Old 03-17-2010, 12:52 PM   #1
BykMyk OP
Oddometer: 262
Replacement for cracked F8 fuel tank
As I write this, my dealer is replacing my 2009 F800GS cracked fuel tank ! It seems that the redesigned tanks are now in the system. Thumbs up to BMW NA and my local dealer.
Now let's get the bearing issue resolved and I'll be one happy dirt camper!
Nobody gets out alive....
BykMyk is offline   Reply With Quote
Old 03-17-2010, 10:29 PM   #2
klarue
klarue's Avatar
Oddometer: 235
After I saw your post, I contacted my local dealer here in San Diego - they are rock stars at SDBMWMC. They had sent out a service bulletin last week (which I missed) and new tank has been ordered. They say 2-3 weeks from Germany and I'll have it.
Gonna have them install it at the same time they are re-shoeing my steed with Anakee 2's. ;-)
'09 Magnesium F800GS - the classic
klarue is offline   Reply With Quote
Old 03-18-2010, 01:10 PM   #3
wacuff
F800GS
Oddometer: 22
Tank Already Replaced
My dealer here in Nashville replaced the new tank last week. So far so good :)
wacuff is offline   Reply With Quote
Old 03-18-2010, 02:47 PM   #4
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Had mine replaced about 6 months ago as well. No cracking so far.
Old 03-18-2010, 04:35 PM   #5
itsatdm
itsatdm's Avatar
Oddometer: 4,935
Griz you got old stock. That is why we had to wait to get the good ones,
Old 03-18-2010, 08:59 PM   #6
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
I wondered about that...... I don't know. It hasn't cracked yet and it's been six months or so. If it does I'll just get another one I guess.
Old 11-24-2012, 07:16 PM   #7
EPMD
EPMD's Avatar
Oddometer: 168
Gas tank crack
I just noticed I had the gas tank cracks on a 2009 F800GS I bought a couple months ago.
Brought the bike to my local dealer for 6K scheduled maintenance and he informed me that he should be able to replace the tank under warranty - even though the bike is past its 3 year original warranty. Apparently there is an additional warranty period of 5 years for fuel and EFI related stuff.
Free new tank hopefully!!
But he also said the same thing will happen since its the exact same part number.
EPMD is offline   Reply With Quote
Old 11-25-2012, 06:00 AM   #8
JRWooden
Oddometer: 4,267
I had not thought about extended warranty on fuel system components..............
My tank started cracking after about a year, I waited till just inside the 3-year warranty period to have it replaced,
having been told that BMW-parts warranty was 2-years from date of purchase. The new one has cracked also,
so far not very badly ... hopefully it will be cracked badly enough to not get into a fight about having it replaced next fall........ pity they can't get this right .......
Old 11-30-2012, 10:17 PM   #9
EPMD
EPMD's Avatar
Oddometer: 168
Eh?
The shop I go to is very honest and they seem to know their sh*t. He was telling me it is an ethanol issue where it is absorbed by the tank plastic causing expansion, swelling and eventually the cracking. It is affecting primarily US and Canadian bikes. Ducati is also badly affected he tells me - worse than BMW. He is on his third tank.
The good news is that it is purely a cosmetic issue and apparently no one has had a failure leading to leaking gasoline. Most likely if that were to start happening BMW would be recalling the tanks. How the swelling and cracking only affects the outer cosmetic wall of the tank I have no idea.
The bad news is that BMW won't likely be changing the tank and any replacement tank is the same part number, same problem. The switch will "buy you a couple years" I'm told.
Oh well! I'll take a new tank soon hopefully and live with some cracks when they recur.
Old 12-01-2012, 12:10 PM   #10
ebrabaek
Oddometer: 4,763
Well... In that case they don't know $h!^..... as there are no contact between the liquids, and the outer shell. Granted.... the gasses will permeate through, which is why you don't put stickers on any composite tank, but..... Ethanol does nothing to the poly ...... Tanks.
Erling
Old 12-01-2012, 03:04 PM   #11
EPMD
EPMD's Avatar
Oddometer: 168
First off, I can't speak to the effects of ethanol on plastic tanks with any authority because I am not a chemist.
But from how certain you are that it has no ill effect, I'm betting you are, so thanks for the info smart guy.
Second, it does make sense conceptually that ethanol in the main tank could cause swelling that could cause cracks in the weak points of the outer shell.
Old 12-01-2012, 06:20 PM   #12
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,743
Wonder if any of the late model Husky tanks (beneath the seat) have ever cracked? Seems reasonable to assume they are made by same production facility.....look quite similar in material on the outside.
I'm blaming the Engineers. Takes one to know one. Just sayin
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 12-01-2012, 11:52 AM   #13
JRWooden
Oddometer: 4,267
For a while I thought it might be the canister system ... but I then found out that even the Eurozone bikes still have the 2-way check valve in the vent line that is used to control the flow of vapors in the canister system...
If the inner liner (exposed to ethanol) swells it would then put tensile stress on the outer plastic "shell",
and that "ridge line" where everyone's tank tends to crack is a natural stress-raiser....
I'm open to other possibilities, but haven't really heard any that make sense...........
Old 12-01-2012, 03:23 PM   #14
runnin4melife
Oddometer: 806
I am from Missouri which adds ethanol to fuel (10% or higher) and I have had no issue with my tank... I am now in MD where ethanol isn't added where I purchase gas and I have no problem either.
Ethyl alcohol, or ethanol is a pretty gnarly solvent, but the noted trend with these tanks does not lend itself to ethanol as the culprit. Otherwise my BMW would be leaking every where and my tank is just fine as I pulled the whole thing off just the other day to make something.
runnin4melife is offline   Reply With Quote
Old 12-01-2012, 04:15 PM   #15
mbonadio
Oddometer: 25
My brand new '13 F700GS tank cracked on both sides within 2 weeks of purchase and after just 2 tanks of gas.... I'm pretty disappointed. More disappointed that I spent all this money on something that's been known bad for 2-3 years and with no signs of a permanent fix. So now, I have to live with the prospect that after my warranty period I'll have a cracked tank for the rest of it's life! I'm not too happy about it right now.... I'll keep my fingers crossed that something changes in the coming year.
But given how quickly my brand new bike developed issues, I sure do wonder!
mbonadio is offline   Reply With Quote
Times are GMT -7.   It's 05:48 AM.
