Old 02-15-2010, 03:36 PM   #1
hasenwerk OP
hasenwerk's Avatar
Oddometer: 1,326
180mm clutch disk BMW vs VW
OK... RB Racing's sprung clutches are fictional from what I have gathered from other riders. Too bad, they seemed like a nice idea! Then I started to Google 180mm clutches and kept on coming up with early 60s Volkswagen Beetle stuff... so... $48 including postage later I have a new 180mm sprung clutch disc from a Volkswagen Beetle.
Worn out R1100 GS on left, new VW Beetle on right
Both are 180mm wide. Both fit on the same on the GS's input shaft. The only difference is that the VW clutch is thicker, 9mm vs 5mm remaining on my BMW disc - I have no new BMW clutch to use as a reference - what are they supposed to measure?
The only difference is the thickness of the center hub. BMW = 20mm and the VW is 25mm - The BMW could easily be machined down by 5mm and be identical. I have yet to assemble to see if the springs get in the way of anything... but there are unsprung versions of this clutch as well.
So... the only other "real" aftermarket 180mm clutch is the Touratech four puck disc at $650 and change! Which got me to thinking about getting some ceramic four puck clutches made up... there are a few places that make custom VW clutches around...
Questions I have for the group would be:
- How thick is the stock R1100 GS clutch?
- How thick is the Touratech four puck ceramic clutch?
I am sure I could get ceramic clutches built for a LOT less money than Touratech!!
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline   Reply With Quote
Old 02-15-2010, 03:48 PM   #2
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,644
New clutch plate thickness is approx 6.4mm - be interesting to see if the center plate springs miss the diaphram spring and that you can disengage the clutch. Good luck.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 02-15-2010, 03:51 PM   #3
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,527
even if the sprung hub doesnt play out, you could always drill out the rivets, and replace your friction material for the $48 cost.
great thread!
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 02-15-2010, 03:52 PM   #4
FixxiT
Lunitic Fringe
FixxiT's Avatar
Oddometer: 953
Survivor Series:
CroMag: 04*05*09*10*11*13*14 Recompence: 10 12 13 14
FixxiT is offline   Reply With Quote
Old 02-15-2010, 04:25 PM   #5
GB
Mod Squad
GB's Avatar
Oddometer: 56,753
If this doesn't work out, you could get the ceramic clutch that Touratech sells directly from the source in South Africa for about half the price:
http://www.advrider.com/forums/showthread.php?t=335934
Old 02-15-2010, 05:17 PM   #6
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,175
You know the input shaft has a spring load shock absorber, right? Wouldn't that work like a sprung clutch hub?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 02-15-2010, 06:24 PM   #7
Oilybimmer
Oilybimmer's Avatar
Oddometer: 1,424
Sounds like a plan, my bike has the TT clutch,though it was fitted before I owned the bike, I believe that the TT one is also thicker than stock, which is why spacing washers are used to accommodate the extra thickness, the paperwork from TT suggests that these can be removed once the clutch has worn down.
Stewart
1998 GS 1100, TT hard parts, Zega panniers, MRA screen, WP rear shock, HID, keeps getting better.
PM me for drawings and dimensions to make your own Canbus fluid adapter
Oilybimmer is offline   Reply With Quote
Old 02-15-2010, 06:53 PM   #8
KShow
KShow's Avatar
Oddometer: 435
Looks like a great concept, Im looking forward to your results. clutch prices seem kinda crazy these days. I'll be watching this one....
96 BMW 1100GS- RTW 2014
04 CRF230 Plated -hers
Harley Davidson (noun) -The most efficient way to convert gasoline into noise, without the side effect of horsepower.
KShow is offline   Reply With Quote
Old 02-16-2010, 07:14 AM   #9
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,851
Stewart
Hmm, memories of shimming Ducati dry multi-plate clutches.... At least you could have those removed and in your hand in about three minutes, start to finish.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 02-16-2010, 08:08 AM   #10
mouthfulloflake
Not afraid
Oddometer: 17,527
there are VW aircooled clutch discs available without the sprung for under $20.
If I bought one and milled the hub down to fit, would this be a frugal 1100GS replacement clutch?
Old 02-15-2010, 07:01 PM   #11
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Sure would. There might be a difference in spring rate or travel. Moot point though, since the Volkswagen disk is available in an unsprung version.
On a related note, does the Vee Dub disk have a compression spring between the friction material?
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 02-15-2010, 07:10 PM   #12
Davis53
Oddometer: 573
Join
Davis53 is offline   Reply With Quote
Old 02-15-2010, 07:19 PM   #13
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,415
I worked at an independent VW shop in the 60s and changed many a VW clutch. Also, if the VW owner would spring for the extra $s, we would install a Porsche disk in the VW rendering the clutch almost industructible. BTW, I never observed worn clutch or transaxle input splines in all the clutches I replaced.
Also, I used to race with a fellow tech to see who could get the VW engine out and on the floor the fastest.........he won...14 minutes. A clutch disk swap was under an hour.
def is offline   Reply With Quote
Old 02-15-2010, 08:10 PM   #14
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
The motor R+R is always big fun at a Bug In.
Spline wear is due to a couple of things. The two issues work independently, and also amplify the other. One issue is the drive disk isn't centered on the disk spline. I don't mean that the clutch splines overhang the gearbox splines, which they do by a small amount but that isn't the problem. But that the clutch disk isn't centered on the clutch hub, it's offset to one side. The other issue is the gearbox shaft is unsupported at the crankshaft end, and supports the weight of the clutch disk without the benefit of a pilot bearing.
The offset-from-the-center drive force causes the clutch spline to deflect radially on the gearbox spline. (Maybe rotates on it's axis is a better visual, like how the Earth is tilted on its axis.) That deflection happens during the shock accelerations of gear changes, when the clutch disk rapidly changes velocity as the gearbox ratios change. The clutch hub momentarily 'tilts on the splines' if you will, and that wears away at the gearbox splines. If the drive force were centered on the spline that would not happen.
The other issue is when the clutch plate is retracted, the unsupported gearbox shaft falls against the weight of the clutch disk. This movement causes a slight misalignment between the clutch disk and pressure plate which 'tilts the splines' just as above. The effect is also the same, it slowly wears out the clutch splines.
Old 07-17-2011, 08:42 AM   #15
lwm
Oddometer: 181
I did a clutch job on a '65 VW bus in 45 minutes including putting away the tools and washing my hands.
But that was the older bus that had the panel you could remove and just slide the engine back off the studs. And I had been in there before so I knew the things that needed to be disconnected, had them all taped/labeled.
On the other hand, I'm not a pro, I was a poor college student with more time than money.
The biggest factor was that panel you removed. I did a trans replacement in a '73 bus, no panel, and I didn't know to drop the engine and trans as a unit, so I wrestled with getting the engine out in that cramped space. Took me the entire day to swap the trans that way. And a lot of cursing.
lwm is offline   Reply With Quote
Times are GMT -7.   It's 09:28 PM.
