The Norton 750 Commando was the muscle bike to have, and then the Mach 3 came along and fast had a new meaning, or so it seemed to a teens drooling eyes. I'd have taken the Norton back then, I'm not so sure now. It'd be kind of fun buzzing down the road killing mosquitoes with both the front and back end.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is offline   Reply With Quote
Old 04-26-2009, 01:17 PM   #7
Ranmar850
Ranmar850's Avatar
Oddometer: 252
Like this one? mine
Or with the fairing
or a mate's
or another mate's
Did someone mention CB750's?
Good judgement comes from bad experience, which comes from bad judgement....
06 FJR 1300a
Norton Commando Mk111 850
02 X1W
ZRX1200R
Ranmar850 is offline   Reply With Quote
Old 06-09-2009, 10:31 PM   #8
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,699
I am sure the cases could leak into the bottom of the combustion chamber and reek RPM havoc.
Have you gone to Kawasaki triples worldwide . com ?
http://www.kawasakitriplesworldwide....pBB2/index.php
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 06-10-2009, 05:07 PM   #9
P B G
Oddometer: 10,001
Did you let the sealer set up before firing it up?
Old 06-11-2009, 10:15 AM   #10
Tundra Tom OP
XLR8
Tundra Tom's Avatar
Oddometer: 65
I did but used the red high temp. silacone rather the recommended 3 bond 1194 which I now have a tube of (of course). Yeah, the triples site is a weath of info. The kick started was never wound right on the spring.
The K3 site had links to photos etc. on the proper install.
I've got sooo much on my plate right now pulling the motor again will have to wait. Hey...it starts with a couple kicks at least!
Old 06-11-2009, 01:06 PM   #11
P B G
Oddometer: 10,001
You've seen this bike right?
Old 08-25-2012, 04:33 PM   #12
Twin-shocker
Oddometer: 1,673
Replace all 3 condensers, as having the wrong coils fitted will almost certainly have damaged them. Pressure test the motor before stripping it, as this will determine exactly where the leak is, and will save an awful lot of work.
You will also find that bikes pretty dangerous in the turns, as moving the shock mounts and fork tubes, will have reduced ground clearance quite a bit, and will mean center stand, pipes, and footrests will all ground out very easily.
Old 09-04-2012, 02:29 PM   #13
dan-c
Back
dan-c's Avatar
Oddometer: 13,713
I thought the H1's were always CDI . Seem to remember the little lightening bolt under the CDI badge on the old refrigerator white tanked ones.
dan-c is offline   Reply With Quote
Old 09-04-2012, 02:41 PM   #14
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
They were, even the 69 said Electric on the side cover meaning CDI. He is talking about replacing the pick up coils on the CDI he refers to them as condensers.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-04-2012, 03:28 PM   #15
Twin-shocker
Oddometer: 1,673
H1A had CDI system, HIB points, and all the subsequent KH bikes CDI
Times are GMT -7.   It's 02:57 PM.
