Old 01-17-2011, 06:09 AM   #1
gsjam OP
gsjam's Avatar
Oddometer: 247
r80 gs bash plate
Hi guys a question to the masses .Will a bash plate from a r80 gs fit a g/s ,tiring to make the g/s a little bit more durable off road .Many thanks in advance
Here for a good time....
gsjam is offline   Reply With Quote
Old 01-17-2011, 07:11 AM   #2
The Raven
The Raven's Avatar
Oddometer: 4,811
Yes and no, apparently a R80GS pan is the same as a R100GS pan according to the fiche. These pans had no place for the oil to drain. This can be addressed with a simple hole.
The biggest downside is that the hole can grab rocks....however I have never had this issue with my KLR.
Hope this helps.
The Raven is offline   Reply With Quote
Old 01-17-2011, 11:15 AM   #3
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,014
R80GS is same as R100GS is same as R80G/S.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is online now   Reply With Quote
Old 01-17-2011, 01:58 PM   #4
Mark Manley
On my way
Mark Manley's Avatar
Oddometer: 697
It does fit both, I have a GS and a G/S and have used the same bash plate on the two of them.
If it's in the Touratech catalogue then you don't need it
"You've got to think for yourselves! You're all individuals!"-Brian of Nazareth
Mark Manley is offline   Reply With Quote
Old 01-18-2011, 03:01 AM   #5
gsjam OP
gsjam's Avatar
Oddometer: 247
bash plate
Thanks guys ,the one on the g/s looks pretty dismal I am glad the gs 80 and gs 100 are the same mountings ,now where can i get one
Old 03-14-2013, 05:01 PM   #6
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,203
Was working on a few things last night - needed to re-fasten my right header pipe after it chunked in the middle of a drive.
Was a good time to hit both sides with fresh copper anti-seize and get a straight shot at rear engine mount nut after Flying Tpot side stand install.
Thing is - I'm knocking the underbelly around pretty good and the two of us are early on in the relationship.
Headers are getting torn up, about sheered two of the oem guard fasteners and generally unethusiastic about the long term prospects for current set up.
So I'm searching for a better bash plate.
Seen a few things but wondering if I'm missing a good choice:
Bad daddy:
Originally Posted by bgoodsoil View Post
Swore I'd never spend here again:
(Also - says it's not a fit for R80 g/s pd but maybe with sawzall?)
Super Sexy (and out of my skill set)
Originally Posted by JRP View Post
Boxer Supplies - sent them an email and they confirmed 'yes to fit'
Anyone using this?
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 03-14-2013, 11:36 PM   #7
Mark Manley
On my way
Oddometer: 697
Here is a replica of the BMW original on UK ebay. I can see it is not quite they same, the mounting bolts set up is different but still looks good and I know the original works well.
http://www.ebay.co.uk/itm/BMW-large-...item3ccf1a2cfe
Times are GMT -7.   It's 01:27 PM.
