Old 08-18-2010, 09:52 PM   #1
MY ADV OP
"ZERO.. POINT.. ZERO"
MY ADV's Avatar
Oddometer: 489
Dont replace your fuel pump- FIX IT.
This was going to be my 4th fuel pump replacement and I didn’t want to buy a new one for $155.00 or go down the Facet pump fix. So I did some research and thanks to some fellow inmates I found a set of replacement contacts for the OEM fuel pump. It took me less than 1/2 of an hour to replace them and it only cost me $50.00.
You can order the contacts at http://www.moto-services.net/search.php Part number 18-4615
Shakin_Jake found them here for $43.00
http://www.wemoto.com/bikes/KTM/950_..._Point_Switch/
And here is a link to a how to. http://www.cbrforum.com/forum/showthread.php?t=102151
Here are a few other tips to help you get it done.
1. Remove the old contacts by removing the two screws and desolder the black pump motor lead.
2: When istalling the new contacts be sure to get the top pivot plate into the grove on the pump shaft.
3: Secure the screws and resolder the pump motor lead.
4: Before you replace the cap be sure that the cable stop (black rubber grommet) is seated all the way into the cap. I used some silicone spray to get it seated.
5: Silicone the cap and the screw. WATER TIGHT!
6: The right side is the inlet. You may want to connect the pump wire and turn your key on to make sure it works before hooking up the fuel lines.
And it's that simple.
You can't make dirt clean, so well just lemon scent it. (Modest Mouse)
2012 KTM 990R ADV (20.0K Miles and growing)
2005.5 KTM 950A ADV (106K Miles to its death by way of truck)
2005 KTM 450 EX-G (Plate)
MY ADV screwed with this post 08-21-2010 at 07:46 AM
MY ADV is offline   Reply With Quote
Old 08-19-2010, 12:23 PM   #2
dezracer
dezracer's Avatar
Oddometer: 642
What year is your bike? Will that work on internal pump on 07?
2007 990 Adventure
Suspension by Super Plush
Rekluse Pro Auto Clutch
WINGS N.O.S Exhaust
Euro Headlight with PIAA bulbs
KTM Hard Parts Radiator Cover
CJ Racer Clear Spoke Clutch Cover
Hilslamer Long Pegs
GPR Stabilizer
DH Racing tripleclamps
'300' Throttle Cam
16t CS Sprocket
Mefo "Super Explorers"
Ram Mount Garmin 76c
PABIKER sidestand relocaton kit.
2007 KTM 300XC (long live lightweight 2-strokes)
Las Vegas, NV and the Great Mojave Desert
dezracer is offline   Reply With Quote
Old 08-19-2010, 05:54 PM   #3
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 834
just out of curiosity , why not go with the facet when its $58 ? and probably will last much longer..
cheers
guy
nomad guy is offline   Reply With Quote
Old 08-19-2010, 06:33 PM   #4
MY ADV OP
MY ADV's Avatar
Oddometer: 489
Why not the Facet?
cheers
guy
Less trouble trying to get all the parts and bits and best of all, there are no modifications needed to the fuel system. The OEM pump is what the bike was designed with and has the proper pressures and all of that. My pumps on average have lasted a bit longer than the water pump shaft and seals. So I would recommend replacing the pump contacts and the water pump shaft and seals at the same interval.
MY ADV screwed with this post 08-19-2010 at 06:40 PM
Old 08-19-2010, 11:04 PM   #5
David P.
David P.'s Avatar
Oddometer: 356
Yes and no. It was probably the cheapest they could get since they raided the Honda factory´s trash bin and found the only reliability flaw of the AfricaTwin; the fuel pump. And they didn't care that fuel pressure was way too high and that you can't use it for serious trail riding and that they burn out like candles...
Get yourself a vacuum pump and stop worrying!
KTM 525 - 2007, Raid Designs MRS Ed.
www.RaidDesigns.com
David P. is offline   Reply With Quote
Old 08-20-2010, 12:44 AM   #6
Sandman 950
Sandman 950's Avatar
Oddometer: 237
QUOTE DavidP: you can't use it for serious trail riding and that they burn out like candles...
Show me a candle that lasts 18,000miles of serious trail riding...(1st set of points last month!)
KLX 250Fi
270 REV3
PUCH MAGNUM X
CBR600FA-B
...and too many bicycles!
Sandman 950 is offline   Reply With Quote
Old 08-20-2010, 05:09 AM   #7
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
+1
$50 you can get 2 new vacuum one's as well. or a pump & a couple of rebuild kits.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 08-20-2010, 08:05 AM   #8
BronsonRacing
Oddometer: 13
Is it the very same pump thats on the Africa Twin? If so i've a spare one kicking around somewhere cos i went the facet route on my old AT. And from what i understood it was only the pumps on the early Twins that gave trouble?
BronsonRacing is offline   Reply With Quote
Old 08-21-2010, 08:53 AM   #9
zDollar Bill
Eat, Sleep, Ride, Repeat
zDollar Bill's Avatar
Oddometer: 972
I don't think 89,000 miles on the factory pump is too bad? Thats how long my points lasted in my cbr600f3...
zDollar Bill is offline   Reply With Quote
Old 06-17-2011, 02:06 AM   #10
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
What interval are you having to change the water pump shaft and seals.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 06-17-2011, 01:23 PM   #11
MY ADV OP
MY ADV's Avatar
Oddometer: 489
New points with New water pump.
I had changed my water pump at 60K miles and the fuel pump points at 70K miles. I just finnished my 80k mile service and replaced my water pump and the points on the fuel pump looked good. I think I'm going to go with the DR Bean fix for my next fuel pump repair.
20K miles between water pump service. Seals and shaft were worn but not leaking.
15 to 20K miles for fuel pump.
MY ADV
Old 08-19-2010, 06:43 PM   #12
MY ADV OP
MY ADV's Avatar
Oddometer: 489
I don’t think so DEZRACER. The 990 pumps are completely different. These pumps are for the carbureted models. I know, one day I’ll stand upright and stop dragging my knuckles and get the 990.
Old 08-19-2010, 11:00 PM   #13
shakin_jake
F-u-h-r-i-ggg!
shakin_jake's Avatar
Oddometer: 223
Nice write up!, and thanks for the link to the CBR forum which shows a little more detail. I have this same job up and coming and your tutorial will help a simple man like me quite a bit=:-)
BTW, I bought the exact same point kit a week or so ago from a UK parts reseller here-
Price was $43 delivered to my door, including overnight international shipping (Fed-Ex) to boot. wemoto rocks hard!
I agree with the premise of rebuilding the OEM fuel pump. With a good point set, the original equipment pump works well. I'll be rebuilding my water pump soon and will do this fuel pump rebuild at the same time. Since the water pump needs a regular rebuild, it only makes sense to fit new points to the fuel pump at the same time. FWIW there is currently 14 K miles on my 05.5' KTM ADV, still on the original fuel and water pump. I'm 3rd owner of this bike
Jake
Reddick Fla.
shakin_jake is offline   Reply With Quote
Old 08-27-2010, 11:26 AM   #14
crazybrit
crazybrit's Avatar
Oddometer: 8,559
Bad link. Looks like you pasted the ADV compressed link (...) rather than expanding it and pasting the real.
crazybrit is offline   Reply With Quote
Old 09-06-2010, 11:10 AM   #15
MY ADV OP
MY ADV's Avatar
Oddometer: 489
Points available in the U.K.
This is for our fellow inmates on the other side of the pond.
Sorry Crazybrit... didnt think I needed to hold your hand.
Times are GMT -7.   It's 12:54 PM.
