Old 03-09-2011, 10:28 AM   #1
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 537
It's alive!!!!
After 8 years living in various rubbermaid totes, and getting moved to two different states my 1965 R50/2 runs again.
This bike has a great history with me. My dad and mom were living in Hawaii and bought this bike to get around the island. When they moved back to the mainland in 1970 they shipped the bike with them. It cost the same as a seat on the plane. They flew into Seattle, got some gas for the bike, and started riding. About a week later they got to western Pennsylvania where our family is from. My dad and my uncle rode the bike for the next 5 years and then the floats in the carbs went bad. Fast forward 27 years. Dad gives me the bike to restore it. I lived in Illinois at the time and my Brother-in-law brought it out to me. I bought floats for it and got it running again. I then tore it down to fix it up. While it was in thousand of pieces, my wife gets transferred to Virginia. That was almost 3 years ago. Now it is back together and running. I still have a few things to do such as tuning it and trying to figure out why the brake light and the neutral indicator is on all of the time. Right now I can get it to run but when I try to accelerate it falls flat on its face.
1965 BMW R50/2 (RUNNING AGAIN!)
An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered. - G. K. Chesterton
65bmwr50 is offline   Reply With Quote
Old 03-09-2011, 12:00 PM   #2
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,522
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 03-09-2011, 12:12 PM   #3
Beamer Bum
Beamer Bum's Avatar
Oddometer: 319
Another one on the road. You will love riding it and the family history is unbeatable. Welcome to the Slash 2 world.
Beamer Bum is offline   Reply With Quote
Old 03-09-2011, 12:16 PM   #4
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Sweet.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 03-09-2011, 12:19 PM   #5
danedg
Horizontally Opposed
Oddometer: 6,723
Brake lite
I'll take a stab at the brake lite problem. In the picture, you can see the lever that depresses the brake light switch. It's right behind the clutch lever with the stout spring. You can't see the switch in this pic, it's mounted with them teeny nuts on the back side of the plate, and no matter what you do, it's a pain in the ass to get to it. I remember having to get the 5?mm nuts off from the other side to service the switch.
ANYWAY, the arm is supposed to depress the switch, and keep it there which "breaks" the circuit. When you step on the rear brake lever, the switch post moves forward and "makes" the circuit, actuating the lamp.
Often, the brake lever, the small lever, or the switch itself are misaligned after 46 years, and the small lever doesn't fully depress the switch, and your brake light stays on...
I, stuck a teeny little crutch tip, [visible in photo] on the actuator lever to make up the misalignment. It worked for a while, until I sucked it up and dismantled the whole shebang and set everything up right. You can see the elongated holes for adjustamento...
I'll guarantee you that switch is filled with goopy,tarry,oily grit and grime. Take it off and soak it electrical contact cleaner for a day. If it's ON, then it still works. Or you buy a new one from Vech, it was pretty cheap.
PS, Your headlight ears are upside down
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg screwed with this post 03-09-2011 at 12:59 PM
danedg is offline   Reply With Quote
Old 03-09-2011, 03:58 PM   #6
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 537
Huh, that's what you get for leaving it in pieces for 8 years...
Thanks for the info on the brake switch. I'll have to check it out. I know the switch moves freely but maybe something else is misaligned.
Old 03-09-2011, 04:23 PM   #7
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Looks great and I appreciate the good story and historical background.
I hope it runs great and you can pass it to the next generation.
datchew is offline   Reply With Quote
Old 03-09-2011, 04:34 PM   #8
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,456
That is great to see an old veteran back on the road. Particularly sweet that you've left the original "patina" live! I'm taking possession of an old 1954 Zundapp soon and hope to do the same. Great job and a great story.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
bmwhacker is online now   Reply With Quote
Old 03-11-2011, 11:09 AM   #9
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
It might be running OK on the idle jet, but you have a plugged pilot jet, then its OK on the slide/needle/main jet.
Pluck a strand out of your wire brush and clean the orifices with that and some spray cleaner.
lemieuxmc is offline   Reply With Quote
Old 03-11-2011, 01:32 PM   #10
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 537
Slides...
danedg - You got this one right. My left slide moves LONG before the right one. I only had a second to run down and check the slides but I will try to get back to it tomorrow and make an adjustment. I'm assuming the adjustment is moving the cable stop in and out. Correct?
lemieuxmc - I will clean the jets as soon as I get the slides working together. I have a feeling it's going to be a combination of things. Also, thank you for your service.
Old 03-11-2011, 02:26 PM   #11
danedg
Oddometer: 6,723
You've got 2 carbs...we've a 50/50 chance of getting this right.
I really like the fact that no major stuff has been done to your bike.
If your lucky, we can avoid the, "You really need to tear your bike down to the lowest common denominator and start over from scratch", syndrome.
It happens a lot, but it's not always necessary.
You've got provenance.
Mom and Dad knew what they were doing when they bought the R50..
It was a tough, sexy, little bike then, and it still is today.
Let's get it runnin' for you and yours.
How cool is that?
danedg screwed with this post 03-11-2011 at 04:50 PM
Old 03-11-2011, 02:30 PM   #12
norton73
drinkin'
norton73's Avatar
Oddometer: 8,320
[hijack] Sandy Hook, huh? Used to live up in Fredneck and come down to the river to paddle the staircase (Shenendoah/Potomac) right in front of your door. Hopefully the river isn't in your front door today. [hijack off/]
Nice bike!
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 03-11-2011, 03:11 PM   #13
danedg
Oddometer: 6,723
I can't find the foto, but pop the top on the carbs. Be careful of the o rings. You can get a whole new set of gaskets from BING. I think it's the OH2K kit for about $12US
Make sure that the cable end is properly attached to the slide top. It comes down from the big hole and lodges into the small hole. Sometimes it can get hung up in the wrong spot.
Yer bike doesn't have enough miles to warrant new jets.
Times are GMT -7.   It's 09:57 PM.
