Old 08-24-2004, 07:45 AM   #1
neduro OP
Addict
neduro's Avatar
Oddometer: 11,937
Neduro's Tire Changing Class
I debated on where to put this, and decided on Thumpers as we probably change our tires the most in here. Maybe it belongs in "The perfect line" but I've never been in there, and it seems to compliment Creepers excellent tube thread pretty well. So here goes.
It is a sad fact of life that motorcycle tires are a short lived affair, especially the knobbly ones that so many of us enjoy punishing in the dirt. During the summer, I change tires every other week, or at most, every third week (either putting new ones on or rotating old ones to utilize the sharp side of the knob). Because I do it so much, I have gotten better at it than I used to be, and I thought perhaps I could share that hard won knowledge.
These pictures happen to have been taken changing dirt tires, but the techniques shown here apply equally to street tires (well, maybe not the bits about rim locks and tube positioning). Later this week, I'll throw new tires on the GS and will document that as well.
Tire changes are not difficult. In putting together this set of directions, I changed both tires on my KTM at an unhurried pace, including shooting 72 pictures which took lots of time to pose, and including cleaning and greasing axles, checking brake pads, and validating spoke tension, in 54 minutes from first picture to last. I never used more than moderate force, did not break a sweat, and no curses were uttered.
A few things to have in mind as you approach this project.
1) If you are using force, you are doing it wrong. You are not stronger than the tire bead, and you don't want to be (broken beads mean wasted tire). If things are not happening easily, THINK about what forces you are putting on the tire and reposition things to align those forces with what you are trying to do. Like most things, tire changes are more a mental exercise than a physical one.
2) The devil, as they say, is in the details. A small change in position or etc can make all the difference. Pay attention to the subtleties of what you are doing. The single most important thing to notice is that the profile of the rim has a dish, or a low point, at the center where the spokes join. This dish is your friend- if the bead of the tire is resting down in the dish, it will be loose on the opposite side. If not, not even a 50 HP dirtbike can break it free.
3) Always look at the side of the tire opposite where you are working. All of the tension that you are working around is generated over there, not at the point where the tire iron is contacting the tire.
Again, these same approaches will apply to street tires as well, but I'll just focus on the pictures I have for now and worry about the others later.
Tire Removal:
We'll assume, for a moment, that you are able to get your bike situated so that the wheel in question is free, and are able to remove it, and so we'll start with the wheel off the bike and go from there.
I like to change tires using the new (or old) tire as a rest for the work I'm doing. The primary reason for doing so is to keep the sprockets and brake rotors off the floor and unbent. Lots of companies make nifty stands, but I've never been able to justify one given how well another tire works.
Step 1: Let air out. Remove the valve stem all the way, so that the tube can "breathe" as you change the volume of the tire through your manipulations. Tip: loosen the valve stem nut, if you have one, prior to letting the air out.
Step 2: Loosen (but do not remove) Rim Lock. Once the nut is loose, push the stem in to make sure that the rim lock has released its grip on the tire carcass. You may need to hit the stem with your socket hammer that you used to loosen the nut to get it to let go.
Step 3: Break the bead. On dirt tires, this is no big deal- I'm doing it here with my chaco'd foot. I can also do it by hand, if I feel like getting dirty. This is the biggest difference for street tires; we'll get to that later. If you're feeling uppity, turn the tire over and break the other side right now too, but chances are good that it doesn't really matter, that it will come free during your other manipulations anyway.
Step 4: Insert 2 tire irons, 4-6€ apart, 90 degrees off the valve stem and/or rim lock. You don't want to go opposite the stem or rim lock because then the bead can't seat all the way into the dish of the rim. You don't want to be anywhere close to them because they will make it harder to get the bead out. So, split the difference.
Step 5: Start working around tire away from initial "bite", inserting tire irons close at first and farther as the bead gets looser. Tip: if the tire is making it difficult to get the iron inside the bead, insert the tire iron just out from where the bead is crossing from outside to inside. It will be a very small bite, but it will be easy to get the iron in.
