03-17-2011, 09:13 AM
#1 |
bikes, booze, broads...
Oddometer: 8,300
Got mine in the box. Are they preset or should I have to fiddle about with the tangs?
'08 R1200R / '10 WR290X/R '81 R100RS Rattlecandy Red '06 950 ADV Orangeboom '05 R12GS Wedding Bike '91 R100GSPD Derelict |
03-17-2011, 09:25 AM
#2 |
+/- V TDSPP
Oddometer: 19,849
Dont think they are pre-set, but they are always in the neighborhood. Its actually easy to check on these- just make sure that seam in the float is level with the carb body just as the the tang begins to engage the needle valve.
Cripes on the Yam XT you ned to make a separate clear tube and make sure the bike is level and then figure out 6mm below the carb seam... Makes the BMW seem no-nonsense.
What to do... What to do... |
03-17-2011, 09:35 AM
#3 |
because I can
Oddometer: 6,045
They are not preset.
They should turn the gas on and off just as the tang is level with the carb body. |
03-17-2011, 09:51 AM
#4 | |
Oddometer: 8,300
Right now my right side needed to be lower than the left for the carb to not over flow. In otherwais e I had to bend the tang open farther.
03-17-2011, 10:05 AM
#5 | |
+/- V TDSPP
Oddometer: 19,849
Or the overflow pipe is.
03-17-2011, 10:17 AM
#6 |
Oddometer: 8,300
...hmmm...you mean I could have a mis-matched pair of float bowls?
I've replace nearly everything in these Bings, float needles and float hinge pins as well.
