Old 03-08-2010, 08:02 PM   #1
Valleyrider OP
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,872
1968 Yamaha DT1 Treasure/Trash?
Found this on Craigslist. Kinda suffering from PMS (Parked Motorcycle Syndrome). Raced a 1969 Suzuki TS250 back in the late '60s.
Moment of weakness and I brought this home...
Plan is to build a period type shorttracker. Keep it as much '60s as possible.
It had been repainted and also had an special shock damper on the kickstart lever for the dreaded kick back..
Someone made sure that the mag cover was on and sealed to keep moisture out...
More to come...
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Old 03-08-2010, 08:20 PM   #2
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 2,095
Not too shabby considering. Tho the mag/points scare me! Good luck!!!!
Jimmy the Heater is offline   Reply With Quote
Old 03-08-2010, 08:25 PM   #3
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
This will be a real "Old School" shorttracker.
Coils will go away and the point cam will be punched out of the flywheel.
I'm going to do a total loss ignition system where a 12 volt battery, points and ignition coil are all that's there.
Old 03-08-2010, 08:43 PM   #4
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
The light of day has done nothing for the looks of this one...
Some of the finer points that the light of day revealed...
It has a compression release!! After looking at the head, it seemed different than the DT's I remember from those days. The spark plug threaded into the head from the left side. This one is straight in from the top...
More on this a little later.
Old 03-08-2010, 09:00 PM   #5
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
Starting to get stuff taken off. Getting ready to clean and paint...
Looking at the head and cylinder, there is something different here.
Time to take a look...
Single ring piston...
Looking at the cylinder bore, there are marks on the cylinder wall,
but not normal seizure marks...?? A magnet confirms my hunch.
It's a chrome lined GYT cylinder and GYT head!!
Old 03-08-2010, 08:52 PM   #6
bsbiker
Oddometer: 3
DTs ?
Wow you are in for a lot of work! I remember back in the day the hot trick for those old DT1s was to cut the down tubes on the frame and put in a 2" spacer. It lowered the engine and made it handle a lot better.
bsbiker is offline   Reply With Quote
Old 03-08-2010, 09:04 PM   #7
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
Work.... HA... Yea your right!
I thought about lowering/adding to the frame, but I think I may wait on that at this point. Maybe in the future.
Old 03-08-2010, 09:16 PM   #8
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
Some degreasing and scrapping to get the heavy crap off the frame.
Simple Green won't even cut some of this stuff, and the pressure washer failed to get the heavy caked on guck.
Time to visit my local sandblaster...
And in keeping with my cheap@$$ motto for this project, I rattlecan it...
Valleyrider screwed with this post 03-09-2010 at 10:01 AM
Old 03-08-2010, 09:23 PM   #9
Barebow
Barebow's Avatar
Oddometer: 19
Go to YAMAHAENDURO.COM and you'll get all the info you could ever need. Great bunch of guys and a wealth of knowledge on the DT.
1975 Bultaco Alpina 350
1971 Yamaha CT1
1969 & 72 Yamaha AT1&2
1970 Yamaha RT1
Barebow is offline   Reply With Quote
Old 03-08-2010, 09:25 PM   #10
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
Thanks, went there and registered 2 weeks ago... bout time I got the bike/project.
Old 03-08-2010, 09:33 PM   #11
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
I rode a stock 72 DT-1 back in the day,ill handling would be a polite way to say it. Heavy ft end plowing tank slapping also come to mind.
I used it as a practice bike, when I jumped on my 200 Bultaco off the DT1 it was easy to go fast on the Bul. They do look neat now a days when their all shined up.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-08-2010, 09:46 PM   #12
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
The '69 TS250 I rode was about.. no, worse than a DT1 in handling, weight, and power.
If you check my flickr link in my signature, the TS185 I rode gave the 200 Sherpas a bad time back then.. and it handled great!!
Hope to get the DT1 shining soon!
Old 06-28-2010, 07:35 AM   #13
funhouse
Overdue
funhouse's Avatar
Oddometer: 3,044
don't go overboard
a virturally new one went begging in Santa Barbara last month for $400...Bruce
A life spent inside a camera: Auto/Motorcycle factories/museums/travels/trains/planes/bikes/cars
http://picasaweb.google.com/funhouse750
funhouse is offline   Reply With Quote
Old 06-28-2010, 09:14 AM   #14
TheBigO
aka The Big Square Head
TheBigO's Avatar
Oddometer: 246
Oh the memories you've brought back for me. Thank you.
Had one of these in my early teens and it was so dead reliable and fun. Keep up the good work.
'91 Honda Nighthawk 750
Character is who you are when no one is watching...
TheBigO is offline   Reply With Quote
Old 07-05-2010, 06:02 PM   #15
Valleyrider OP
I Survived The '60s
Oddometer: 1,872
This is/was the original tank for the project bike. Looks like someone may have used a large sledge hammer to tune it up. I had a bad feeling about trying to save it... That is until I met Dave Williams.
Dave tried to tack and pull the dent, but it wouldn't budge. He then cut the side of the tank off (the outside!!) and used what is mostly a lost art these days... He hammered the dent out and welded the tank back up. Paint will be applied in the next week. Dave Williams is a true Master Craftsman!!!
Times are GMT -7.   It's 10:13 AM.
