Old 12-06-2010, 12:32 PM   #1
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,583
Any Secret to getting the top nut off an Airhead Triple Tree?
I'm befuddled.
Bought the 36mm socket.
Even have the breaker bar.
Soaked all three in liquid wrench.
Several times.
None of them budge.
Thoughts?
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 12-06-2010, 01:43 PM   #2
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,330
air impact wrench
it helps having one with adjustable torque
you've taken the internal chamfer off the socket end for full engagement?
Renner is offline   Reply With Quote
Old 12-06-2010, 04:12 PM   #3
danedg
Horizontally Opposed
Oddometer: 6,773
Like this??
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg is offline   Reply With Quote
Old 12-06-2010, 04:15 PM   #4
MacRunch
MacRunch's Avatar
Oddometer: 46
Pick up a heavy piece of pipe at least 3 ft long. Place it over your breaker bar and just wrench away. It's all about leverage. I believe I read one time that Matt Parkhill uses an old airhead fork slider tube to extend the breaker bar.
MacRunch is offline   Reply With Quote
Old 12-06-2010, 04:22 PM   #5
kixtand
kixtand's Avatar
Oddometer: 2,178
In removing the three (3) nuts on top of the triple tree particular attention needs to be paid to how the fork is held / braced to allow said removal. Do NOT use the fork stop for this task!!! I have seen folks that have fashioned a bracket/bar that mounts in the handlebar riser holes, and that seems to be an easy enough solution.
Please note that even more care must be taken when reinstalling and applying the proper torque to the three (3) nuts as it is easy to twist the forks if you are not careful...
YMMV--
kix
Bacon...
it makes everything better.
kixtand is offline   Reply With Quote
Old 12-06-2010, 08:28 PM   #6
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
A fork tube, not a slider.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 12-06-2010, 10:08 PM   #7
lulu
Oddometer: 95
What worked for me was a lot of penetrating oil + heat + hammering on the bmw tool. I tried a breaker bar, but that was useless. I spent many days on that issue.
lulu is offline   Reply With Quote
Old 12-06-2010, 04:26 PM   #8
Beater OP
Beater's Avatar
Oddometer: 3,583
Originally Posted by Renner View Post
air impact wrench
Just tried again ... no dice.
Don't have an air impact wrench ...
Not sure what you mean by the 'internal chamfer' ... but here are some pics that show what's going on.
This first one is a shot of all three nuts ... I can't budge any one of them.
New 36mm socket on the end of a breaker bar.
Inside the socket?
Is there an internal chamfer that I'm not seeing?
Thanks in advance ...
Old 12-06-2010, 04:33 PM   #9
danedg
Oddometer: 6,773
Hit it with your OTHER purse!
Put a chunk of pipe on it and twist the sucker offa there.....
Old 12-06-2010, 04:35 PM   #10
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,645
those nuts are real narrow. See how the inside of the socket tapers out a bit? That little bit might be half the thickness of the nut. Makes it easy to round 'em off.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 12-06-2010, 04:37 PM   #11
Beater OP
Beater's Avatar
Oddometer: 3,583
I'll do that too ... Thanks.
You need to drop by and see my TWO new one's.
I think Greta will get G/Sified. Thoughts?
Old 12-06-2010, 05:02 PM   #12
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,330
nice, succint explanation.
my keyboard skills are also lagging
Good job Beater
hope the thumb is feeling better
Old 12-06-2010, 04:36 PM   #13
Beater OP
Beater's Avatar
Oddometer: 3,583
Believe it or not ... I did that. I broke the pipe. No sh!t.
I guess it's time for a bigger pipe.
Old 12-06-2010, 04:42 PM   #14
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,330
Originally Posted by Beater View Post
Inside the socket?
In the center of the pic. The socket leading edge.. chamfered so it goes over the nut easily.
Grind the end flat so the socket 'teeth' engage directly.
This is mostly only critical for nuts with low profiles like the spring retaining nuts either side of the steering stem center nut.
Those being aluminum... you want full purchase or rounding of the nut corners may result.
Facing the socket on a bench grinder isn't as difficult as one might imagine. Use something flat to check your progress.
Renner screwed with this post 12-06-2010 at 04:55 PM
Times are GMT -7.   It's 03:27 AM.
