Old 11-25-2010, 05:04 AM   #1
Migs OP
Migs's Avatar
Oddometer: 165
Deactivate the ABS while moving? F800GS
Friends:
Is there some way to deactivate the ABS while moving? Are there any special tricks related to ABS on the F800GS?
Migs
"I consider myself a road man for the lords of karma"~Hunter S Thompson
"He who is not afraid will always be safe." -Lao Tzu
"Do not be bothered by anything."-S. Suzuki
Migs is offline   Reply With Quote
Old 11-25-2010, 05:38 AM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 56,741
You must STOP, press and hold the ABS button till the brake light glows red and then continue. There's no need to turn the engine off. When you want to re-activate it, you must stop, press the button again and go.
The ABS wheel sensors must not be sensing a rotating wheel in order for this to work, that's why you must stop. I have never seen any bike with switchable ABS where you can turn it off while the bike is in motion as a factory setting. On the SuperTenere 1200 since it does not have an ABS switch, someone made one, so you can turn it off at any time.
Old 11-25-2010, 05:48 AM   #3
Migs OP
Migs's Avatar
Oddometer: 165
Thanks GB! My ideal would have been to figure out a way to turn it off on the go. Because I forget sometimes. (Most of my riding is off road or dirty slimy road).
Migs
Old 11-25-2010, 06:00 AM   #4
GB
Mod Squad
GB's Avatar
Oddometer: 56,741
Migs
you can't, without triggering a brake fault code and cutting into the bike's harness, such as running a switch to one of the ABS wheel sensors.
Old 11-25-2010, 06:46 AM   #5
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Not exactly true, GB. On the F twins you only need to slow to <5 mph to disengage the ABS. It's in the owner's manual, and I've verified this myself a few times now. Granted, it's often easier to just come to a full stop. But you don't have to.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 11-25-2010, 07:05 AM   #6
GB
Mod Squad
GB's Avatar
Oddometer: 56,741
Well, since the speedo doesn't exactly show speeds at or below 5 mph, the bike is basically nearly stationary and barely self balanced, might as well put a foot down, disengage it and ride off
Old 11-25-2010, 07:53 AM   #7
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,764
Hey, do you have to be in neutral?
For some reason, I've done it a million times and I can't remember if I ever tried it while in gear (stopped or moving), mostly habit for me to put it in neutral when I come to a stop for ABS....
EnderTheX is offline   Reply With Quote
Old 11-25-2010, 11:09 AM   #8
Migs OP
Migs's Avatar
Oddometer: 165
I read somewhere that all you have to do to be in permanent non-ABS is to cover up one of the ABS sensors (like with Duct tape). Anybody tried this?
Old 11-25-2010, 04:09 PM   #9
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
Nah, pull in the clutch, hold down the ABS button, and off you go!
David
David
--Curly
Old 05-17-2011, 03:59 AM   #10
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,378
Originally Posted by Desert Dave View Post
If this is the best it can do it's far from a transparent system.
Transparant? As in "I don't want to know when the ABS kicks in"?
That would scare me more I think.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 05-17-2011, 04:09 AM   #11
Desert Dave
Enjoying the moment
Desert Dave's Avatar
Oddometer: 2,761
No, as in I don't want the ABS to kick in while riding in situations that I don't need it. Turning the ABS off I can ride through the same road pushing just as hard without any ill effects, I don't want ABS to do ANYTHING in those circumstances.
The reason I used the word transparent is that before I got ABS I've always heard the argument that you'll never know you have ABS on the bike until you need it, so it's transparent until it saves you from a certain deadly lock up. So far I haven't found that to be the case as it kicks in long before I need it in some circumstances, and actually makes it harder to hold a constant brake pressure at the limit of traction.
See what I've been up to! Ongoing Ride Report
Desert Dave is offline   Reply With Quote
Old 05-02-2014, 10:27 AM   #12
lawe
lawe
Oddometer: 141
It stays lit
Skickat från min Nexus 4 via Tapatalk
Lars
Umeå, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Times are GMT -7.   It's 12:31 AM.
