Old 02-25-2011, 09:55 AM   #1
rudolf35 OP
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Question Airhead pushrod tube seals
This might be a silly question but why does one need to use a tool to seat the pushrod tube seal with a older airhead? I know I can make the tool with a 1/2" pipe but the reason escapes me - enlighten me.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 02-25-2011, 10:45 AM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,633
I've never needed a tool for my seals.
crazydrummerdude is offline   Reply With Quote
Old 02-25-2011, 11:28 AM   #3
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,418
Wouldn't that be the metal collar (?) on the older PRT's that you could cinch down a bit if they were weeping? Newer PRT's had a brazed collar that if you tapped them would break and leak even more. Is this for the 71?
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is offline   Reply With Quote
Old 02-25-2011, 12:15 PM   #4
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
That's always been a very temporary fix at best. Spending a few bucks and a morning replacing the seals is a better solution. No special tools required, and it doesn't take very long at all.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 02-25-2011, 12:48 PM   #5
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 984
sent you a pm. Please check...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 02-25-2011, 03:26 PM   #6
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Temporary fix? Yes but it's also a reasonable solution to a frequent problem.
I've been able to reseal my PR seals using a seal setting tool and a hammer on many occasions and thereby extend the usefulness of my old seals for more than a year. It took maybe 1/2 hour to make the tool, the materials cost was zero, c clean bike? Priceless!.
I learned the trick from a trained BMW mechanic, who would always tighten up his customers seals during a regular service stop, if they showed need of it. That way, his customers could put that job off until it was time to schedule more extensive repairs, thus saving them time and money, while it also saved him time and made him money!
Nothing wrong with that!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 02-25-2011, 04:10 PM   #7
4ad
ochlacrat
4ad's Avatar
Oddometer: 2,707
These seals wear from constant expansion and contraction during the heat cycles of the engine. If you compare a new seal to an old one you'll see the ridges on the base are worn completely smooth on the old one....no amount of hammering will do much good for long and MAY even pull the pushrod tube from the cylinder....a pain to replace....and involves an angry wife wondering what the f&%k a cylinder is doing baking in her oven and stinking up her kitchen.
Besides...it's bad karma to hammer on an airhead.
Go ahead and change em...takes a 1/2 hr per side..and thats if you're slow.
This was all fun banter until 4ad posted a pic of a rapist/murderer.- GP640
4ad screwed with this post 02-26-2011 at 01:41 PM
4ad is offline   Reply With Quote
Times are GMT -7.   It's 08:40 AM.
