Old 06-03-2010, 03:37 PM   #1
ashrubbery OP
ashrubbery's Avatar
Oddometer: 79
Charging problems -R100RS
Hello,
Sorry for having to introduce myself by having to ask for help! I am a new airhead owner having recently bought a '82 R100RS. The bike is in good condition, no dents, paint was perfect, engine sounds great etc. etc. It had done about 8500km (53000 miles) when I bought it.
Anyway, the guy I bought it from had been plugging the bike and charging it in every day because he didnt use it much. While it was charging the Voltmeter showed about 11 -12v which is low, but he said the battery and everything was fine...mmm...
Well I had done about a week of riding, a lot of it slow , low revving riding when the bike wouldnt start. Just that click click click click click sound. So we check the battery its one of those closed batteries with out easy access. But we got the rubber seal on each of the cells off and found that the battery was completely empty. So we filled the battery up with distilled water and charged it up overnight. The voltmeter showed 13v yay! It also looked like the bike was charging when it got good rpm.
So i continue to ride it but I also notice each time the voltmeter is slowly getting less and less until it went below 11v, and well, I couldnt start my bike. This was four days later. I admit while riding the rpm would often be around 3-4, sometimes over 4rpm, and sometimes id be in slow traffic. Upon closer inspection, when the bike is revving the charging light does not completely go away but remains dimly lit!!
When I checked the voltage across the battery while revving the engine it was about 12. something volts and not increasing very much even with increased rpm. Isnt it supposed to be 14?
So what are my options and what is the most likely culprit? Alternator? Regulator? corrosion? loose wires? If it is corrosion and loose/broken wires where should I look?
What steps do I need to tack to be absolutely sure the battery is charging well? So it wont fail on me again! (planning on long trip...soon...)
Ill also check if the battery is able to keep a charge since it is a bit shady....
Thank you
ashrubbery is offline   Reply With Quote
Old 06-03-2010, 03:53 PM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
First, replace the battery.... if it is even the slightest but shady go new!
Second, someone is going to tell you to head over to Motorrad Elektric and buy Rick's book titled "Classic Boxer Charging"... unfortunately Rick doesn't have any left and isn't planning on printing a new edition any time soon.
12v is way too low, and you do have something wrong other than the battery for absolute certain... there are a number of things to check and methods to check them... my own voyage of discover his here...
"OK charging system Guru's.. WTF is up with my GS"
I would say to start by checking the rotor.... that's my guess. Although when my former R100RS had a similar issue, it was the brushes.
My current R80G/S throws about 13.7 volts at 4K rpm's.... all on the stock charging system
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 06-05-2010, 03:58 AM   #3
Twinz
Twinz's Avatar
Oddometer: 542
Originally Posted by SOLO LOBO
First, replace the battery.... if it is even the slightest but shady go new! I would say to start by checking the rotor.... that's my guess. Although when my former R100RS had a similar issue, it was the brushes.
+1
When my riding buddy's R100RS had charging issues, eventually after checking everything it turned out to be the brushes.
Twinz, Montpelier, VT
04 aprilia Futura, Ash Black - love it!
Gone but not forgotten:
'94 R1100RS, '84 R100CS, '76 R75/6 (S fairing)
'80 Guzzi V50 II, '73 Guzzi V7 Sport
Twinz is online now   Reply With Quote
Old 06-05-2010, 04:45 AM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,241
When the system is busy recharging the battery (like after a start-up) it'll read a lower voltage than when it's all topped up. And as everyone says, the volt meter tends to show a different voltage than actual - usually a volt or so less - being several connections removed from the battery, plus inaccuracies in the meter itself.
It's not the high voltage reading that matters so much as the current. But we don't use current meters so can't monitor that. I've had a system that charged at 13.5 without problems because it had very good connections with plenty of current flowing. Remember that Voltage is the potential, but Current is how much can flow. For example, a cup of water dropped from 176 feet has the same potential as Niagara Falls, but nowhere near the same current.
Old 06-05-2010, 12:43 PM   #5
ashrubbery OP
ashrubbery's Avatar
Oddometer: 79
Ya, one of the brushes was sticking a little so I think we got that fixed. That and a working battery. I just hope the voltmeter is broken, because it hovers at 11v and doesnt change much no matter what the rpm is!
Old 06-05-2010, 04:12 PM   #6
Frank06
Oddometer: 235
Mine is inaccurate as well, reading ~11 volts at idle and *maybe* 12.5 max once charged up. The key as mentioned before is to check the battery itself with a known meter then use the gauge as a guide to see if anything has changed.
Frank06 is offline   Reply With Quote
Old 06-06-2010, 02:54 AM   #7
ashrubbery OP
ashrubbery's Avatar
Oddometer: 79
hey will something like a solid state high output regulator by motorrad elektrik (http://www.motoelekt.com/charging.htm) help for better charging? The whole package looks great but I dont have that kind of money, but wouldnt mind spending $32 or roundabouts if it makes a difference.
