11-11-2010, 06:47 AM
#1 |
What? Me hurry?
DR650SE Index Topic#13- PROBLEMS/FAILURES
DR650SE Index Topic#13- PROBLEMS/ISSUES
Lucky 13... how about some bad luck stories . For such an inexpensive motorcycle, the DR has proven itself remarkably reliable. A few problems have been observed over the years. Some relatively minor, others catastrophic. While epic failures like the third gear problem are dramatic and troubling, they are still very rare.Share your fixes, dodged bullets and, yes, your disasters... ![]() -HEADER WELD -BASE GASKET -CAMSHAFT CHAIN TENSIONER (CCT) GASKET -UPPER CHAIN ROLLER -STARTER BACKLASH -NEUTRAL SENDING UNIT [NSU] SCREWS -3RD GEAR FAILURE |
11-11-2010, 07:33 AM
#2 |
Butler Maps
Oddometer: 14,580
none for me
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
11-11-2010, 03:22 PM
#3 |
Life behind "Bars"
Oddometer: 6,354
I had an electrical fire in the main wiring harness. Destroyed the whole wiring system. A fellow DR650 ADV'r sent me one from his parts bike just to help an old guy out. Thanks Steve
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
11-11-2010, 03:40 PM
#4 |
Southern Explorer
Oddometer: 1,238
NSU screws do need to be checked, one of mine had started to come out. Wasn't even finger tight. Check those suckers!
I did the lock tite and star washer method. It was a good practice session to learn about the clutch too, mine was still like new. Then again I was only at 6K then.
11-11-2010, 04:13 PM
#5 |
Gitchee some !!
Oddometer: 208
Its never happened to me,but...
I bought my bike (a 99 that didnt have a limiter from the factory) from a gent who "forgot" to tell me about the boss that holds a gear in place explode on him and tear the boss in half, then he had it repaired (slob weld job). I found the repair after I had a bolt break off the fly wheel and proceeded to chew up my stator.
Instead of attempting another weld job that probably wouldnt last I decided the best course of action would be to bite the dust and replace the motor cases, I'd rather do it rite as have to waste my time and money (quite a bit by the time its finished) on a roll of the dice. By chance you own a 98 or 99 model and havent put in a tourque limiter, do so ASAP, An idea of the cost involved...motor cases (new) $700ish (used)$300/$400, service manual $65 new, specialty tools (must have) fly wheel puller $80 the rest of the tools you can improvise becuase some run at $200 a piece, Gasket set $80/$160 (depends), labor bids ran $500 to $700 (main reason I'm gonna do it). A lotta hassle and cash for a $170 part.
Pavement...we dont need no steenking pavement. |
11-11-2010, 04:54 PM
#6 |
Oddometer: 445
base gasket
I have a 2003 with about 5k miles complete with leaky base gasket. Recall Suzuki switched from a paper to a metal gasket in approximately '03. The leak acts like a pinhole spitting tiny droplets of oil as the motor revs. A nice bead of high temp silicone has effectively taken care of the problem. I'm planning to take this bike through South America next year and have no plans to replace the leaking gasket.
12-18-2010, 07:24 PM
#7 | |
Oddometer: 72
THATS THE TRUTH!!
11-28-2010, 09:00 AM
#8 |
What? Me hurry?
Krusty ... screwed with this post 12-21-2010 at 11:48 AM |
12-08-2010, 07:14 PM
#9 |
Oddometer: 2,611
NSU Information
The Neutral Sending Unit screws have been known to loosen themselves and find their way into the tranny gears, not good. Does not seem to be related to model year or mileage. It's a small percentage failure number, but a big disaster $$$ if it happens. After removing the clutch cover: remove, clean screw threads and holes, then Loctite or safety wire. I prefer safety wire.
