Old 01-06-2010, 04:48 PM   #1
SUVslayer OP
SUVslayer's Avatar
Oddometer: 834
Airhead Exhaust Wrench
I know it's been posted a hundred times, but I can't find it with the search engine. I'm looking for options (cheap??) for an exhaust wrench. Who wants to get rid of a used one or knows what the new options are?
thanks
SUVslayer is offline   Reply With Quote
Old 01-06-2010, 04:57 PM   #2
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,584
IMO, you simply cannot do better than JT's tools at Northwoods: http://www.northwoodsairheads.com/Tools.html
No, we are not related, nor do I get commision.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 01-06-2010, 05:04 PM   #3
SUVslayer OP
SUVslayer's Avatar
Oddometer: 834
That looks great. Thanks for the heads up.
On another note, the reason the exhaust is coming off is because I need to replace the pushrod seals. That means all the other gaskets will be replaced. Question is, how do I know before taking the cylinder off if I need the little o-rings that go around the top studs? I'm guessing my local BMW shop won't have them in stock and I'll need to order them.
Old 01-06-2010, 05:51 PM   #4
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 988
I believe my tube seals came with some, so cheap anyway. Check Hucky out and he will set you up with all the things you need. And if you’re lucky (for the entertainment value) you will hear his wife yelling at him about the cat in the background. I love those guys.
Giving the horses and the wife a break from riding...
CurlyMike is online now   Reply With Quote
Old 01-06-2010, 05:12 PM   #5
Steve W.
Boxer Pilot
Steve W.'s Avatar
Oddometer: 316
Ed Korn Tools Cycleworks
http://www.cycleworks.net/tools_intake_exhaust.htm
Cheers
Steve
"Never say Never"
Steve W. is offline   Reply With Quote
Old 01-06-2010, 05:38 PM   #6
P B G
Oddometer: 10,001
Be forewarned, in all likelihood, the special wrench is not going to get them off, if they haven't been loosened in however many years (20? 30?) There's a good chance they are stuck and will need to be destroyed in removal.
But there's always a chance you get them free, and from here on out you can crack them loose yearly and apply antisieze.
Old 01-06-2010, 05:58 PM   #7
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Maybe an overnight spray of Kroil will help loosen them.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-06-2010, 06:10 PM   #8
norton73
drinkin'
norton73's Avatar
Oddometer: 8,317
And a little application of the blue tip wrench
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 01-06-2010, 06:13 PM   #9
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,747
man just get the o-ring seals and the cylinder base o-ring or gasket, don't be cheap and it's not worth taking the chance that your old ones will work ok. they won't, they've been compressed for how long.
For the exhaust nuts, try heating them with a heat gun before removal. If you cannt get them loose then you'll have to split them, w/ a hack saw and ordremal w/ a cutoff wheel. Cut most of the way through then split w/ a chisel. the reason you'll stop just shy of cutting all the way through w/ a hack saw is to stay away from the exhast threads on the head. A chisel will bust the nut and allow it to be removed..
Hopefully you won't have to do this. Check the threads on the head as you don't want to cross thread, if threads are a little buggered up then you'll need to chase w/ a thread file.
When putting exhaust nuts back on, coat the threads w/ anti seize.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-06-2010, 06:17 PM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,833
JT's tool is made of steel, a genuine good-for-a-(couple of )-lifetime(s).....
I have also seen the original version of the tool in cast iron, cast bronze and cast aluminum, as well as a slick head-only that you could carry on the bike, and use with a lugnut or socket wrench handle... I thought I had a picture of that one, but cannot find it anywhere....
edit: found it! made by another ADV'r "HPMGuy"
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm screwed with this post 01-06-2010 at 06:23 PM
bpeckm is offline   Reply With Quote
Old 01-06-2010, 06:28 PM   #11
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,070
I have JT's wrench, and it's a stout piece of tooling.
And BTW, I batted .500 in luck department on my ST. One nut came off the first time, and the other had to be cut free as described above. Even heat wouldn't persuade it.
And always keep in mind that yes you can always put enough torque to the wrench to get the nut off, but at some point it may bring the threads from the head along with it. If in doubt, sacrifice the nut.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-06-2010, 06:47 PM   #12
SUVslayer OP
SUVslayer's Avatar
Oddometer: 834
This was the one I was thinking of! Guy rebuilt my drive shaft 10,000 miles ago and when I inspected it it was still looking brand new. I guess it'll come down to cost...
So if I do have to cut the nut, what's the procedure for getting the rest out? dremel hack-and-chop bit by bit??
Old 01-06-2010, 08:09 PM   #13
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Won't fit older style exhaust nuts.
I bought this one, and it fits my '88 and '95 exhaust nuts fine. It WILL NOT fit the older exhaust nuts with bigger fins. I don't know what the changeover year was, but I know the /5 fins are too big.
Jim
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 01-06-2010, 06:17 PM   #14
SUVslayer OP
SUVslayer's Avatar
Oddometer: 834
I'm crossing my fingers I don't run into this problem. Seems to me they were removed at some point not long after getting the bike (can't remember why, I didn't do it) so I'm hoping it's only 8 years of neglect. Don't know how this one got away from me.
Thanks for all the sourcing tips. I cleaned all the old oil away from the PR seals when I changed the oil pan gasket and now they leak like sieves. I've made a minor problem critical
Old 01-06-2010, 07:59 PM   #15
zenben
all roads are one
zenben's Avatar
Oddometer: 595
I wouldn't risk it. If you've never had them off, then cut them loose and buy two new ones at $30 each.
In a pinch, you can use the old ones you cut loose to install the new ones with either chain grip or channel grip pliers.
If you don't take this advise when removing the left one, then DO consider it on the right. They always seem to seize on the right side for some reason.
If you are exerting what seems like a lot of force to remove the collar, it is probably b/c you are ripping the threads off the cylinder head.
zenben is offline   Reply With Quote
Times are GMT -7.   It's 03:19 PM.
