Old 09-09-2010, 05:39 PM   #1
CHRIS_D OP
CHRIS_D's Avatar
Oddometer: 903
How do you remove the front brake pads?
Well I'm a bit embarrass . I'm trying to replace my front brake pads on 08 ADV and I can't seem to remove the pin that holds the pads in the caliper. I have removed the one (only) clip that holds the pin in place, but can't figure out how to unscrew the pin out of the caliper. There's no head on pin to stick a hex wrench or screwdriver on. The rear brake pads have the "normal" two clip deal which once both clips are removed it makes it easy to remove the pin. What in world am I missing here on the front?
Thanks in advance!!
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 09-09-2010, 05:49 PM   #2
Johnf3
Oddometer: 1,048
Thanks in advance!!
They just tap out. Use a drift punch and a hammer. They should come right out.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 09-09-2010, 07:12 PM   #3
thugdog
Druid Revisionist
thugdog's Avatar
Oddometer: 396
+1, firm but gentle tap, tap, tap
...also note, just in case you get super frustrated, please NEVER apply flame/heat after using brake cleaner spray!
....there's nothing more permanent than a temporary solution
thugdog is offline   Reply With Quote
Old 09-09-2010, 07:26 PM   #4
flyingreg
just ridin' along
flyingreg's Avatar
Oddometer: 242
LOL, the picture that went through my mind as I read that line, totally priceless.
Greg
"Illegitimis Non Carborundum"
2010 KTM 990 Adventure
flyingreg is offline   Reply With Quote
Old 09-10-2010, 05:04 AM   #5
CHRIS_D OP
CHRIS_D's Avatar
Oddometer: 903
Thanks for the replys!
I did try to push it out with a punch but didn't want to start hammering on it until I was sure.
Old 02-16-2013, 01:50 PM   #6
bikepsych
Oddometer: 162
Did you get it out?
Bruce
Camarillo, CA
2011 KTM Adventure 990
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 02-16-2013, 03:28 PM   #7
DirtyADV
DirtyADV's Avatar
Oddometer: 2,199
Originally Posted by bikepsych View Post
Did you get it out?
Sure hope so since it was 2 years since he posted.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 02-19-2013, 03:40 PM   #8
Sadlsor
Oddometer: 691
/Johan
Ha! That's a good one.
But in the event he DIDN"T get the pin out, I'd bet he needs new rotors now, too... and pistons.
You must be the change you wish to see in this world.
Sadlsor is offline   Reply With Quote
Old 02-21-2013, 06:51 AM   #9
CHRIS_D OP
CHRIS_D's Avatar
Oddometer: 903
Yes I got the pin out.
Old 09-04-2013, 07:11 PM   #10
bluesurf
en dos ruedas
bluesurf's Avatar
Oddometer: 1,004
at this thread....I'm swapping my 990's out for the first time, and went through the same exercise of trying and not wanting to hammer too hard, so thought I'd consult the forum.
Thanks for the instrux & chuckles
Ride Travel Explore Live
bluesurf is offline   Reply With Quote
Old 09-05-2013, 05:43 AM   #11
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,942
I have to say that pin is the suckiest thing - makes a changing them when you are travelling just that little more difficult than it needs to be.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 09-05-2013, 06:19 AM   #12
Sadlsor
Oddometer: 691
Oh, and one more thing...
Whenever I change the brake pads, front or rear, I always put anti-seize on the pins before replacement.
I'm sure there are other chemical compounds that will work.
The pins always come out easily, once the small cotter pins are removed.
Old 09-05-2013, 09:39 AM   #13
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,942
With the right tools they out easily but as a traveller doing some where other than their garage it isn't as friendly as it could be. The rears are much better I just want to do it with the minimal of tools.
Sent from my GT-I9305T using Tapatalk 2
Old 09-06-2013, 04:32 AM   #14
Oz Nutter
Oddometer: 1,230
Wink Love those pins....
I used a pin head punch to take out brake pin.
A tyre lever in between the pads is good too hold it steady, (place foot on lever)
I found my last replacement pads to be very tight when new, could hardly push bike!!
Oz Nutter is online now   Reply With Quote
Times are GMT -7.   It's 03:15 AM.
