Old 03-14-2011, 09:19 AM   #1
mfp4073 OP
mfp4073's Avatar
Oddometer: 1,353
How does the choke work on airhead bings?
Owners manual does not address this. I am used to manual chokes as found on classic cars/hot rods. Butterfly that restricts airflow thus making it richer that is adjustable from completely closed to completely open.
I know the bings dont use butterflies, its fuel passengers. Then realized that this may not be an adjustable setup. Are these only 3 positions (off, mid, all on choke) or are they graduatingly adjustable (is that a word)?
Does my question make sense? Not sure i am describing it very well.
1974 BMW R90/6 Bettie #1
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 03-14-2011, 09:26 AM   #2
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,873
Its more like an enricher circuit. A separate circuit on the inboard side that essentially dumps lots o fuel past the idle inlet. Pretty sure. I would have to go peruse the Bing manual again to be sure of the particular pathway details, but its basically a fourth fuel metering circuit, used only at startup because it would flood the thing otherwise.
What to do... What to do...
Stagehand is online now   Reply With Quote
Old 03-14-2011, 09:30 AM   #3
mfp4073 OP
mfp4073's Avatar
Oddometer: 1,353
Thanks for the reply, I got that much..but guess I didnt describe my question very well.
If off is 1, middle is 2, all on is 3, can i set it at say 2.5 in the controls travel? Or is it only a 3 position setup?
Old 03-14-2011, 10:09 AM   #4
rufusswan
rufusswan's Avatar
Oddometer: 900
Set it where ya want, there may be three holes but there are no notches. Once you've used it a time or two, your bike will tell you what works best for the initial fire. In the cold I crank mine on all the way, warmer whether is about 1/2.
Just remember to turn them off a few blocks down the road, as it is just a starting assist, not a "make a cold engine run better" like on a car.
1971 BMW R75/5 Toaster LWB
2002 Baja Chetak
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 03-14-2011, 10:14 AM   #5
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,873
Weell, ok paraphrasing the bing book, the slide type carbs had a plunger assembly that let a predetermined combustible air/fuel ratio to enter the carb throat. THe CV carbs are similar but use a rotary valve instead, and the mix is varied by lever position.
Doesnt specifically say there are three positions, although you can feel detentes.
Old 03-14-2011, 10:27 AM   #6
mfp4073 OP
mfp4073's Avatar
Oddometer: 1,353
Yeah can feel the detentes. Was not sure if there were passages that it lined up, so if you were not on the detentes it was blocking the flow of fuel to the enricher circuits. Since it does not say anywhere specifically "use settings at detentes" I would guess its trimable (again, is that a word?). BMW is pretty good at not leaving you guessing on stuff.
Times are GMT -7.   It's 01:18 PM.