Step 6: Continue to work all the way around the tire until one whole side is off. Step on the middle of the rim and pull the tube out, taking care to ease the valve stem out through the hole in the rim.
Step 7: Flip rim and tire up to vertical, and insert tire iron as shown to pull second side toward the same as the first. Use the other iron to pull the bead off. Once you get about 1/4th of the way around, you should be able to simply jerk the rim out of the tire.
Congratulations. You are now halfway through the project.
neduro screwed with this post 03-21-2007 at 04:28 PM
neduro is offline   Reply With Quote
Old 08-24-2004, 08:04 AM   #2
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Excellent job so far. They just might have to put this in the "how to" section. There are some folks out there that have never done a manual tire change who will really appriciate you're efforts.
Ah, you think you could use a woman's foot for the rest... about a size 6 in a nice stilletto
So... how's tricks?
creeper is offline   Reply With Quote
Old 08-24-2004, 08:07 AM   #3
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,254
Originally Posted by neduro
Kewl
Do you have to wear "Alabama Safety Boots" to properly change a tire?
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Old 08-24-2004, 08:19 AM   #4
Steelhead
Dirt Good/Street Bad
Oddometer: 428
Teacher can I chew gum in your classroom?
Steelhead is offline   Reply With Quote
Old 08-24-2004, 08:49 AM   #5
neduro OP
Addict
neduro's Avatar
Oddometer: 11,937
Hey, at least I didn't go for flip-flops. Those are the true "alabama safety boots".
Looks like I'm out of bandwidth on Smugmug. I guess the rest of the report will have to wait for next month...
Old 08-24-2004, 09:29 AM   #6
neduro OP
Addict
neduro's Avatar
Oddometer: 11,937
Or, you can just give Baldy more money. $16.85 for YFF's. Hope you're grateful.
Next section- Installing a tire, coming soon.
Old 08-24-2004, 10:11 AM   #7
neduro OP
Addict
neduro's Avatar
Oddometer: 11,937
A few words before we get started on installing the new rubber.
Your primary task in installing a new tire is protecting the tube from damage. You want to make sure the tube is lying straight throughout the tire, so that it won't chafe on itself and cause a flat. You want to make sure not to damage the tube with the end of your tire iron. You want to make sure that the valve stem is nicely aligned with the hole in the rim, so that it doesn't rip the stem from the tube upon shifting.
New KTM's often locate the valve stem hole relatively close to the rim lock hole, which is very convenient for tire changes as we are about to see, although it does not help the balance any. However, many other makes will have the valve stem and rim lock opposite- I'll cover that eventuality in a moment.
Some dual-sporters like to run 2 rim-locks, to improve tire balance. I've done this, and it does help with balance, but it's a bitch to install, and no way around it. We'll save that for the advanced class. Personally, I never bother anymore. I really can't feel the difference when push comes to shove.
As above, if doing the rear wheel, it is nice to work on the side opposite the sprocket. Plan accordingly.
I do not use any soap or water- I prefer the tire to be a little sticky, so that it holds position as I work on it. Others disagree with me. Experiment and make up your own mind.
Step 1: install the valve stem and add some air to the tube. The goal is to give the tube enough body to roll itself out of the way of the tire iron or etc, without making it hard to get the bead into the dish of the rim. Another important function of adding air before you start is that it will ensure the tube lies flat, with no twists or kinks, inside the tire.
You will be hard pressed to flat the tube with your tire iron if you have added some air first.
Step 2: Install the tube in the tire (I cheated here and put the tube in the tire before adding air).
Step 3: Align tire/tube combo with rim/rimlock combo, so that valve stem is ready to pass through the hole.
Step 4: If the valve stem and rimlock are in the same quadrant of the wheel, you've got it easy, because you can pass the valvestem through the hole in the rim, and align the rimlock all at the same time.
If they are opposite, just worry about aligning the rimlock for now. I'll show pics of how to deal with the valvestem in a moment.
Aligning the rimlock- you want to push the rimlock down, so that it is between both beads of the tire and when the time comes, can suck the beads up and into the rim as it is designed to do. Trust me- if the rimlock is not inside the beads, you will not pass go, and you will not collect $200 no matter how hard you try.
