Old 09-29-2010, 06:39 PM   #1
ebrabaek OP
Oddometer: 4,727
Talking Hid install .....With pictures......
I know that there are other threads covering this install...... But none of them covers any before and after pictures....... So I thought I`d post a new thread. I also decided on a little different mounting than most decide to do. I looked at it once.....and......ehhh.... yep..... one.....must.....make......a....carbon fiber....bracket....... Really..... Most people elects to put the ballasts on the middle bracket behind the brake line..... I wanted to illustrate a different way to make a composite bracket. Most of the composites I make....is on the outside......, but this stuff ,can be used in many applications. This one took a total of 30 minutes to make. I wanted the ballasts up in the front behind the fairing.......And first had to make a bracket that would serve as a mold for the composite.....
Then cover it with aluminum foil so the epoxy won`t stick.......
I used 4 layers of 5.7 oz. 2x2 twill carbon fiber......max-clr hp epoxy....... Done and installed the ballasts.........
I will route the wires in the morning........and post back tomorrow night....with the after pictures. The HID`s are H7`s from 1off motorsports..... I used m4 ss hardware....and 3 threaded 3/4 inch collars...to create a 6mm space between the ballasts for cooling purposes. I called and asked 1off motorsports....they said that I could mount them on top of each other.....but just to be safe......Until then.....
Erling
Old 09-29-2010, 08:36 PM   #2
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 395
I installed one of their HIDs as a replacement for the low beam... Awesome bright lite! I see you are installing two... so are you also replacing the high beam with HID, or are you going to totally blow us away and somehow intall them on those new CF handguards?
Inquiring minds.... O)
BMW_BIKER_KEITH is offline   Reply With Quote
Old 09-29-2010, 09:00 PM   #3
ebrabaek OP
Oddometer: 4,727
Hi-Hi..... Evil genius at work..........Nahhh.... In the future....there will be a set of high power led blinkers in the guards.......... The other is for the high beam. Not the norm..... But here in the desert southwest.... when I ride at night..... I do use the high quite often...... Whereas if you live in La....perhaps not. Like in many car applications, where only the low beams are hid`s.....when you flick on the highs.... It`s a very disappointing result. Lots of people states that it does not work for flashing...... But in all practicality.... After the arc has been struck once while riding...... It flicks on very fact.... every bit as fast as it`s halogens counterpart. So I opted for the dual setup. Another thing...... The 1off motorsports setup strikes the arc at a full 55watt, so not to create any issues with the canbus..... When it stabilizes..... It lowers to 35 watt.... The latter I confirmed with a amp meter.....
Erling
Old 09-29-2010, 09:03 PM   #4
ebrabaek OP
Oddometer: 4,727
So for starters.... Here are the before pictures....with stock halogens..... Among some of the best stock halogen MC lights....imho......
Low beams.....
High beam......
We shall se tomorrow......how many hot spots the hid`s will create......
Erling
Old 09-30-2010, 04:09 PM   #5
ebrabaek OP
Oddometer: 4,727
In routing the wires....I found it much easier to feed the loom through the 7/8 inch hole I just drilled....If I took apart the feed connector..... You use a small screw driver to push on the little pin inside....then the plug slides out....
Then after feeding it....when you put the connector back together....this is the little tap you bend in the prior step....bend it back again....insert the prong in the plug.... Note where plus and minus is....
This is how it looks out of the housing.....
Then zip tie the wires in the front...
Then re-check all is working.....
Time for a few shots of espresso.....wait until darkness.....I`l post a few pictures later.......
Erling
Old 09-30-2010, 06:46 PM   #6
TowPro
Lets ride
Oddometer: 3,167
When you turn the front end, how bad does the brake hose get tied in your wires? I brought my HID connector out the same place, but had to pull the wires to pretty much a right angle at the rubber connector to keep the brake hose from hitting on them.
I plan on adding bar risers at some point, so that will move the brake hose out of the way a little :)
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is online now   Reply With Quote
Old 09-30-2010, 07:29 PM   #7
ebrabaek OP
Oddometer: 4,727
Not at all..... But I have a 19 inch brake line rather than the standard 17 inch.... Plus my cockpit is raised about one inch,
So perhaps mine is not the best to compare with.....
Erling
ebrabaek screwed with this post 09-30-2010 at 08:34 PM
Old 09-30-2010, 08:41 PM   #8
ebrabaek OP
Oddometer: 4,727
Pictures....before, and after...
Here are the comparison pictures...... Same road..... Same parked car in the front.......
Halogen low beam....
Hid low beam......
Halogen High beam......
Hid High Beam.......
The first thing that gave it away.... was the fact the camera had trouble focusing on the halogen low beam...... When the halogen high beam was added...it was fine..... It focused fine on either Hid beam..... The picture of the halogen is " enhanced " by the camera`s shutter, and is really yellower than it appears. In general this very great stock light is now greater......with very little hot spots. Very pleased.......
Erling
Note......The beam drop is not identical..... I goofed and took the first pictures ( stock halogen) with the bike on centerstand....., and HID off the center stand with me standing up straddling the bike..... Sorry I did not catch that It really only has an affect on the low beam...... as the stock halogen high beam is illuminating the house far down the street...... Note as well that you can make out the fence in front of said house with the hid......Not really with the halogen.
ebrabaek screwed with this post 10-02-2010 at 05:33 PM
Old 11-04-2011, 03:41 PM   #9
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I went with the DDM HIDs. Tucked the ballasts & ignightors in the side fairings with sticky backed strong Velcro.
Only complaint is the cut out on the low beam is not in the right spot now. Have to play with the alignment of the light a bit and see if I can fix it.
Ride more, bark less
Gangplank is offline   Reply With Quote
Times are GMT -7.   It's 12:07 PM.