I know a guy who was having troubles charging his bike and I cant remember if they found a problem with his regulator or he just decided to change it for better charging. Anyways he was able to get a car regulator for next to nothing and make it work for his BMW (i think a /80 or something). He mainly uses his BMW for around town trips and doesnt always use his bike every week either. He definately doesnt charge it up overnight or go on really long trips, but hes having no problems with charging or his battery anymore.
Im thinking maybe I should do something similiar even though nothings wrong with my regulator.
Thoughts?
Old 10-04-2012, 04:05 PM   #8
bushyb
bushyb's Avatar
Oddometer: 74
So what was the problem at the end of the day?
bushyb is offline   Reply With Quote
Old 01-17-2013, 12:13 AM   #9
ashrubbery OP
ashrubbery's Avatar
Oddometer: 79
Sorry for such a late response. This problem actually took two years to get mostly sorted.
What I did from June 2010 to the present.
-Got the diode box completely checked and re-soldered by a motorcycle electrical business. (didnt help)
-Brushes rechecked. (didnt help)
-Wiring checked, changed some connections to brass if i can remember correctly?
-Changed brake light to a smaller globe
-Initially changed regulator to a car regulator, then it was found that this wasnt working (faulty?) changed to BMW regulator this was found to be faulty (really?), then changed to another car regulator (cant remember what type but can check if someone is interested). This seemed to do it, the bike charges much better now.
-Replaced motorcycle battery with a full sized car battery (again i forget which type, but can check). The battery takes up all the space underneath the seat (no space for the little compartment thing that goes there).
-Fixed starter motor (bike does not struggle to start now, usually starts with one or two flicks unlike before. Means it drains the battery less at each start up).
Now im not convinced the bike is charging 100% of what it should, because the Generator light can still be seen dimly in the dark indicating a minor problem, but the bike works fine for me. It charges well in the day, charges at night with the lights on, and has no problem with doing lots of short trips in traffic (~5km).
The three main things that helped for me where
1) A regulator that seems to work properly
2) A larger battery
3) A fixed starter motor
Cheers,
Old 06-03-2010, 03:53 PM   #10
puncar thogoole
Oddometer: 238
Start with a new battery.
Go through the wiring & clean & solder connections as necessary, bad connections can cause the charge light to glow.
After cranking the bike to start it, it'll probably take somewhere around 10-20 minutes at medium to high revs to put the charge back in, so if you are doing a lot of short runs, re-starting often or riding at low revs the battery will not have a chance to charge & eventually won't start the bike.
If the above fails, then start checking components.
puncar thogoole is offline   Reply With Quote
Old 06-03-2010, 03:58 PM   #11
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,055
I would disagree.... he says that while reving the engine the charging voltage is <12v... that means there is a charging issue (most likely along with a battery issue)
If the charging was fine and the battery poor, the charging voltage would be closer to 14v than 12v
R65LazaruS
Old 06-03-2010, 04:23 PM   #12
Wirespokes
Wirespokes's Avatar
Oddometer: 8,241
Good advice. Also, don't allow the starter to do the click click click click click click click click thing. Serious arcing occurs in the starter solenoid and it'll stop working.
Old 06-04-2010, 03:53 AM   #13
ashrubbery OP
ashrubbery's Avatar
Oddometer: 79
Thanks for all your replies
So I charged my bike up overnight again (i needed to get somewhere) and it was all good.
The wierd thing is I found out that riding in 3rd gear around 4000 rpm the voltmeter shows a nice 14volts. 2nd gear will only sometimes go over 13volts at 4000rpm. So i guess maybe I just needed to push the bike a little more. Shouldnt the bike charge the same based on rpm not on different gears? Im a complete novice to the motorycle/mechanical world.
For the battery to be charging where should the voltmeter read?
Im going to get a new battery for sure, and hopefully I can have a look at the brushes as well....
10-20 mins for each start up? If youre doing a lot of inner city travel/lots of stops how do you guys compensate for the loss of battery power?
thanks
Old 06-04-2010, 05:01 AM   #14
bmwloco
bmwloco's Avatar
Oddometer: 1,485
+1 on visiting Rick's site. He is "The Man" when it comes to BMW electrical issues and undoubtedly has the fix.
> soon.
The current version is 2.0, and it is light years away from the first edition when we shot photos with a QuickCam... (look it up, early, basic digital technology... my avatar to the right is a 20 year old shot taken with a QuickCam and hand colored with PhotoShop). A lot of the information is just basic knowledge.
BMW hasn't changed airheads in a decade or more. I will bring up the issue of updating the book at the Gathering of the Clans with him next week.
'66 BMW R60/2, '83 BMW R100RS,'81 BMW R100RS "Das Beast", '87 BMW R850R '77 Honda XL125
Airhead #371
bmwloco is online now   Reply With Quote
Old 06-04-2010, 06:12 AM   #15
Jasper ST4
Guest
Oddometer: n/a
Originally Posted by ashrubbery
10-20 mins for each start up? If youre doing a lot of inner city travel/lots of stops how do you guys compensate for the loss of battery power? thanks
Battery charger and longer rides.
Times are GMT -7.   It's 02:26 PM.