Here the valve stem has passed through;
And here the rimlock has been pushed between the beads and the tire is ready to be pulled on.
Step 5: Pull the first side of the tire down onto the rim, taking care as always to keep the bead in the dish of the rim.
If you could not slide the valve stem in at the outset, here's where you do so:
Note that the valve stem is aligned with the hole it will pass through.
This picture sucks, but all I'm doing is shoving the valvestem inside the tire.
And this picture sucks too, but I'm lifting up the tire from the opposite side (the one that is already on) so that I can move the valve stem into the hole.
So, now we've got one side of the tire on, the valve stem and rim lock positioned correctly, and the second side completely off. We're in the home stretch.
Step 6: The second side of the tire. You want to start with the portion of the tire immediately adjacent to the valve stem, so that the bead of the tire won't trap the tube adjacent to the valve stem.
From there, you want to work the shortest route toward the rimlock. If the rimlock and valve stem are exactly opposite each other, whichever direction will be fine.
And finally, you want to finish the tire off 90 degrees from the valvestem and rimlock, so that they are not in the way of getting the bead into the dish of the rim. As always, take care that the opposite bead is down in the dish€
Step 7: Air the tire up. Always fill tubes slowly- not from a 120 psi compressor that's all charged up. Filling the tube too quickly can result in a twist that does not resolve itself. Bicycle floor pumps are best, but if you must use a compressor (I do), just switch it off once it hits 40 psi or so.
Step 8: tighten the rimlock- this should always be done after adding air to the tire, so that the tube has no chance of being caught between the rimlock and the tire bead, AND so that the tire has the best chance to seat evenly.
Done!
Mmmm... Fresh Meat...
neduro screwed with this post 03-21-2007 at 04:31 PM
Old 12-20-2005, 12:58 PM   #8
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,203
Found by searching for a recommeded tire from these fellas:
http://www.advrider.com/forums/showt...t=98839&page=5
I thought they might have a good opinion.
They recommeded the Mefo Stone Master, this list of tire for the Honda Transalp came up:
http://www.transalp.de/technik/reife...sicht.php#mefo
I always thought it would be great to have a dedicated tire thread, but I already have one hobby () and hoped someone else might bite.
Jerome has a nice table on his site (reposted around) for the LC4, and with combined knowledge and resources such as the one above might lead to a very useful thread.
Anyone steppin' up?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-21-2005, 10:47 AM   #9
meat popsicle
Ignostic
Oddometer: 14,203
Anyone steppin' up?
Redirect from an inapropriate thread:
Originally Posted by PASSMORE
Both of ya'll shadddup and bow to the Tera-Flex
We all know that it is the best no matter the metrics...
Now back to exhausts...
How does it compare to the Mefo StoneMaster?
Old 01-09-2006, 10:52 PM   #10
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,292
Thanks for this thread Neduro. I did the rear tonight on my 640. Took me about 4 hours. Kicked my ass. Didn't even think I'd be able to finish it, but I learned alot doing it and will do the front last night. Probably shouldn't have started it so late in the day in the winter. Was wishing for some of that Cali sunshine to heat it up. I'm beat and and I can honestly say that I've had my ass kicked by the Baja. The Michelin Baja.
Errin
Thunderbird 1 - '14 BMW F800GS ADV
"Love comes in spurts!"--Richard Hell
ErrinV is offline   Reply With Quote
Old 01-09-2006, 11:03 PM   #11
Two Dot
Two Dot's Avatar
Location: So Cal (winter) Montana (summer) NC (spring&fall)
Oddometer: 566
Errin, Can't wait to hear more about this. It sounds like a REAL adventure...
CONGRATS on your Baja adventure!!!!
03 640 Adventure
05 950 Adventure "S"
Two Dot is offline   Reply With Quote
Old 01-10-2006, 11:10 PM   #12
ErrinV
D Boon!
