07-08-2009, 10:14 AM
#1 |
I'm a Yorkshireman thanoz
Oddometer: 1,767
Oil Leak Pictures...... Any Ideas??
Just got back from a couple of days in Scotland with the missus. I checked and topped up the oil before we went. Ran smooth as you like and covered almost 600 miles. Got home and when I came to put the bike away I noticed a pool of oil underneath the bash plate.
I didn't start her up as I checked the dipstick and there was barely any oil on it so I wheeled her down to the garage and whipped off the tanks to have a better look. I'd like like your views on a number of things; If the oil was low why didn't the warning light come on? I know the TSB regarding the nuts on the top of the cylinders haven't been done could this be the cause of the leak? If so could I get a dealer to do the work? If the oil pressure sensor is Kaputt could this also have caused the leak? And finally any ideas on the cure? I'm no whizz on the spanners, but I do my own servicing including the valve clearances and I'd like to tackle the job myself, I just need a bit of guidance. And what parts if any would I need? Many Thanks in Advance Left side ![]() Front ![]() Rear ![]() ![]() Right side ![]() Front ![]() Rear ![]() We're going away into Europe in 5 weeks time and I could do with my confidence restoring |
07-08-2009, 11:50 AM
#2 |
Oddometer: 39
Hi Dee Gee
Check your Breather pipe at the air box end, if you have an early Adventure it may not have the non return valve fitted if not Fit one. Second check the oil pressure switch, its just above the starter on the cylinder head, both of these are common oil leak areas. Rick Nottingham. |
07-08-2009, 11:52 AM
#3 |
Arrogant Horse's Ass #1
Oddometer: 36,513
Mine had the check valve in the breather pipe and had the same leaks as yours. Took the valve out and no more leaks. The valve will clog. So if you have a valve think about replacing it. I have been running without one for a month and the leaks are gone.
Steve |
07-08-2009, 12:14 PM
#4 |
Oddometer: 1,767
Cheers for the replies, so what's the course of action? Do I have to strip the heads down or just clean up the oil and check the breather pipes and fit a new oil pressure switch?
It's an 04 Adventure by the way. |
07-08-2009, 12:27 PM
#5 |
Oddometer: 36,513
I thought I had a bad base gasket and head gasket and had resigned myself to taking it apart.
After removing the valve, I cleaned up the motor with a good engine cleaner and have not had to do anything else since then. I may need to look at reinstalling the valve if I find oil on the filter at the carb when I do my next valve adjust this weekend. Oh mine is an 04 Adv also. |
07-08-2009, 12:37 PM
#6 |
Goober
Oddometer: 587
I'll bet those Scots tried to deep fry something in there while you weren't looking.... they'll eat deep fried anything!
Best way to tell is to taste it and see if you catch a hint of Mars bar or the like. oh wait... this is a serious thread. Sorry.
Chris KTM 990 ADV Honda XR650L |
07-08-2009, 12:44 PM
#7 |
Oddometer: 3,404
Start with oil pressure(£6.78 i think) switch as Ricardo says,i swapped mine out at 25k miles. I had oil dripping fast!!This is a bitch to get to.
Clean up the engine area and go ride a few hundred miles.I did and mine looked like your engine only less oil so i changed my base gasket and found the studs that hold the cylinder on was corroded so the gasket was gone on mine. Another tell tale sign was that there was oil/crap in my coolant yet no coolant in my oil(my oil filter didn't have weavy pleats). Any specs of oil/crap in ya expansion bottle? |
07-08-2009, 03:39 PM
#8 | |
Oddometer: 3,433
2009 XR650L Steve |
07-08-2009, 04:06 PM
#9 |
Oddometer: 383
Have you checked that the drain hose (the transparent one) hasnt become disconnected from the bottom of the air filter box?
I had similar symptoms to you last year and was convinced the head gasket had gone but it was oil blown through the crankcase breather hose that had run into the bottom of the filter box and run out onto the cylinder head because the drain hose had become detached. Looked for all the world like a blown cylinder head gasket - I even stopped at a KTM dealer in Germany for a second opinion, and their mechanic - a beautiful little blonde girl with her arm in a plaster cast - agreed. Pete |
07-09-2009, 05:15 AM
#10 |
Oddometer: 1,767
Update
Right here's what I've done today.
I cleaned all the oil up that was on the casings, I checked and topped the oil level up (she lost just over 700ml). I dowsed the engine in talc started her up and waited.......... Here's what happened; ![]() At the rear of the front cylinder ![]() ![]() The other side ![]() ![]() And the oil pressure switch is damp and oily ![]() I'll be ordering an oil pressure switch, but do you think I'll have to replace the gasket at the bottom where the leak is?? |
07-09-2009, 05:17 AM
#11 | |
Oddometer: 1,767
07-09-2009, 02:23 PM
#12 |
Oddometer: 39
Hi Dee Gee
Your Oil pressure switch is leaking from the sealing washer, the oil is then running down the barrell . The new switch will come with a new sealing washer. I would still check your Breather pipe as a precaution. Rick Nottingham |
07-15-2009, 08:38 AM
#13 |
Oddometer: 1,767
Touch wood it's sorted.
New oil pressure sensor switch as most of you correctly diagnosed. Just buttoned her back up and done approx 15 miles and so far so good! Thanks for all your help and advice DG |
07-16-2009, 12:29 PM
#14 |
Oddometer: 3,404
Pleased to hear it DeeGee.
07-16-2009, 02:49 PM
#15 | |
Oddometer: 728
, counting the days eh
If You wish to be out front, Then act as if you were behind Lao Tzu |