So if your neutral indicator light quits or starts acting funny...... ![]() http://www.advrider.com/forums/showp...ostcount=33543 mx_rob: "One point though on the screw just gently falling out and settling on the bottom. The hurricane turbulence of the clutch basket and gears in the oil can easily sweep the screw up into places that would be a major bummer for it/them to be." Like these two pics: http://www.advrider.com/forums/showp...ostcount=49541 http://www.advrider.com/forums/showp...ostcount=49542 Here's how: http://www.thumpertalk.com/forum/sho...9&postcount=38 Thanks to LukasM, pics are worth a thousand words: http://advrider.com/forums/showpost....ostcount=19784 http://advrider.com/forums/showpost....ostcount=19799 Mine only has the single blue wire: http://www.advrider.com/forums/showp...ostcount=33214 2laneblacktop's step by step and NSU screw sizes: http://www.advrider.com/forums/showp...ostcount=26847 The two NSU screws, the pin and spring hiding behind the NSU, looking to escape: http://advrider.com/forums/showpost....ostcount=57707 ![]() TREE posted this, I think a good solution: This is the plan for my NSU bolts . . . easy to wrench and then they will be lockwired. http://i64.servimg.com/u/f64/11/94/64/62/bolts210.jpg plodalong posted his idea: http://www.advrider.com/forums/showp...ostcount=33685 Dyno: http://www.advrider.com/forums/showp...ostcount=33257 The oil pump drive gear is some sort of resin/fiber construction, so I replaced it (at 15,000 miles). It's $19.94 and #7 here: http://www.bikebandit.com/2004-suzuk...5873#sch502975 There is also a seal in the clutch cover I'd replace while in there. It's shown in the middle photo on page 3-42 in the service manual. It's on the crankshaft page, #10 here: http://www.bikebandit.com/2004-suzuk...5873#sch502988
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. ER70S-2 screwed with this post 12-12-2012 at 12:28 PM |
12-12-2010, 12:46 AM
#10 |
Mountain scaling freak
Oddometer: 63
I had my rear brake light shake loose at about 7000k and the Cam chain tensioner gasket leaked at around 5000k miles. I believe that was from over servicing though. Other than that, no problems.
"Death may be the greatest of all human blessings." -Socrates |
12-12-2010, 12:42 PM
#11 |
Oddometer: 2,611
Oil Leaks
Near spark plug, starts here, with a few following posts:
http://www.advrider.com/forums/showp...ostcount=35690 Including: http://www.advrider.com/forums/showp...ostcount=35695 And:
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. ER70S-2 screwed with this post 12-29-2011 at 10:32 AM Reason: Added Pic |
03-31-2012, 11:04 PM
#12 |
Armature speller
Oddometer: 6,845
04-01-2012, 04:09 PM
#13 |
still 20 in-my-mind
Oddometer: 344
02-20-2013, 07:35 AM
#14 |
Butler Maps
Oddometer: 14,580
Originally Posted by Rob.G View Post A lot of people strip those screws... they're actually not philips. They're a Japanese "standard" (I forget the exact term)... but if you look closely, they aren't tapered like a true philips.. the slots go all the way down completely. There's a special tool you can get to remove them, but it sounds like you already solved the problem. :) Rob ----------------------- JIS screwdrivers - http://www.webbikeworld.com/motorcyc...-screwdrivers/ http://www.amazon.com/Hozan-JIS-4-JI.../dp/B005NIY3PM the special tool for most is using a hand-hammer impact tool. http://www.harborfreight.com/impact-...ase-37530.html http://www.sears.com/craftsman-impac...p-00947641000P http://www.harborfreight.com/7-piece...set-93481.html - light duty one for smaller fasteners. i've used a dremel tool in the past with a thin cutoff wheel and made a slot for a flathead screwdriver to work. later found out the trick, if you only have Philips screwdrivers, is to use the next size smaller one (so it gets the tip down in deeper in the JIS screw) and tap it from the top with a hammer. this helps drive the tool head deeper into the screw and also shocks the screw some to loosen it. if the screw is somewhat buggered up, from previous attempts, tapping the screwdriver in harder can work. often the steel screw, alum. cap & brake res. main body somewhat fuse together if the fluid has never been serviced. here is a way to modify Philips bits/screwdrivers to fit better in JIS: http://www.kzrider.com/forum/21-tool...rewdriver-tips when dealing with the JIS screws on the floatbowl, the same technique can be used but often those hand-hammered tools is key. that is 1 essential tool that every home mechanic should have! once you have those screws out replace with allen bolts from PC, Jesse or the hardware store.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps eakins screwed with this post 02-20-2013 at 10:09 AM |
03-01-2013, 10:10 AM
#15 |
Butler Maps
Oddometer: 14,580
Start squeal noise and fixes
http://www.fy-yff.com/2011/08/squeak...-easy-fix.html http://webpages.charter.net/jrandall...tarter_fix.htm http://www.advrider.com/forums/showthread.php?t=832297