ErrinV's Avatar
Oddometer: 2,292
So I attempted the front today. I was able to change it within an hour, however when I filled it with air i realized that I punctured the tube so I had to do it over. Then I get it fixed and take both the front and the rear to the gas station because I couldn't get my sparrow to fit. Something's wrong with the cap. So while at the gas station I realize that not only is the bead not seated properly on the front, I had punctured the tube in the rear the night before. Damn. So end up reseating the front, and then redoing the rear. Only now, with all this experience I get them both done in an hour. So then I go back to gas station and pump them up and you guessed it. IT WORKED!!!! Go home and mount them up and rode it down the street. Now I'm just keeping my fingers crossed that the air is still in there in the morning.
So I ended up doing 1 tire change, 2 tube changes and reseating a tire today. Plus I used up my spare tubes so I'll have to get new ones tomorrow. Yesterday I only did one rear in 4 hours, so I feel much better about doing it now. Changing the tire yesterday kicked my ass becausing I was using too much force, but tonight I got the hang of it and it wasn't that difficult. The proper technique helps out tremendously. That reminds me, I need an air compressor.
Many thanks for this thread Ned.
Errin
Old 03-01-2006, 10:03 PM   #13
JOKER650
JOKER650's Avatar
Oddometer: 1,545
Am I missing something here?
Do you install the tube in the tire before you put the first side if the tire on the rim??
I have never done it like that before. I have always installed one side of the tire(with the rim lock in place) then install the tube then air it up a little then the 2nd side of the tire ending at the rim lock. I have done it like this since the 70's.........what am I missing?
JOKER650 is offline   Reply With Quote
Old 03-03-2006, 07:40 AM   #14
neduro OP
Addict
neduro's Avatar
Oddometer: 11,937
Do you install the tube in the tire before you put the first side if the tire on the rim??... I have done it like this since the 70's.........what am I missing?
Both ways work, as you know, but I think getting the tube lying flat in the tire ahead of time is easier and faster. So yes, I put the tube in the tire, then put the tire on the rim.
Unless I'm doing 2 rimlocks or the tire is really fuggin' stiff (739 A/T Desert), in which case, I do it your way.
Originally Posted by eastCOeric
Good point. How about D/S bikes or those who plate their dirtbikes?
Thanks Neduro!
PS - are you going to put on another riding clinic sometime? I couldn't make the one late last year, but it sounds great! Thx.
Personally, I never bothered to balance my sportbike tires. Others shudder in horror when I reveal this, but it never bothered me.
That said, I machined my 950 rear wheel unevenly and have come to the conclusion that this was not a good thing to do based on newfound peg vibes, and that I need to add weight to straighten it out... so maybe I'm turning over a new leaf.
Regarding a clinic- yes, I'm thinking about doing another one soon. Watch for a post in "rockies".
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
Old 10-15-2006, 02:28 PM   #15
Zen Slug
Spineless Adventurer
Zen Slug's Avatar
Oddometer: 5,947
Giving this fantabulous thread a bump because I'm about to change a tire on my own for the first time and want it near the top where I can find it
Taking the EXC to Baja next weekend and need to mount a new rear knob and ultra heavy duty tubes front and rear. Went with Pirelli MT18 rear tire on the recommendation of the guys at Scotts Performance (which just happens to be around the corner from my house) but I can already tell it's gonna be a challenge to get that stiff rubber onto my rim.
Wish me luck!
P.S. the guys at Scotts also recommended running slime in my tubes for Baja... anybody suggest when to add it and how much to use?
Edit: Well I got the rear tire off following ned's instructions without any major difficulty. Getting the new tire back on I did have to resort to R-dubb's trick of a moist paper towel with a little dish soap on it. I also had a bit of trouble keeping the opposite side in the dish of the tire, this could partly be due to the fact that I was mounting a 120 width tire on a 110 rim.
I'll put the HD tube into the 21 inch front tomorrow night... gotta pace myself
Thanks for posting this neduro!!!
"The female ass is a mysterious creature." Sir David Attenborough
Zen Slug's Rides
Join the ADV TooL PooL!
Zen Slug screwed with this post 10-15-2006 at 10:39 PM
Zen Slug is offline   Reply With Quote
Times are GMT -7.   It's 03:56 AM.
