Old 03-07-2011, 06:27 PM   #1
BarryT OP
Oddometer: 546
Airhead mikuni carb question
My R75/7 has the rockpoint cycle mikuni kit installed. I was giving it a tune up and realized I have no idea what the needle position is supposed to be. I live at about 2,200 feet and do go down to sea level fairly regularly.
Barry
1977 BMW R75/7
2004 Kawasaki Ninja 250R (Wifes)
1977 RD400 (for sale)
2006 Buell Ulysses
BarryT is offline   Reply With Quote
Old 03-07-2011, 07:30 PM   #2
elite-less
As above, so below
elite-less's Avatar
Oddometer: 539
My r75/5's jet needle came from Rockypoint at the 3rd positions, dead center. However, I'm at sea level and my bike runs best (richer) with the clip at the 4th position. It took a good morning of riding to set my carbs properly... but once dialed in, I haven't touched them in 2 years.
This website may also be of help:
http://www.iwt.com.au/mikunicarb.htm
elite-less is offline   Reply With Quote
Old 03-08-2011, 11:32 AM   #3
mykill
odd
mykill's Avatar
Oddometer: 1,160
Start in the middle and ride a pre-determined route. Then go full rich (bottom clip) and do the same route at the same pace. Better or worse? Try at full lean (top clip) Better or worse? Then work you way back towards the middle where it is best behaved most of the time.
You should feel the difference coming off of idle through about 3/4 throttle, so don't be in a hurry to go WOT, ride like you like to ride. Hunting, searching and roughness are usually lean. Muddy, flat and unresponsive are usually rich.
Do yourself a favor and make sure timing, valves, etc are all spot on before you begin this adventure.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 03-08-2011, 11:55 AM   #4
supershaft
because I can
Oddometer: 8,836
+1 mykill! It is so easy to try it all. Why not do it! I might add what advise is right there in the beginning of the Sudco manual. If you can't tell much difference between the richer and leaner settings, stay with the leaner. If he lucks into just the right mix, he might have to raise the needle down at sea level but I doubt it will end up that close. If he was at 4200 feet instead of 2200, you could just about bank on it but . . . .
Times are GMT -7.   It's 05:54 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
