Old 11-15-2010, 08:09 AM   #1
KnuckC OP
F8er
Oddometer: 199
Replacing rubber skid plate mounts?
Did an end of the season check on the condition of my Touratech skid plate which was installed by the dealer when I bought the bike. Not pleased to find that three of the rubber mounts were sheared off and the fourth 1/2 sheared. Not pleased with the installation or the skid plate itself. It does not protect the pipes.
Does anyone know how to replace the rubber mounts? It appears that the bottom plate of the oil pan has to be removed.
KnuckC is offline   Reply With Quote
Old 07-24-2011, 08:24 AM   #2
99p38a
99p38a's Avatar
Oddometer: 322
bump.
Which one works on the 1150 for the front? is it: http://www.mcmaster.com/#9376k213/=dbdoi2? what about the rears?
Brian
Mid-Michigan, USA
2001 BMW r1150GS
99p38a is offline   Reply With Quote
Old 11-15-2010, 11:13 AM   #3
KnuckC OP
F8er
Oddometer: 199
Originally posted by AlanI:
I don't see why. From my reading of the pdf instructions for the fitting of the skid plate the 4 supplied TT bolts are a direct replacement for the OEM bolts which are simply screwed in to a torque of 8NM. My guess is that for replacement bolts you'll have to go back to TT.
It isn' the bolts that are the issue. On my bike (2010) the rubber mounts appear to be mounted directly to the oil pan on the bike. The skid plate, be it Touratech or something else, screw into these four rubber mounts. What has happened is that the rubber, which is about 1" thick x 3/4" wide, has broken in half horizontally so that there is about a 1/2" x 3/4 " piece of rubber still on the oil pan and there is no bolt thread in that portion of the rubber that attaches it to the oil pan.
On your bike, dos the bash plate attach directly to the metal of the oil pan or to rubber mounts?
Old 11-15-2010, 11:42 AM   #4
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Regardless of what the RSD does or does not say, the rubber mounts should be screwed into the oil pan just over finger tight to facilitate removal when they shear. Either way, removal of the oil pan won't help, the threads are cast in, there's no access from inside the oil pan.
There's a hex shaped plate the same size as the rubber at both ends of the mount.
Usually a socket on the hex shaped rubber and an impact will spin the broken mounts out. If not, prying with a screw drive in a circular motion always has for me.
The mounts are made to damp and resist impact. Shear forces should be carried through the front bolt.
Some skid plates protect the mounts from sheer better then others.
The BMW metal skid plate resists sheer well and protects the can, wink, wink ;)
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 11-15-2010, 11:49 AM   #5
KnuckC OP
F8er
Oddometer: 199
Thanks Joel and AlanI.
I just spoke to Touratech. Their design is really poor. I strongly recommend against using their skid plate. Not only does it not offer any protection from the front wheel sending rocks into your pipes but it is also designed to break. Their system uses a rubber mount that is screwed into the oil pan. Rubber makes sense here because bolting a hard plate directly onto the pan can cause damage to the pan from impact. Their design however is the problem. They bolt the rubber mount onto the oil pan and then use a separate screw to attach the bash plate to the rubber mount. The screw goes in about 1/4 inch and is only supported by rubber for the most part. As a result, vibration causes the screw to eventually sheer the rubber in half leaving a very difficult bolt to remove form the pan.
If you ride alot of rocky dirt, DO NOT BUY THE TOURATECH PLATE.
Now I have to figure out how to get the bolts out off the oil pan. Joel do you know the size of the socket?
Old 11-15-2010, 02:10 PM   #6
KnuckC OP
F8er
Oddometer: 199
Joel, don't worry about it. With a little effort and your advice I got them off.
Old 11-16-2010, 12:52 PM   #7
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Hey KnuckC,
A customer of our posted that he used anti-seize when he re-installed the BMW breakaway skid plate mounts and I think that is a great recommendation! That will end any possible problem/frustration of getting broken mounts out later.
We will be adding that to our instructions.
The mounts are a standard BMW part and available at any BMW dealer.
As I mentioned in another thread we have designed our front bracket to be stronger than most to help support the breakaway mounts and prevent minor impacts from breaking them. It is still however designed to be "sacrificial" and bend in the event of a significant impact thereby protecting the engine block.
More info on the thread here:http://www.advrider.com/forums/showt...536723&page=13
Thanks for your email and interest on the MOD skid plate too and please ask if you have any more questions!
See you out there!
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 11-16-2010, 08:03 PM   #8
KnuckC OP
F8er
Oddometer: 199
Hey Dave,
I just picked up your V2 skidplate. Will Locktite work as well as antiseize?
Old 04-26-2013, 05:54 PM   #9
moe.ron
I got nuthin'...
moe.ron's Avatar
Oddometer: 2,601
I have been using the Touratech plate with no issues, I got mine second hand. It has gone above and beyond the call of duty. Mine is extremely bashed and dented, the mounts have not sheared off and there is no damage to my pan whatsoever. I actually just replaced it with the same one because thats just how beat up it is. Bought the black one this time.
There are plates out there that offer better protection for sure, at 2 and 3 times the price. For a $125 bash plate mine has served me very well.
Pig Can Fly.
moe.ron is offline   Reply With Quote
Old 04-27-2013, 01:55 AM   #10
Snowy
Oddometer: 1,665
I bought the BMW bash plate and have bent, dented and scratched crap out of it. I replaced the rubber mounts after a bit of log crossing in the snow. 2 rubbers had sheared, one partial shear and one was loose. The front mount was damaged.
BMW wanted about $70 for a set of mounts. I used anti seize on them and use my little battery rattle gun when I fit them. Have done several oil changes and not had issues.
The factory bash plate will move enough to dent the header pipes. It's relative to how hard you hit things. Lift the front over a log and land hard on the bash plate like you'd do on a 250 and you'll break stuff.
Snowy is offline   Reply With Quote
Old 05-23-2014, 10:46 PM   #11
The Maz
Savage
The Maz's Avatar
Oddometer: 48
Pissed shear bolts
man, I must not know my own strength! Barely tightened bolt on skid plate mount and the bolt sheared right off. Not the rubber, but the bolt.
Well I guess it's off to an automotive store for some vibration isolating bolts...
Sigh..... Not eaven a 1000 K on the bike yet.
Just to make sure, it's a M8 X 1.25?
Sweet Potato Pie!
2014 F800 GSA
2008 KLR 650
The Maz is offline   Reply With Quote
Times are GMT -7.   It's 10:24 AM.
