Old 01-23-2005, 01:05 PM   #1
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
Enduro Timekeeping How-To...
Not sure where this belongs, but since it is a form of racing, I'll stick it here.
There have been a few requests for a how-to on enduro timekeeping, I've got time today (stuck overseeing an upgrade at the office, can't leave, but not actually needed until fecal material hits the rotary oscillator), so here goes. Hope this helps.
To understand timekeeping, the place to start is with the theory involved. I'll take a shot at that, then I'll add some of the detailed rules, then I'll go to the practical side of how to run a race. I firmly believe everyone should start riding enduros with nothing more than a watch and an odometer- learning with a dedicated enduro computer means you won't really understand what's going on and how to fix it when things screw up.
The idea for an enduro is to stay on a precise time schedule and course, following a pace exactly as described by the event organizer. The organizer will put checks on the course to see where the competitors are, compared to where they should be. Going faster than the “perfect” pace results in a penalty of 2 points per minute, slower equals 1 point per minute. Points are bad- to "zero" a check is to have done perfectly.
Now, the reality is that the organizer will set unachievably fast averages for certain sections, so the fastest rider should be able to lose the least time compared to schedule, and therefore the least points, and there’s your race. But the organizer will almost certainly also put slower averages in than are possible, even easy, in an attempt to catch these racers ahead of pace. So, it’s a cat and mouse game between whoever set the race up and those riding it.
Now, let’s start with the basics. Enduros are started from a key time- usually 8:01 AM, but this will be printed on a sheet. For the sake of an example, let’s say that the first section of the enduro is 6 miles long and the speed average is 30. The second section is 3 miles long and the speed average is 15. Because the organizer knows the speed average for a section, and because he knows the distance between his checks (even though you don’t), he can set a check at say, 3 miles into the first section, which he knows should take you 6 minutes to arrive at. Therefore, the clock at that station will be set to read 7:55 when the race starts at 8:01, so when you come through, if you are riding perfectly, the check worker will write :01 on your scorecard and it will be clear that you are “on your minute”.
But, only 4 riders are on the first minute. Let’s say you are on row 34, starting at 8:34 (8:01 + 33 minutes for each row in front of you). Before the enduro, you will have taped a card on you front fender that will be written on at each check, to prove you were there, and to facilitate scoring.
You will set the clock on your handlebars to keytime minus 34 minutes. So, when you take off, your clock should read 8:01. When you arrive at that same check, assuming you are on time, their clock will read 8:34 (when you started, their clock read 8:28). And so on. Each checkpoint will mark your card with the minute, and in some cases, the second that you arrive, and write that time in a backup book as well in case the card is damaged or illegible or there is a protest.
The reason you don’t set your clock to keytime without the offset is that you want to use an enduro rollchart, which are not made specific to your row but generically for the event. By offsetting their clocks, everyone can use the same rollchart without issue.
So, over the course of the day, you’ll be following the course, arriving either early or late and that progress will be recorded on your fender card.
The next installment will explain the different types of checks and how to keep time so that you can arrive when you should, and the final installment will be tips and tricks to bring things as much as possible into your favor.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 01-24-2005, 08:49 PM   #2
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Great Thread Ned
Can't wait until you get into E-checks, AMA vs Brand X rules etc. etc. etc.
It's all enough to make ya want many many beers.
My helmet's off to you for such an ambitious endeavour.
deerslayR
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 01-25-2005, 08:47 AM   #3
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Awesome Ned!
Folks may also want to refer to some excellent articles written by Paul Clipper on the subject posted up on my site.
Check it out at:
www.motorally.ca and then follow the links to the TSD2000 and Timekeeping.
Could be a good supplement to what you write Ned.
Flanny screwed with this post 01-26-2005 at 09:23 PM
Flanny is offline   Reply With Quote
Old 01-26-2005, 05:21 PM   #4
luv
luv's Avatar
Oddometer: 218
Thank you :) your "for dummies" version is MUCH appreciated - waiting for installment 2!
-luv
Originally Posted by KiLeR650 --
Everyone I know perdicted my death when I bought my bike. I say its done just the oppisite. Even if it does kill me, it wouldnt take too many days like today to make it worth it.
luv is offline   Reply With Quote
Old 01-26-2005, 07:22 PM   #5
Salt
Moto Whore
Salt's Avatar
Oddometer: 109
Very nice neduro. I hope you keep this going.
Salt is offline   Reply With Quote
Old 01-27-2005, 06:56 PM   #6
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
I have done 2 enduros with no watch and no odometer. I just wanted to finish. Say you are on line 60. You start one hour after the first row. When it is your turn you go as fast as you feel comfortable. When you hear a loud 4 stroke revving behind you pull over, let him pass then carry on. Make note of the row numbers of the guys passing you. If you are number 60 and you are passing up to row 50 your are too fast. If you are 60 and everyone is passing you, you are slow. If you are hanging with row 59 and they have fancy enduro computers and ride well you are close to on time.
If you come around a corner and see 4-5 bikes waist deep in mud, stop and find a route around the mud hole. Thank those 4-5 guys for marking the mud hole.
Don't go too fast. I got passed by a fast guy who appeared competent. I got passed by him a bunch of times because he would crash or hit a tree shortly after passing me. This happened a lot. I would let them by and they would crash.
ICO Racing Checkmate Enduro Computer
All that timing stuff is great, but if you have to go faster than your capabilities to be on time then what is the point. Enduros are a blast and make you a better all around rider.
scooteraug02 is offline   Reply With Quote
Old 04-24-2012, 07:49 AM   #7
The_Italian
The_Italian's Avatar
Oddometer: 12
Originally Posted by Flanny View Post
Awesome Ned!
Check it out at:
thanks Neduro and Flanny for the always good jobs posted.
the links do not open though.
Any suggestion ?
what about starting a tread about the cheapest possible Enduro racing season ?
E.
The_Italian is offline   Reply With Quote
Old 04-24-2012, 02:44 PM   #8
rthuey
twist your wrist!!!
rthuey's Avatar
Oddometer: 2,827
Any suggestion ?
E.
well that link is more than 7 years old. it is not that it is broke. looks like since then the domain has been re-released into the wild. it is currently available for purchase if you or others are interested. i would like to point out that it could either be read as Motor Ally or as the previous owner it turns out was using it Moto Rally. two names for the price of one. i do register and host domains, as well as create websites so i will give myself a little plug. i can get you a website with 2 names for the price of one. PM for further details.
We're gonna go ridin!!!
rthuey is offline   Reply With Quote
Old 04-25-2012, 05:02 PM   #9
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,228
Not exactly about time keeping, but my club has a pretty good first-timers guide on our site.
http://www.ride-mci.com/first-time-enduro-checklist
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is offline   Reply With Quote
Times are GMT -7.   It's 04:08 AM.
