11-27-2004, 08:17 PM
#1 |
a.k.a. Mr Rico Suave
Single 320MM rotor and fancy brake on the 950?
talking with my friend Mark today about the possibility of mounting a 320MM Full floating rotor from a supermotard kit plus a sofisticated 4 piston caliper(I don't remenber the brand the are anodize gold but they are not brembo) my head got to wonder, the funny part is that I happend to be at a motorcycle hang out and a ktm 525 was park right next to my bike...
well to make the story short,,aparentlly (i did not have a accurate way to measure) the rotor bolt pattern and Inner diameter size(hub flange) are the same,also the mount for the brake caliper features a extremlly similar bolt pattern and overall shape,,ergo if you can install a motard kit on the 525EXC you can also do it on the 950 hopefully improving the performance of the braking in a big way.. at the stage this is pure gestimation and wishful thinking,,so please if you have a way to get the accurate data post it here or even better if you know anybody that ever try it..get some feetback I just don't think the lammeAss caliper that comes with the 950 is sufficient to stop the bike propertlly specially with a single rotor and then again i live for the last 10 years with the same stupid caliper in the back of the GS and let me tell you they do NOT have a Happy and trouble free life.. thanks in advance..
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore. |
11-27-2004, 08:23 PM
#2 |
The Trespasser
Some one on the board was working on this. I forget who
THE ORANGE ONES ARE FASTER! Have maximum fun while preserving bike and body 2004 KTM 950 2003 Ducati Multistrada 2001 Honda XR 400 1988 C&J Honda 625 1970 Honda SL 100 (green) |
11-27-2004, 08:33 PM
#3 | |
Good..... Mark is getting one him self so hopefully i will have something to report soon.
11-27-2004, 10:41 PM
#4 |
Oddometer: 31,202
I thought you showed a picture from someone at the Lake Elsinore race last year that had a single disc on a 950?
Jon |
11-28-2004, 12:29 AM
#5 |
100% CAROTONE
hi ricardo
the LC4ADV front single disc and caliper (with the distancial) fit perfectly on 950... i will go too to this solution with a set of excel rims
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni ciao Matteo www.barbasma.smugmug.com www.lc8.org www.adventureschool.it KTM 950 ADV S 2003 80.000 KM..... and gooooo... |
03-02-2005, 11:48 AM
#6 | |
Oddometer: 5,723
NO THEY WILL NOT!!!!! I have a set right here and first of all, the calliper is the same. Secondly the calliper hanger is different and won't work. |
11-28-2004, 12:44 AM
#7 |
Ninth of the Nazgul
Oddometer: 1,099
When you're not using your 950 for 80% off road or more (but then, why would you buy a 950 in the first place?) I don't understand this mod.
For Meoni & Co. who ride their bikes through the desert and nothing else it does make sense IMO. The rally bikes have a small and light(er) 300mm rotor from the enduro models with the standard Brembo 2-pot we have too. A big 320 floating rotor with a 4-pot caliper won't shave off much unsprung weight. BTW, a floating rotor requires fixed mounting of the 4-pot caliper. Not the stock floating caliper setup. The stock twin disk arrangement of the 950 is ok-to-good for street use but nothing more. Not nearly as good as the achors on the 12GS for instance. Amputating half the stopping power doesn't make much sense IMO. I don't think the 950 is a bike with a 'surplus' of brakes to say the least. A single 320 & 4-pot will bring back some of the lost power but by the time it gets up to the level of the stock brakes it'll suffer the same downsides off road too. But then together with the other downsides of a single disk setup too. Possible heat problems with street use but for sure handlebars pulling to one side on the brakes and twisting and flexing of the forks. Years of Supermotards learned me all the virtues of single disk setups. With the same 48mm WP USD forks btw...
11-28-2004, 03:31 AM
#8 |
Life, 2 short 4 traffic
The brake kit you refer to Ricardo is a Beringer unit.
yesterday is history, tomorrow a mystery, today is a gift, that is why we call it the present. - johnbaker |
11-28-2004, 06:52 AM
#9 | |
KTMax I was sure you will come to the rescue,,exelent posting as ussual.. more than anything my interest is to replace the Puppy look shelf brakes calipers that come with the bike with something a little more efficient,,for me the bigger rotor with the bigger rotating mass is just the price to pay for the clearance require for a widder caliper.. My self I think I'm staying with the two rotor setup, since is more simetrical, in my view (impression) most people take the right caliper when they go to the high fender just because they do not know how to route the brake hose above the tyre, well hopefully that is soon to change,,i think I figure out a way(working on it) very pennytech but very clean to run the two hoses very well protected but not decreasing the mud clearance that much.. still Interesting to see the diferent possibilies, I still think the calipers on the KTM are not that great, but also before you fix the brakes you need to make sure that the suspension can take it. thanks again for all the Input
11-28-2004, 10:38 AM
#10 | |
The Trespasser
11-28-2004, 11:06 AM
#11 | |
Personally I got the 950 because I feel I was reaching the outer edge of the GS suspension capavilities Bert..to be my "Dirtbike" more than my street bike..and then keep the GS's for transporting loads and do long tours were dirt is less of a component.but now that the swingarm broke on the 950, i'm scare of pushing the bike in the dirt, maybe i just need to get over it and hope the swing arm will never fail again or take mine apart and do a proper heat treatment to avoid stress rissers or maybe figure out a shock that will work better to take the loads,, i don't know.. so far I just DO NOT trust the bike and i check it for cracks on it everytime I ride it.. also I got to ride R-dubb's 450EXC yesterday and for sure that is a bike you can trash all you want,(if you take care of the engine),maybe i did not know better or i just don't want to get into this whole car, trailer, transport crap, but for sure this bike remind me of my bicycle days,,hell my old "Intense M-1" downhill bike feel slower to turn and track that this beautyful orange monster.
03-02-2005, 09:49 AM
#12 | |
That's MR. Toothless
Oddometer: 25,901
M [/hijack]
There. I've moved back to VA. Can you PLEASE change the weather?! |
03-02-2005, 04:56 PM
#13 | |
The Trespasser
